MHB How Can One Show That a Given Example is Not a Submodule?
Math Amateur
MHB
I am reading Dummit and Foote's book: "Abstract Algebra" (Third Edition) ...
I am currently studying Chapter 10: Introduction to Module Theory ... ...
I need some help with an Exercise 8(b) of Section 10.1 ...
Exercise 8 of Section 10.1 reads as follows:
https://www.physicsforums.com/attachments/8312Can someone please show me an example as requested in Part (b) of the above exercise ... and demonstrate that the given example is not a submodule ...
Peter
Hi Peter,
Try thinking about $\mathbb{Z}_{6}$ and see what you can come up with.
GJA said:
Hi Peter,
Thanks GJA ...
OK ... then consider the ring $$R = \mathbb{Z}_{6} \equiv \mathbb{Z} / 6 \mathbb{Z} = \{ \overline{0}, \overline{1}, \overline{2}, \overline{3}, \overline{4}, \overline{5} \}
... and consider $$M = R$$ as a left module over itself ...Now $$\overline{2}$$ is a nonzero element of $$R$$ ...
So, now $$\overline{3} \in M$$ is torsion since there exists a nonzero element, namely $$\overline{2} \in R $$ such that $$\overline{2} \cdot \overline{3} = \overline{0}
That is $$\overline{3} \in \text{Tor} (M)$$ ...Similarly we have $$\overline{3}$$ is a nonzero element of $$R$$ ...
So, now $$\overline{2} \in M$$ is torsion since there exists a nonzero element, namely $$\overline{3} \in R$$ such that $$\overline{3} \cdot \overline{2} = \overline{0}$$
That is $$\overline{2} \in \text{Tor} (M)$$ ...
But ... $$\overline{2} + \overline{3} = \overline{5} \notin \text{Tor} (M)$$ ... ...
Therefore, $$\text{Tor} (M)$$ does not satisfy additive closure ...
So ... $$\text{Tor} (M)$$ is not a submodule of M ...Is the above correct? ... ...Thanks again for the suggestion ...
Peter
Hi Peter,
Nicely done! Quick note on where the idea for considering $\mathbb{Z}_{6}$ came from: Trying to use a field is out because each non-zero is invertible (so things like $\mathbb{R}, \mathbb{Q},$ and $\mathbb{Z}_{p}$ are out). Good places to look for counterexamples when multiplication is involved with fields off the table are then $\mathbb{Z}_{n}$ ($n$ non-prime) and matrices.
GJA said:
Hi Peter,
Thanks GJA ...
Appreciate your help ...
Peter
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
