How can potentials be well-defined without violating U.P.?
In summary, the conversation discussed the use of the Coulomb potential in the Schrödinger equation and how it relates to the uncertainty principle. It was noted that treating the nucleus as stationary is just an approximation and a more accurate calculation would use the motion of a reduced mass around a stationary center of mass. However, this approach still has limitations, such as the size and mass of the nucleus and external environmental factors. Ultimately, the use of the Coulomb potential in quantum mechanics is an operator and the classical approach is just one possible approximation.
TomServo
281
Tried searching for equivalent question but couldn't find it.
Presumably, a potential (like a Coulomb one) comes from another particle, which has its own momentum/position uncertainty, but in the Schroedinger equation the potential is well-defined either in terms of some coordinate system or its relation to the particle that the equation is for.
So how does this work? How do we talk about the hydrogen atom as if the nucleus were stationary without violating the uncertainty principle?
Treating the nucleus as stationary is just an approximation. A more accurate calculation uses the motion of a reduced mass around a stationary center of mass. This gives slightly lower energy levels.
Yeah I get that, but using a classical orbital mechanics approach still sounds like we're well-defining position and momentum.
It's just an approximation. The position of the nucleus is well defined because we assume that it is stationary.
You are confusing two things. One is whether the uncertainty principle prevents you from having an arbitrarily well-defined potential. It does not. In the case of the Coulomb potential, adding mass to the central charge until you are within your tolerances will do the trick. The other is whether there is a practical limitation. Sure - for many reasons. You can't make a nucleus arbitrarily heavy. You can't make it arbitrarily small, so the point charge approximation has limits. There are environmental effects - the atom may be in a molecule, or there may be stray external electromagnetic fields, etc.
In QM, the Coulomb potential of a nucleus is an operator, just like the nuclear position itself is represented by an operator.
As others already pointed out, it is often a good approximation to treat the nucleus classically and this is often done in praxis. However, this is only an approximation and nobody forces you to apply it.
FAQ: How can potentials be well-defined without violating U.P.?
How is potential defined without violating the Uncertainty Principle?
Potential is defined as the energy required to move an object from one point to another in a force field. This definition does not violate the Uncertainty Principle as it only considers the energy of the object and not its position or momentum.
Can potential energy be accurately measured without violating the Uncertainty Principle?
Yes, potential energy can be accurately measured by using statistical methods that take into account the uncertainty in the measurement. Additionally, potential energy is a relative concept and does not require an exact measurement of its value.
How does potential energy relate to the Uncertainty Principle?
Potential energy does not directly relate to the Uncertainty Principle. However, the uncertainty in measuring the position and momentum of an object can indirectly affect the measurement of potential energy.
Is it possible to have a well-defined potential energy and still violate the Uncertainty Principle?
No, it is not possible to have a well-defined potential energy and violate the Uncertainty Principle. The principle states that there is a fundamental limit to the precision with which certain pairs of physical properties of a particle, such as position and momentum, can be known simultaneously.
Are there any exceptions to the Uncertainty Principle when it comes to potential energy?
No, the Uncertainty Principle applies to all physical systems, including those involving potential energy. It is a fundamental principle of quantum mechanics and has been extensively tested and proven to hold true in countless experiments.
