How can scalars like voltage, impedance, etc. be added like vectors?
In summary, scalars like voltage and impedance can be added like vectors by considering their phase relationships in AC circuits. While scalars represent magnitudes, when dealing with alternating currents, they can have phase angles that affect their combination. By converting these scalars into complex numbers or phasors, one can add them using vector addition, taking both magnitude and phase into account. The resultant can then be converted back to a scalar form for practical use. This method allows for a more accurate representation of the behavior of electrical quantities in sinusoidal steady-state analysis.
Aurelius120
251
24
TL;DR Summary
Confusion regarding phasors and a proof on why scalars can be added like vectors and still give correct answers. Especially in ##L-C-R## circuits connected to Alternating Current.
So we learnt about the different types of circuits and their behaviour when connected to an alternating current source.
(DC was treated as an AC with 0 frequency and/or infinte time period).
For purely inductive and purely capacitive circuits we were shown the derivation and why things are the way they are.
Then came Series L-C-R circuit.
In this they said that:
For an AC source,
##V=V_○\sin(\omega t)## which is the equation of a wave.
So to make calculations easier, "We treat them as vectors".
$$\vec{V}=\vec{V_{R}}+\vec{V_{L}}+\vec{V_{C}}$$
Then this
And this
And finally these:
$$V=\sqrt{V_R^2+(V_L-V_C)^2}$$
$$Z=\sqrt{R^2+(X_L-X_C)^2}$$
$$\tan\phi=\frac{|V_L-V_C|}{V_R}=\frac{|X_L-X_C|}{R}$$
And then we moved to question solving.
But all of this doesn't make a scalar quantity a vector quantity(that was just an assumption to make things easier)
The best explanation I got was that it is the way it is and adding them as ##V=V_R+V_L-V_C## gives wrong answers.
So I tried to add them like the scalars they are and subsequently obtain/prove the vector equations from that. But I couldn't do it.
Can you provide an explanation and/or proof of what happens that makes scalar additions (in reality) give same answers as vector addition (an assumption for ease of calculations)?
A similar thing is observed with amplitude of waves in superposition and got no explanations there either.
DaveE said:
I do get the importance of phasors(to an extent, especially in SHM)
I don't get why they work the way the do?
I don't understand why:
If voltage across inductor is ##V_L##, across capacitor is ##V_C## and resistor is ##V_R##
Why is $$|\vec V|=V_○\sin(\omega t) |\hat n|=|\vec V_R+\vec V_L+\vec V_C| $$
$$\implies V=V_○\sin(\omega t) =\sqrt{V_R^2+(V_L-V_C)^2}$$
Doesn't this violate Kirchoff's Rule?
According to which ##V=V_○\sin(\omega t)=V_L+V_C+V_R##
Yes but you then have to do the next step of describing V_L, et. al. using the impedance definitions:
##V_L(t) = L \frac{di}{dt}## etc.
This is where phasor notion is really useful. Because ##\frac{d(sin(\omega t))}{dt} = \omega cos(\omega t)= \omega sin(\omega t + \pi/2)##. When you express this with complex numbers (i.e. vectors) then this appears as a 90o phase shift, or multiplication by ##i##.
It's not *just* vectors, it's 2-D vectors. You can think of this as just a mathematical representation of an ordered pair of real numbers. But there are a couple of magical things that make everyone want to do this. First, a 2-D vector can also be described as a complex number (not true for 3-D etc.), which makes calculations easy. Second, if you represent everything as sinusoids (think Fourier & Laplace...) operators like integration and differentiation are simple changes to the gain and phase of the sinusoids. i.e. sinusoids in the domain are mapped to sinusoids in the range with pretty simple rules. In particular, the frequency isn't changed. This allows a "phasor" notation where everything is expressed as gain and phase changes to an underlying oscillation.
Your underlying question is good. Yes, they are just voltages (currents, impedance, etc.). But it sure is convenient to use a mathematical model that allows for easy comprehension and calculation. There is nothing in phasor notation that can't be done with rigorous, explicit, calculus, but no one wants to actually do that very often. We prefer simple algebra to memorized trig identities. This is particularly useful when you move on to Laplace transform solutions to the resulting DEs, which also work really well for transient problems and non-sinusoidal conditions.
PS: I think you'll really understand it if you go through the complete rigorous solution to a simple circuit DE keeping all of the ##sin(\omega t)## terms. Then use trig identities to express the answer in the simplest form ##Asin(\omega t + \phi)##. Frankly, it's a PIA compared to phasors.
Likes Klystron and Aurelius120
So are ##V_L## and ##V_C## the voltages across ##L## and ##C## or are their sine components the voltage acrosss ##L## and ##C##?
How to know when to use phasors?
Do they work for all sinusoidal waves?
How did they know that if the source is a sinusoidal wave, then ##V_L## and ##V_C## will also be sinusoids just with different phase? (and not logarithmic or exponential or some other weird function)
Linear circuits with sinusoidal excitation. Unless you prefer different analysis approach. You don't HAVE to use them.
Yes. Sinusoids can always be expressed in the form ##f(t)=Asin(\omega t + \phi)##, for example.
Aurelius120 said:
How did they know that if the source is a sinusoidal wave, then VL and VC will also be sinusoids just with different phase? (and not logarithmic or exponential or some other weird function)
This is is always true for linear circuits. Where the components V, I characteristics are defined as simple linear equations, like ##v(t) = Ri(t), v(t)=L\frac{di}{dt}##, etc. It absolutely doesn't work for non-linear circuits, like ##v(t) = a_0+a_1i(t)+a_2i^2(t)+....##. In those cases you will generate additional harmonic frequencies and/or sum and difference frequencies that aren't necessarily present in the excitation waveform(s).
The other great thing about linear circuits is superposition. By definition we know f(ax(t)+by(t))=af(x(t))+bf(y(t)), where a,b are constants.
Likes Aurelius120
Also, if your excitation is composed of multiple frequencies, like ##f(t)=a_0+a_1sin(\omega_1 t + \phi_1)+a_2sin(\omega_2 t + \phi_2)+...##, you would want to use superposition to solve separately for each term (each frequency) and add the solutions together at the end. Phasors work for the solution of each term. But you have to go back to the original form at the end, with a solution like ##g(f(t))=b_0+b_1sin(\omega_1 t + \theta_1)+b_2sin(\omega_2 t + \theta_2)+...##.
In this case ##g(a_nsin(\omega_n t + \phi_n)) = b_nsin(\omega_n t + \theta_n)##
But, again, only for linear circuits!
Aurelius120 said:
TL;DR Summary: Confusion regarding phasors and a proof on why scalars can be added like vectors and still give correct answers. Especially in ##L-C-R## circuits connected to Alternating Current.
For an AC source,
○V=V○sin⁡(ωt) which is the equation of a wave.
Not strictly a wave because there is no distance involved.
The equation of a wave has the form
V = V0sin(ωt -kx)
Without the kx, it's just an oscillation in time. Perhaps the term 'waveform' would make things ok.
No. Each of the three terms is the value of a function of ##t##. Each value varies with ##t##. There is no value of ##t## for which those three values are a maximum, for example.
Yeah but what I meant was
How can ##V=V_L+V_R+V_C=\sqrt{V_R^2+(V_L-V_C)^2}##?
##\implies (V_L+V_R+V_C)^2=V_R^2+(V_L- V_C)^2## for all values of t
For three numbers, ##a,b,c## how is it possible that ##(a+b+c)^2=a^2+(b-c)^2?##
V = V0sin(ωt -kx)
But it's represented by a wave in graph and called AC wave?
It's a terminology thing.
In physics, 'wave' has a special meaning - it's a pattern moving through space and caused by oscillations. E.g. a sound wave, a water wave or a light wave.
The 'wavy' shape of a graph of (for example) ##V = V_0 \cos (\omega t + \phi)## is called 'sinusoidal'. A sinusoidal voltage-time graph is often called a sinusoidal waveform.
Also, we don't refer to an 'AC wave'. The term 'AC signal' wold be better,
Likes Klystron
The problem is caused by using the symbols ##V_R, V_L## and ##V_C## with two different meanings. Hope the following isn't too long...
We need to distinguish between instantaneous values and peak values (amplitudes). (If preferred, we could consider RMS values rather than amplitudes but let's use amplitudes here.)
For R, L and C in series with an applied voltage ##V(t) = V_0 \sin(\omega t)##, Kirchhoff's (2nd) law tells us that at any time ##t##:
##V(t) = V_R (t) + V_L (t) + V_C (t)##
No problem,
But each component has its own sinusoidal voltage across it. Each voltage has its own amplitude and phase:
##V_R(t) = V_{0,R} \sin (\omega t)##
##V_L(t) = V_{0,L} \sin (\omega t + \phi_L)##
##V_C(t) = V_{0,C} \sin (\omega t + \phi_C)##
Note that the three amplitudes don’t add to equal the amplitude of the supply. It is not true that ##V_0 = V_{0,R} + V_{0,L} +V_{0,C}## because of the different phases.
When you do the maths, the correct relationship between the amplitudes is:
##V_0 = \sqrt {V_{0,R}^{~2} + (V_{0,L}-V_{0,C})^2}##
The confusion arises when the above equation is abbreviated to
##V = \sqrt {V_R^2 + (V_L- V_C)^2}## without explanation.
Likes Mister T, gmax137, Klystron and 2 others
And when we say current in a circuit, we refer to :
$$I_○=\frac{V_○}{Z}=\frac{V_{L_○}}{X_L}=\frac{V_{C_○}}{X_C}=\frac{|V_{L_○}-V_{C_○}|}{|X_L-X_C|}=\frac{V_{R_○}}{R}$$
Yes - providing we're talking about a series RLC circuit of course.
And don't forget the handy result ##Z = \sqrt{R^2+ (X_L-X_C)^2}##
Just one more question:
How do we know that current is in phase with ##V_{R_○}##? Is this derived from the Differential Equation or from phasors?
It is not correct to say that the current is in phase with ##V_{R_○}## because current, ##I(t)##, is a time-varying quantity but ##V_{R_○}## is a constant - it is the amplitude of ##V_R(t)##.
But we can say that for an ideal resistor, the instantaneous current through it is in phase with the instantaneous voltage across it. The phase-difference between the current and voltage for a resistor is zero: ##V_R(t) = I_R(t) \times R## - which is just saying that (for an ideal resistor) Ohm's law works even for oscillating voltages and currents. (But see note* below.)
I'd say the fundamental physical reason is this. Inductors and capacitors, operating in an AC circuit, cyclically store/return energy from/to the circuit. This is what gives rise to the phase-difference between their voltage and current.
This is not true of a resistor. As a consequence there is no phase-difference between a resistor's voltage and current.
This is not 'derived from' a differential equation or phasors. It's the other way around. When you set up differential equations or phasors, you make sure they represent the actual behaviour of the resistors, inductors and capacitors.
*Note: Warning! Under some conditions (e.g. very high frequencies) real resistors do not behave as ideal ones. The same goes for other components. It's worth being aware of this.
Likes DaveE and Aurelius120
FAQ: How can scalars like voltage, impedance, etc. be added like vectors?
How can voltage be added like vectors?
Voltage can be added like vectors when dealing with alternating current (AC) circuits. In AC circuits, voltages are represented as phasors, which are complex numbers that encode both magnitude and phase angle. When adding these voltages, you need to take both their magnitudes and phase angles into account using vector addition in the complex plane.
What is the process for adding impedances like vectors?
Impedances in AC circuits can also be added like vectors because they are complex quantities consisting of resistance (real part) and reactance (imaginary part). To add impedances, you convert them to their complex form and then perform vector addition by adding their real and imaginary components separately.
Why do we need to consider phase angles when adding AC voltages?
Phase angles are crucial in AC circuits because they represent the time shift between different sinusoidal waveforms. When adding AC voltages, ignoring phase angles can lead to incorrect results. By considering phase angles, you ensure that both the magnitude and the timing of the voltages are accurately accounted for, using vector addition in the complex plane.
Can DC voltages be added like vectors?
No, DC voltages cannot be added like vectors because they lack a phase component. DC voltages are scalar quantities and can be added arithmetically by simple algebraic addition, without the need for considering direction or phase.
How do you represent impedance as a vector?
Impedance is represented as a vector in the complex plane, often written in the form Z = R + jX, where R is the resistance (real part) and X is the reactance (imaginary part). The magnitude of the impedance vector is given by the square root of (R² + X²), and the phase angle is the arctangent of (X/R). This complex representation allows for vector addition of impedances.
