MHB How can the convexity of a disk be proved using linear algebra?
  • Thread starter Thread starter rputra
    Disk
rputra
I am working on a linear algebra problem like this:
> Consider the set of all points $(x,y) \in \mathbb R^2$ as defined by $x^2 + y^2 \leq 25$. Prove that $x^2 + y^2 \leq 25$ is convex.
Here is what I have made out so far:
(1) $x^2 + y^2 \leq 25$ is a disk with center at the origin of Cartesian coordinate with radius of $5$. Consider two points in the disk as defined by $P(a,b)$ and $Q(c,d)$. Consider also point $R(e,f)$ which lays in the segment line $\overline {PQ}$.
(2) By way of contradiction, we will assume that $R(e,f)$ lays outside of the disk. Hence, while we have $a^2+b^2 \leq$ 25 and $c^2+d^2 \leq 25$, we assume that $e^2+f^2 > 25$.
(3) Since $R(e,f)$ lays in the line segment $\overline {PQ}$, there exist $t_1 \geq 0$, and $t_2 \geq 0$, with $t_1 + t_2 = 1$, such that
$$\begin{align}
(e, f) &= t_1(a,b) + t_2(c,d)\\
&= at_1 + ct_2, bt_1 + dt_2.
\end{align}$$
After the third step, I believe that I need to algebraically manipulate $(at_1 + ct_2)^2 + (bt_1 + dt_2)^2$ such that $(at_1 + ct_2)^2 + (bt_1 + dt_2)^2 > 25$ is impossible. However, I am stuck on how to contradict my own assumption. Do I have to use the Triangle Inequality instead? Any helps or suggestion would be very much appreciated.
Thank you before hand for your time and effort.
Hi Tarrant,
To show that your set (which I'll call $\Omega$) is convex, prove that given $\lambda\in [0,1]$, $(x,y),(a,b)\in \Omega$, we have $\lambda(x,y) + (1 - \lambda)(a,b)\in \Omega$, i.e., $(\lambda x + (1 - \lambda)a, \lambda y + (1 - \lambda) b) \in \Omega$. Obtain the identity
$$[\lambda x + (1 - \lambda)a]^2 + [\lambda y + (1 - \lambda)b]^2 = \lambda^2(x^2 + y^2) + 2\lambda(1 - \lambda)(xa + yb) + (1 - \lambda)^2(a^2 + b^2)$$
Since $x^2 + y^2 \le 25$ and $a^2 + b^2 \le 25$, then $\lambda^2(x^2 + y^2) \le 25\lambda^2$ and $(1 - \lambda)^2(a^2 + b^2) \le 25(1 - \lambda)^2$. Now, by the Cauchy-Schwarz inequality, $xa + yb \le \sqrt{x^2 + y^2}\cdot \sqrt{a^2 + b^2} \le 5 \cdot 5 = 25$. Therefore $2\lambda(1 - \lambda)(xa + yb) \le 25 \cdot 2\lambda(1-\lambda)$. Consequently,
$$\lambda^2(x^2 + y^2) + 2\lambda(1 - \lambda)(xa + yb) + (1 - \lambda)^2(a^2 + b^2) \le 25\lambda^2 + 25\cdot 2\lambda(1-\lambda) + (1 - \lambda)^2 = 25[\lambda^2 + 2\lambda(1 - \lambda) + (1 - \lambda)^2] = 25[\lambda + (1 - \lambda)]^2 = 25$$
This proves $[\lambda x + (1 - \lambda)a]^2 + [\lambda y + (1 - \lambda)b]^2 \le 25$, as desired.
Euge said:
Hi Tarrant,
Thank you for your quick response, and apology for not responding fast enough. I have one question though about the Cauchy-Schwartz Inequality:
(1) According to Wolfram MathWorld, the vector form of the inequality looks like this:
$$||\mathbf a \cdot \mathbf b|| \leq ||\mathbf a|| \ ||\mathbf b||,$$
see its link here: Cauchy's Inequality -- from Wolfram MathWorld
Don't you think the left-hand side should be absolute sign instead, so that it goes like this:
$$|\mathbf a \cdot \mathbf b| \leq ||\mathbf a|| \ ||\mathbf b||,$$
simply because the result of a dot product is already scalar?
(2) If my observation is true, do you think you have to make sure that the left-hand side is always positive in order for your proof to be valid? Please let me know.
Thank you again and again for your quick response.
Yes, you're right. The author made a typo there.
No. For all real numbers $t$, $t\le \lvert t\rvert$. So $xa + yb \le \lvert xa + yb\rvert \le \sqrt{x^2 + y^2}\sqrt{a^2 + b^2}$. Since $2\lambda(1 - \lambda)$ is a nonnegative number, then $2\lambda(1 - \lambda)(xa + yb) \le 2\lambda(1-\lambda)\sqrt{x^2 + y^2}\sqrt{a^2 + b^2}$.
Thank you again and again.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
