How can the diagonal of a topological space determine if it is Hausdorff?
  • MHB
  • Thread starter Chris L T521
In summary, a topological space is a mathematical concept used to describe the properties of a space or set of objects. The Hausdorff property, also known as the separation axiom, describes the degree of separation between points in a space. The diagonal of a topological space can determine if it is Hausdorff, and Hausdorff spaces have important properties and connections to metric spaces. However, not all topological spaces are Hausdorff as there are different types with different properties and separation axioms.
Chris L T521
MHB
915
Here is this week's problem!
Problem: Let $X$ be a topological space. Show that $X$ is Hausdorff if and only if the diagonal $\Delta=\{x\times x:x\in X\}$ is closed in $X\times X$.
This week's question was correctly answered by girdav. Here's my solution:
Proof: ($\Rightarrow$) Let $X$ be Hausdorff and let $\Delta=\{x\times x:x\in X\}$ denote the diagonal of $X\times X$. We seek to show that $\Delta$ is closed in $X\times X$. Suppose $x\times y\in X\times X\backslash\Delta$. Thus, $x\neq y$ and there exists disjoint open sets $U$ and $V$ such that $x\in U$ and $y\in V$. By the definition of the product topology on $X\times X$, $U\times V$ is an open subset of $X\times X$; furthermore, $U\times V\subset X\times X\backslash\Delta$ (otherwise, $U\cap V\neq\emptyset$ [contradicting the fact that $X$ is Hausdorff]). Since $U\times V$ is open in $X\times X\backslash\Delta$, $\Delta$ is closed in $X\times X$.
($\Leftarrow$) Let $\Delta=\{x\times x:x\in X\}$ be closed in $X\times X$. We seek to show that $X$ is Hausdorff. Again, consider $x\times y \in X\times X\backslash\Delta$, where $x\neq y$. Then there is a basis open set $U\times V\subset X\times X\backslash\Delta$ that contains $x\times y$ (in the product topology). Here, $U$ and $V$ are disjoint open sets containing $x$ and $y$ respectively. Therefore, $X$ is Hausdorff.Q.E.D.
Here's girdav's solution:
Assume that the diagonal $\Delta$ is closed (for the product topology), and take $x,y\in X$ with $x\neq y$. Then $(x,y)\in X\times X\setminus\Delta$ which is open, hence we can find $U$ and $V$ two open subsets of $X$ such that $(x,y)\in U\times V\subset X\times X\setminus\Delta$. We have $x\in U$,$ y\in V$ and if $z\in U\cap V$, $(z,z)$ wouldn't be in $\Delta$. Hence $U$ and $V$ are disjoint, which proves that $X$ is Hausdorff.
Conversely, assume that $X$ is Hausdorff. We shall show that the complement of the diagonal $C$ is open. Let $(x,y)\in C$. Then $x\neq y$ and we can find two disjoint open subsets of $X$, $U$ and $V$, such that $x\in U$ and $y\in V$. Then $U\times V$ is open for the product topology, and $U\times V\subset C$ (if $(x,y)\in\Delta$, $x=y$ and $(x,x)$ can't be in $U\times V$, since $U$ and $V$ are disjoint).
FAQ: How can the diagonal of a topological space determine if it is Hausdorff?
What is a topological space?
A topological space is a mathematical concept used to describe the properties of a particular space or set of objects. It is a generalization of the more familiar notion of Euclidean space, and it is used to study the ways in which objects can be arranged and related to one another in a given space.
What is the Hausdorff property?
The Hausdorff property, also known as the separation axiom, is a fundamental concept in topology that describes the degree of separation between points in a space. A topological space that satisfies the Hausdorff property is known as a Hausdorff space, and it has the property that any two distinct points in the space can be separated by disjoint open sets.
The diagonal of a topological space refers to the set of all points in the space that have identical coordinates. In other words, it is the set of points where the x-coordinate is equal to the y-coordinate, and so on. If a topological space is Hausdorff, then its diagonal is always a closed set. Conversely, if the diagonal is closed, then the space is Hausdorff.
What are the benefits of having a Hausdorff space?
Hausdorff spaces have several important properties that make them useful in mathematical analysis and other applications. For example, the Hausdorff property ensures that limits of sequences in the space are unique, and that continuous functions on the space are well-behaved. Additionally, Hausdorff spaces have a nice connection to metric spaces, which allows for the use of tools and techniques from metric topology.
Are all topological spaces Hausdorff?
No, not all topological spaces are Hausdorff. In fact, there are several different types of topological spaces that have different properties and satisfy different separation axioms. For example, the Sierpinski space is an example of a topological space that is not Hausdorff. It is important to note that while the Hausdorff property is desirable in many situations, it is not always necessary or appropriate for a given space or problem.
