How can the gradient of a scalar field be covarient?
In summary, according to Carroll, the covariant under rotations is that the one-forms \mathrm{d} q^{\mu} are the dual basis to the holonomous basis \partial_{\mu} induced by the coordinates. This really confuses me. For example, how could equations like \vec{F}=-\nabla V be rotationally covariant if force is a contravariant vector?
  • #36
micromass said:
Sure, no problem. You just define it the same way. But what does this have to do with orthogonal coordinates?
Just that if you were using non-orthogonal coordinates, like having the x and y-axis in the Euclidean plane forming an acute or obtuse angle, df and ∇f would have different components, (just like they would have if we were in a curved surface) and we couldn't identify the gradient of a function with a vector as we usually do in regular vector calculus in Euclidean space with orthogonal coordinates, it would have to be a covector.
micromass said:
The point is that if we look at the gradient as covector, then defining it in polar and in rectangular yields exactly the same thing. So the covector is coordinate invariant. The gradient as vector does change as we change the coordinates.
Yes, sure. Differential forms are coordinate independent while vector fields representation is coordinate dependent, was this what you wanted to highlight?
  • #37
Yes that was what my original example was trying to do. This was the OP's original question.
  • #38
Being nonorthogonal is one way that vectors and covectors can be different, but they are different even for orthogonal coordinates in lots of circumstances.
Here's an intuitive way to get an idea of which mathematical objects should be thought of as vectors, and which should be thought of as covectors: Suppose you are given a mathematical description of a situation in good old Cartesian, Euclidean coordinates (x,y,z), but with one difference: Different units are used in measuring distances in the x-y plane and in measuring distances in the vertical direction (z-direction). An example of such a situation is the measurements used by sailors in the olden days. Distances along the surface of the ocean were measured using nautical miles, while vertical distances below the surface of the ocean were measured using fathoms. How long is a fathom, in terms of nautical miles? If you don't know the conversion factor, then you can't convert between vertical distances and horizontal distances.
But you can still do a lot of vector analysis. For instance, you can compute velocities as vectors with components [itex]V^x = \dfrac{dx}{dt}, V^y = \dfrac{dy}{dt}, V^z = \dfrac{dz}{dt}[/itex]. If there is a scalar function, say the temperature of the ocean, [itex]T(x,y,z)[/itex], you can compute a one-form [itex]dT[/itex] with components [itex]dT_x = \dfrac{\partial T}{\partial x}, dT_y = \dfrac{\partial T}{\partial y}, dT_z = \dfrac{\partial T}{\partial z}[/itex]. You can combine a vector with a one-form to get a scalar: If a fish has velocity [itex]V[/itex] and the water has a temperature "gradient" [itex]dT[/itex], then the rate of change of temperature for the fish will be given by:
[itex]\dfrac{dT}{dt} = V^i (dT)_i[/itex]
But what you can't do is compute any kind of "dot-product" between two vectors, or between two one-forms.
  • #39
Ah, ok, thanks WN.
On rereading it was not so easy to see that just by the wording of post #1.
But I,m glad I get this now.
I thought by the title of the thread he was more interested in the reasons why in usual vector calculus the gradient could be considered a vector field.
  • #40
I don't blame you; it was ambiguous for me as well. I only realized that was what he was asking later on. I still couldn't find the pages in Carroll where this was mentioned so I gave up on that haha.
  • #41
Maybe Tricky Dicky meant positive definite metric and orthonormal?
I believe the usual vector calculus gradient is gijf,j with Euclidean metric and f,j are the components of the gradient covector.
