How can the Higgs Boson induce mass?
In summary, the Higgs boson is a quantum excitation of the Higgs field, which is responsible for giving mass to particles through interactions with itself and other particles. Other particles that also interact with themselves are gluons and gravitons. The Higgs field allows for the masses of fermions and gauge fields to be incorporated in a gauge invariant way, without violating fundamental principles. This concept can be compared to photons as the quantum excitations of the electromagnetic field.
Mukilab
73
How can the Higgs boson induce mass?
How can it interact with itself? Is it the only particle able to do so, if yes, why, and if no, what other particles can interact with themselves?
As a side thought, is Young's Double Slit Experiment evidence of particles interacting with themselves (the electron as a wave entering both slits simultaneously)?
What we sometimes call "the Higgs" is really two things: a constant background field h0 and a Higgs boson: quantum excitations of that field. It's the Higgs field that is believed to be responsible for the masses of the fermions (electrons, neutrinos, quarks) along with the gauge fields W and Z. These masses could have been put into the theory by hand, but not without violating a fundamental principle, electroweak gauge invariance. What the Higgs field does is to allow these terms in a gauge invariant way.
Other particles that interact with themselves are gluons and gravitons.
So how is the higgs boson related to the higgs field/is it related at all?
What do you mean by quantum excitations of the field? Surely every particle would 'excite' the field at any level since it has mass and gravity.
Thank you for the quick answer by the way :)
Consider photons. Photons are the quantum versions of electromagnetic waves, which are ripples in the electromagnetic field. It's possible to have a constant background electromagnetic field, for example the one created by a permanent magnet. Then if you jiggle around some charges somewhere, you will create ripples in the electromagnetic field on top of whatever constant field is already there. These ripples travel as electromagnetic waves, which are described quantum mechanically in terms of photon particles. We could say that photons are the "quantum excitations" of the electromagnetic field.
It's the same with the Higgs. There is a Higgs field that is very much like the electromagnetic field, and in the universe there is a constant background Higgs field. If you jiggle massive particles around in the right way, you can create ripples in the Higgs field which travel as waves, and which are described quantum mechanically as particles called Higgs bosons. We say that Higgs bosons are the "quantum excitations" of the Higgs field.
FAQ: How can the Higgs Boson induce mass?
What is the Higgs Boson and how does it relate to mass?
The Higgs Boson is a subatomic particle that was first theorized in the 1960s. It is associated with the Higgs Field, which is thought to give particles mass through interactions.
How does the Higgs Boson induce mass?
The Higgs Boson interacts with the Higgs Field, which permeates all of space. This interaction slows particles down and gives them mass.
How was the Higgs Boson discovered?
The Higgs Boson was first discovered in 2012 by the Large Hadron Collider (LHC) at CERN. Scientists observed the decay of the Higgs Boson into other particles, providing evidence of its existence.
What is the significance of the discovery of the Higgs Boson?
The discovery of the Higgs Boson confirms the existence of the Higgs Field and provides a deeper understanding of how particles acquire mass. This discovery also supports the Standard Model of particle physics and opens up new possibilities for future research.
Can the Higgs Boson be used to create mass in everyday objects?
No, the Higgs Boson only plays a role in the mass of subatomic particles. The amount of mass it can induce is minuscule and cannot be applied to everyday objects.
