How can the product of two categories help us understand groups?
In summary, Awodey's definition of the product of two categories C and D states that for the category of groups, the product category G x H has objects of the form (G,H) where G and H are groups and where G is in C and H is in D. Arrows in the product category are of the form (f,g):(G,H) -> (G',H') where f:G -> G' and g:H -> H'. This definition implies that the product category for groups is equivalent to the direct product of groups, as recognized by Awodey. However, it should be noted that the product of two categories does not always correspond to the direct product of their objects.
Math Amateur
MHB
3,998
48
I am reading Steve Awodey's book: Category Theory (Second Edition) and am focused on Section 1.5 Isomorphisms ...
I need some further help in order to fully understand some aspects of the definition of the product of two categories as it applies to the category Groups ... ...
The definition of the product of two categories ... reads as follows:View attachment 8356
For the category Groups of groups and group homomorphisms, the product category of two categories \(\displaystyle C\) and \(\displaystyle D\), namely \(\displaystyle C \times D\), has objects of the form \(\displaystyle (G,H)\) where \(\displaystyle G\) and \(\displaystyle H\) are groups and where \(\displaystyle G \in C\) and \(\displaystyle H \in D\) ...
Arrows would be of the form
\(\displaystyle (f,g) : (G,H) \to (G',H')\)
for \(\displaystyle f: G \to G'\) and \(\displaystyle g: H \to H'\)
... BUT ...
... now ... you would expect ... indirectly at least! ... that the definition of the category and its rules would specify the product ...\(\displaystyle (g_1, h_1) \star (g_2, h_2) = (g_1 \bullet_1 g_2, h_1 \bullet_2 h_2)\) ... ...
... where we are dealing with a product of two groups \(\displaystyle G\) and \(\displaystyle H\) ... namely \(\displaystyle G \times H\) ...
... where \(\displaystyle g_1, g_2 \in G\) and \(\displaystyle h_1, h_2 \in H\) are elements of the two groups ...... BUT! ...
how does the product category definition imply this in the case of groups ...
Note that what got me started on my chain of thoughts above was Awodey's statement at the end of the above quote, viz.: (see above scanned text ...)
" ... ... The reader familiar with groups will recognize that for groups \(\displaystyle G\) and \(\displaystyle H\), the product category \(\displaystyle G \times H\) is the usual (direct) product of groups ... ... "
How should we interpret this remark?Hope someone can help ...
Peter
Let $G$ be a group, let us use the notation $\overline{G}$, that is, G is a group viewed as a group and $\overline{G}$ is the group G viewed as category.
Given a group $G=(G, 1, \cdot )$
$\overline{G}$ is defined as follows:
$\overline{G}$ has one object, say $\star$
Each element $g$ of $G$ corresponds with an arrow $g: \star \rightarrow \star$ in $\overline{G}$
The composition $g \circ h$ in $\overline{G}$ corresponds with the product $g \cdot h$ in $G$
The identity $1_\star$ in $\overline{G}$ corresponds with the unit $1$ in $G$
Idem for inverses and associativity
Show that $\overline{G \times H}$ corresponds with the group $G \times H$
$\overline{G \times H}$ has one object, say $\bullet$
Each element $(g, h)$ of $G \times H$ corresponds with an arrow $\alpha = (g, h): \bullet \rightarrow \bullet$ in $\overline{G \times H}$
The composition $(g, h) \circ (p, q)$ in $\overline{G \times H}$ corresponds with the product $(g, h) \cdot (p, q) = (gp, hq)$ in $G \times H$
The identity $1_\bullet$ in $\overline{G \times H}$ corresponds with the unit $(1, 1)$ in $G \times H$
I think this is enough to show the correspondence
(One can also consider to prove $\overline{G \times H} \cong \overline{G} \times \overline{H}$,
In that case $(g, h) \circ (p, q) = (g \circ p, h \circ q)$ makes sense
too much work for me)
Elementwise products like $(g, h) \star (p, q)=(g \bullet p, h \bullet q)$ make sense in, for instance groups. They make no sense in general categories, because an object $C$ of a category $\mathscr{C}$ in general does not have elements
In fact, looking closely at a group $G$ viewed as a category, you see that this category does not possesses elements: besides one object, it only contains arrows. And products like $(g, h) \star (p, q)=(g \bullet p, h \bullet q)$ make only sense if $g, h, p, q$ are arrows.
Thanks for this post Steenis ...
It is most helpful ...
Peter
- - - Updated - - -
Thanks steenis ...
Peter
Peter
- - - Updated - - -Thanks steenis ...
Peter
Maybe initially I should have had the confidence to simply translate Awodey's definition of the product of two categories into the case for two groups \(\displaystyle G\) and \(\displaystyle H\) ... visually \(\displaystyle G \times H\) ... where the two groups and their product are viewed as categories ...Now the Awodey's definition ( with a couple of trivial amendments to the notation ... ) reads as follows:
"The product of two categories \(\displaystyle C\) and \(\displaystyle D\), written as \(\displaystyle C \times D\) has objects of the form \(\displaystyle (A, B)\) for \(\displaystyle A \in C\) and \(\displaystyle B \in D\), and arrows of the form
\(\displaystyle (f, g) : (A, B) \to (A', B')\)
for \(\displaystyle f : A \to B\) and \(\displaystyle g : A' \to B'\)
Composition and units are defined componentwise, that is
\(\displaystyle (f', g') \circ (f, g) = (f' \circ f, g' \circ g ) \)
\(\displaystyle 1_{ (C, D) } = ( 1_C, 1_D ) \)
Now ... following the above ... the product of two groups \(\displaystyle G, H\) viewed as categories ... written as \(\displaystyle G \times H\) has objects of the form \(\displaystyle ( \bullet, \star )\) for \(\displaystyle \bullet \in G\) and \(\displaystyle \star \in H\) ... and arrows of the form
\(\displaystyle (x, y) : ( \bullet, \star ) \to ( \bullet, \star )\)
for \(\displaystyle x : \bullet \to \bullet \) and \(\displaystyle y : \star \to \star\) Composition and identities/units are defined componentwise
\(\displaystyle (x', y') \circ (x, y) = (x' \circ x , y' \circ y )\)
where \(\displaystyle (x' \circ x , y' \circ y ) = ( x' \times_1 x , y' \times_2 y ) \)
and
\(\displaystyle 1_{ (G, H) } = ( 1_G, 1_H)\) Thus ... for groups \(\displaystyle G\) and \(\displaystyle H\) the product category \(\displaystyle G \times H\) is the usual external direct product for groups ...
Essentially the composition of arrows in the product category is interpreted as 'multiplication' in the direct product ... Is the above a correct interpretation ... ?
Peter
Where did I go wrong ?
I should not only consider to prove $\overline{G \times H} \cong \overline{G} \times \overline{H}$,
but I must prove this. Only then the compositon rule
$$ (f', g') \circ (f, g) = (f' \circ f, g' \circ g ) $$
of the product category is fulfilled
Where did you go wrong ?
You defined, with my notation, $\overline{G}$ and $\overline{H}$ and constructed $\overline{G} \times \overline{H}$,
but you did not show that this is equal to the product $G \times H$ viewed as a category.
So, you have to define $G \times H$ viewed as a category, i.e., $\overline{G \times H}$ and show that this corresponds to
$\overline{G} \times \overline{H}$.
So, you also have to prove that $\overline{G \times H} \cong \overline{G} \times \overline{H}$
So, you also have to prove that $\overline{G \times H} \cong \overline{G} \times \overline{H}$[/QUO
Thanks for the above post Steenis ...Thinking through your post and reflecting on what you have said ...
I will, indeed must, think about this some more in the morning ...
Thanks again...
Peter
Thanks again...
Peter
Hi steenis ...
I set out merely to translate Awodey's definition of the product of two categories into the case for two groups G, H ... and I think I did that correctly ...
But I did go too far when I stated ...
" ... ... Thus ... for groups \(\displaystyle G\) and \(\displaystyle H\) the product category \(\displaystyle G \times H\) is the usual external direct product for groups ... "
I did not show this! For this I need to follow your advice and as you said ...
" ... ... define $G \times H$ viewed as a category, i.e., $\overline{G \times H}$ and show that this corresponds to
$\overline{G} \times \overline{H}$."
That is ... " ... prove that $\overline{G \times H} \cong \overline{G} \times \overline{H}$ ... "
Thanks for the advice and help ...
Peter
No, you did not go to far, You defined the product category of the groups $G$ and $H$, viewed as categories, and you did that correctly.
After that it has to be shown that $\overline{G} \times \overline{H}$ corresponds with $\overline{G \times H}$ because Awodey askes: “The reader familiar with groups will recognize that for groups $G$ and $H$, the product category $G \times H$ is the usual (direct) product of groups.” (viewed as category - steenis)
So, in my view, the correct things to do are:
- define $G$ viewed as a category, my notation $\overline{G}$
- define $H$ viewed as a category, my notation $\overline{H}$
- construct the product category, as defined in post #1, of the categories $\overline{G}$ and $\overline{H}$, that is $\overline{G} \times \overline{H}$
- define $G \times H$ viewed as a category, my notation $\overline{G \times H}$
- and, finally, show that
$$\overline{G \times H} \cong \overline{G} \times \overline{H}$$
Thanks for all your help in this matter Steenis ...
I now understand this example thanks to you
Peter
FAQ: How can the product of two categories help us understand groups?
What is a product of categories?
A product of categories is a mathematical concept that combines two categories into a new category. It is denoted by the symbol "×" and is defined as a category where the objects are pairs of objects from the two original categories, and the morphisms are pairs of morphisms from the two original categories.
How do you define a product of groups?
A product of groups is a mathematical operation that combines two groups into a new group. It is denoted by the symbol "×" and is defined as a group where the elements are pairs of elements from the two original groups, and the operation is defined component-wise using the operations from the original groups.
What is the significance of Awodey Section 1.6 in relation to product of categories?
Awodey Section 1.6 discusses the properties and examples of product of categories. It shows how the product of categories can be used to construct new categories and how it relates to other mathematical concepts such as direct products and pullbacks.
Can you provide an example of a product of categories?
One example of a product of categories is the product category of sets. This is the category where the objects are pairs of sets and the morphisms are pairs of functions between the sets. Another example is the product category of groups, where the objects are pairs of groups and the morphisms are pairs of group homomorphisms.
How is a product of categories different from a direct product?
A product of categories is a concept in category theory, while a direct product is a concept in group theory. While both involve combining two mathematical structures, a product of categories is defined as a new category, while a direct product is defined as a new group. Additionally, the operations and properties of these two concepts differ due to the different structures they are defined on.
