How can we add a node in a tree?
  • MHB
  • Thread starter evinda
  • Tags
    Tree
In summary: Finally attach e as either the left child or right child of p.Just to make certain that I understand your question:In summary, you would add a node to a binary tree by first finding the leftmost node at a specific level, and then attaching the node to that leftmost node.
  • #36
I like Serena said:
We can assume the node will be a struct with a key.
I would also assume that the left and right child have been initialized to NULL. (Nerd)
So, do we have to do it with this command: [m] node->left->key=e [/m] ? (Thinking)
I like Serena said:
Yes. We have to ensure the algorithm can also handle that. (Wink)
How could we do this? (Thinking)
Technology news on Phys.org
  • #37
No. (Shake)
When we want to add the node with key $e$ as a left child of [m]node[/m], at that point in time [m]node->left[/m] will be equal to NULL.
If we try to access [m]node->left->key[/m] in any way, we will be redirected to chaos and madness. (Devil)
What will happen now if level $l$ does not exist? (Wondering)
  • #38
I like Serena said:
No. (Shake)
So, should it be [m] node->left=e [/m] ? (Thinking)
Do we have to add maybe the command of the line 11? Or am I wrong? (Worried)
Code:
1.depth=0
2.Add_node_leftmost_at_least_at_level(node, l, e)
3.  if node == NULL
4.    return failure
5.  if depth >= l and node->left == NULL
6.    node->left = e
7.    return success
8.  else if depth >= l and node->right == NULL
9.    node->right = e
10.    return success
   else
11.[B] if (node->left==NULL and node->right==NULL and depth<l) return failure;[/B]
12.  depth=depth+1
13.  result = Add_node_leftmost_at_least_at_level(node->left, l, e)
14.  if result is failure
15.    result = Add_node_leftmost_at_least_at_level(node->right, l, e)
16.  depth=depth-1
17.  return result
  • #39
Let's stick with that yes. (Nod)
For the purpose of our algorithm, we will require that the parameter $e$ is a node with whatever key, that has both a left and a right child of NULL.
We should state this as a precondition of the algorithm. (Mmm)
That won't be necessary.
If we leave line 11 out, the algorithm will make a recursive call, and in line 3 it will be detected that we can't get to level $l$, so the algorithm will fail in line 4.
The behavior will be the same with or without line 11. (Nerd)
  • #40
So what can we do elsewhise for the case that there are no more nodes in level $l$? I haven't understood it... (Sweating)
  • #41
I believe there is nothing else to do.
As it is now, the algorithm will already return a failure. (Thinking)
But don't take my word for it!
What if you program the algorithm in C and apply it to a tree that has no level $l$? (Wondering)
