How can we approach a seemingly senseless binomial expansion problem?
In summary, the conversation discusses a problem involving the evaluation of a variable and an attempt to solve it using comparison and a method involving the golden ratio. Rounding errors in calculations are discovered and the final solution is determined to be $ap=1$. The conversation also touches on the significance of the golden ratio in the problem.
anemone
MHB
POTW Director
3,883
115
Hi MHB,
I've come across this problem and I think I've observed a pattern when I tried to solve it by using the method of comparison with some lower values of the exponents, but then I just couldn't deduce the answer to the problem because the pattern suggests that I can't. Here is the problem along with my attempt and my question is, am I approaching the problem incorrectly and also, I am wondering what's the point of asking this type of seemingly "senseless" problem under a challenging problems section? (Yes, I found this problem in the challenging problems from a site whose name I don't even recall.)
Problem:
If \(\displaystyle a=(\sqrt{5}+2)^{101}=b+p\), where $b$ is an integer, $0<p<1$, evaluate $ap$.
Attempt:
Let \(\displaystyle a=(\sqrt{5}+2)^n=b+p\)
$n$\(\displaystyle a=(\sqrt{5}+2)^n=b+p\)$ap$
1$(\sqrt{5}+2)^1$1.414213562
3$(\sqrt{5}+2)^3$0.9999999999999999999999999999999999999999999999999762
5$(\sqrt{5}+2)^5$0.9999999999999999999999999999999999999999999999373888
7$(\sqrt{5}+2)^7$0.9999999999999999999999999999999999999999999929280362
9$(\sqrt{5}+2)^9$0.9999999999999999999999999999999999999999956716794758
11$(\sqrt{5}+2)^{11}$0.9999999999999999999999999999999999886821525305828144
I noticed that the value of $ap$ deceases at a very small rate and it just is unsafe to say at this point that the value $ap$ that we're looking for in the expansion \(\displaystyle a=(\sqrt{5}+2)^{101}=b+p\) approaches 1. What do you think?
Mathematics news on Phys.org
Hey anemone! :)
It appears you've made a mistake for n=1:
$$(\sqrt 5 + 2)\{(\sqrt 5 + 2)\} = (\sqrt 5 + 2)(\sqrt 5 - 2) = 1$$
As for your other results, I'd say they are simply 1 instead of 0.9999...
The difference is caused by rounding errors in your calculator.
It appears that for higher powers the $\sqrt 5$ is canceled.
For n=3 we get:
$$(\sqrt 5 + 2)^3\{(\sqrt 5 + 2)^3\} = (17\sqrt 5 + 38)(17\sqrt 5 - 38) = 17^2\cdot 5 - 38^2 = 1$$
What strikes me is the resemblance to the golden ratio number.
$$\varphi = \frac {1+\sqrt 5} {2}$$
$$2+\sqrt 5 = 2\varphi + 1$$
If we take
a=(√5+2)^101
and b = (√5-2)^101
and expand both we see that the terms with odd power of (√5) shall be same in both and they shall be positive
so a-b =(√5+2)^101 - (√5-2)^101 is integer
now as (√5-2) < 1 so fractional part of (√5+2)^101 is (√5-2)^101 = p
so ap = (√5+2)^101 * (√5-2)^101 = (5-4) ^ 101 = 1
I like Serena said:
Hey anemone! :)
For n=3 we get:
Thanks for your reply, I like Serena!:)
Oops...you're so right.:eek: All those values are calculated wrongly as there are rounding errors in the calculations and now I re-do the case for which $n=3$, yes, I get $ap=1$ for that particular case.
Thank you again for spotting my error and hey, now that you mentioned about the golden ratio number, I can tell maybe this is where they got the idea to set this problem up.:)
Hi,
Thank you for sharing your observations and attempt at solving this problem. Binomial expansions can often be tricky and require a lot of careful observation and analysis to arrive at the correct solution.
First, I would like to clarify that the purpose of asking seemingly "senseless" problems under a challenging problems section is to challenge your critical thinking skills and to push you to think outside the box. These types of problems may not have any practical application, but they help to strengthen your problem-solving abilities.
Now, let's address your approach to the problem. It seems like you are on the right track by looking for patterns in the expansion. However, instead of looking at lower values of the exponent, try looking at the higher values. For example, what happens when n=101? Can you see any patterns in the expansion? Also, keep in mind that the value of p can vary depending on the value of b. So, instead of trying to find a specific value for p, try to find a range of possible values.
I hope this helps. Keep exploring and trying different approaches, and you will eventually arrive at the correct answer. Remember, as a scientist, it is important to be persistent and open-minded when faced with challenging problems. Good luck!
FAQ: How can we approach a seemingly senseless binomial expansion problem?
What is a binomial expansion problem?
A binomial expansion problem involves expanding a binomial expression, which is an algebraic expression with two terms, to a certain power. For example, (x+y)^3 is a binomial expansion problem.
How do I expand a binomial expression?
To expand a binomial expression, you can use the binomial theorem or the Pascal's triangle. The binomial theorem is a formula that allows you to directly expand any binomial expression to a certain power, while the Pascal's triangle is a visual tool that helps you find the coefficients of the expanded expression.
What are the coefficients in a binomial expansion?
The coefficients in a binomial expansion represent the numerical values that are multiplied to each term in the expanded expression. These coefficients can be found by using the binomial theorem or by using the corresponding row in Pascal's triangle.
How do I know when to stop expanding a binomial expression?
You can stop expanding a binomial expression when you have reached the desired power, or when the exponents of the terms in the expanded expression add up to the power. For example, if you want to expand (x+y)^5, you can stop after finding the terms with x^5, x^4y, x^3y^2, x^2y^3, xy^4, and y^5.
What are some real-life applications of binomial expansion?
Binomial expansion has many practical applications in fields such as statistics, economics, and physics. For example, it can be used to calculate probabilities in genetics, to model population growth, and to approximate solutions in physics equations. It is a useful tool in many scientific and mathematical calculations.
