How can we factor $\displaystyle x^4 + 1$ into the difference of two squares?
  • MHB
  • Thread starter paulmdrdo1
  • Tags
    Factoring
But if we have x^4+1 , we see that $x^4+1 = \left( x^2 + 1 \right) ^2$ but we can't factor this further . So to make it a complete square we add the term 2x^2 to get $x^4 + 2x^2 + 1 = \left( x^2 + 1 \right) ^2 + 2x^2$ which can be factorized as $\left( x^2 + 1 \right) ^2 - \left( \sqrt{2} \, x \right) ^2$ and then further into the difference of squares.
paulmdrdo1
385
how to force factor this into the difference of two squares.
Mathematics news on Phys.org
Re: brushing up on factoring.
\(\displaystyle x^4+1=x^4+2x^2+1-2x^2\)
or
\(\displaystyle x^4+1=x^4-i^2\)
The rest is for you ;)
I would get this
$\displaystyle \displaystyle \begin{align*} x^4 + 1 &= x^4 + 2x^2 + 1 - 2x^2 \\& = \left( x^2 + 1 \right) ^2 - \left( \sqrt{2} \, x \right) ^2 \\& = \left( x^2 - \sqrt{2}\, x + 1 \right) \left( x^2 + \sqrt{2}\,x + 1 \right) \end{align*}$
but i want to know what's your reasoning by choosing the term 2x^2?
paulmdrdo said:
I would get this
The idea is complete the square , since if we have for example :
\(\displaystyle x^2+1\) our first glance suggests converting it to $x^2+2x+1$ which is a complete square hence factorizing will be possible .
Factoring is an important skill in mathematics that allows us to break down a polynomial into smaller, simpler parts. In this case, we are looking at the polynomial $\displaystyle x^4 + 1$. To factor this into the difference of two squares, we need to first identify the perfect square terms within the polynomial. In this case, we have $\displaystyle x^4$, which is a perfect square because it can be written as $\displaystyle (x^2)^2$.
Next, we need to find the square root of this perfect square term, which is $\displaystyle x^2$. Now, we can rewrite our polynomial as $\displaystyle (x^2)^2 + 1$.
To force factor this into the difference of two squares, we can use the formula $\displaystyle a^2 + b^2 = (a + b)(a - b)$. In this case, our $\displaystyle a$ term is $\displaystyle x^2$ and our $\displaystyle b$ term is 1. So, we can rewrite our polynomial as $\displaystyle (x^2)^2 + 1 = (x^2 + 1)(x^2 - 1)$.
Finally, we can simplify this expression further by factoring $\displaystyle x^2 - 1$ into the difference of two squares. This gives us our final factored form:
$\displaystyle x^4 + 1 = (x^2 + 1)(x + 1)(x - 1)$.
By using the difference of two squares formula, we were able to break down the polynomial into smaller, simpler parts that are easier to work with. This skill is useful in solving equations and understanding the behavior of polynomials.
FAQ: How can we factor $\displaystyle x^4 + 1$ into the difference of two squares?
What is factoring?
Factoring is a mathematical process of breaking down a complex expression into simpler expressions or factors. It is used to solve equations, simplify algebraic expressions, and find the roots of polynomial equations.
Why is factoring important?
Factoring is an essential concept in mathematics as it helps in solving various mathematical problems. It is also a foundational skill for more advanced concepts like solving quadratic equations, finding the GCF and LCM of numbers, and simplifying complex algebraic expressions.
What are the different methods of factoring?
There are several methods of factoring, such as the greatest common factor (GCF) method, the difference of squares method, the trinomial method, and the grouping method. Each method is used for different types of expressions and equations.
How do I know when to use each method of factoring?
The method of factoring to use depends on the type of expression or equation you are dealing with. For example, if the expression has a common factor, you can use the GCF method. If it is a perfect square, you can use the difference of squares method. It is essential to understand the different methods and when to use them to factor effectively.
Can factoring be used in real-life situations?
Yes, factoring can be used in various real-life situations. For instance, it can be used in business to determine the best pricing strategy for a product or service. It can also be used in engineering to find the optimal design for a structure. Additionally, it can be used in cryptography to secure information by factoring large numbers.
9K
10K
