How can we prove $|Cx^2+Bx+A|\le 2$ for the given condition?
  • MHB
  • Thread starter anemone
In summary, the real numbers $A,\,B,\,C$ satisfy the condition such that for $-1\le x\le 1$, the inequality $|Ax^2+Bx+C|\le 1$ holds. Furthermore, $g(x) - g(1) = Cx^2+Bx+A - (C+B+A) = C(x^2-1) + B(x-1)$, so that $\dfrac{g(x) - g(1)}{1-x} = -C(x+1) - B.$ This proves that $g(x)$ can never be greater than $2$.
anemone
MHB
POTW Director
3,883
115
The real numbers $A,\,B,\,C$ satisfy the condition such that for $-1\le x\le 1$, the inequality $|Ax^2+Bx+C|\le 1$ holds.
Prove that $|Cx^2+Bx+A|\le 2$ for the same $x$.
Mathematics news on Phys.org
let :$f(x)=Ax^2+Bx+C,\,\,\,g(x)=Cx^2+Bx+A$
then we have :$-1\leq f(0)=C\leq 1----(1)$
$-1\leq f(1)=A+B+C\leq 1---(2)$
$-1\leq f(-1)=A-B+C\leq 1---(3)$
now $-2<-1\leq g(1)=C+B+A=A+B+C\leq 1<2---(4)$
$-2<-1\leq g(-1)=C-B+A=A-B+C\leq 1<2---(5)$
as for the domain of $A$: to satisfy $|Cx^2+Bx+A|\le 2$
we get: $-2\leq g(0)=A\le 2$
for one case :$f(x)=2x^2-1,\,\,\, g(x)=-x^2+2$
[sp]I'll use Albert's notation $f(x) = Ax^2 + Bx + C$, $g(x) = Cx^2 + Bx + A$. Notice that $g(-1) = f(-1) = A-B+C$ and $g(1) = f(1) = A+B+C$. Therefore $|g(-1)| \leqslant 1$ and $|g(1)| \leqslant 1.$ Also, $C = f(0)$ and so $|C| \leqslant 1$.
Suppose that for some $x$ with $-1< x< 1$, $g(x) >2$. Then $g(x) - g(1) > 2-1 = 1$, so that $\dfrac{g(x) - g(1)}{1-x} > \dfrac1{1-x}.$ Similarly, $g(x) - g(-1) >1$ so that $\dfrac{g(x) - g(-1)}{1+x} > \dfrac1{1+x}.$ Therefore $$\dfrac{g(x) - g(1)}{1-x} + \dfrac{g(x) - g(-1)}{1+x} > \dfrac1{1-x} + \dfrac1{1+x} = \dfrac2{1-x^2} >2.$$
On the other hand, $g(x) - g(1) = Cx^2 + Bx + A - (C+B+A) = C(x^2-1) + B(x-1)$, so that $\dfrac{g(x) - g(1)}{1-x} = -C(x+1) - B.$
Similarly, $g(x) - g(-1) = C(x^2-1) + B(x+1)$, so that $\dfrac{g(x) - g(-1)}{1+x} = C(x-1) + B.$
Therefore $\dfrac{g(x) - g(1)}{1-x} + \dfrac{g(x) - g(-1)}{1+x} = -2C \leqslant 2$ (because $|C|\leqslant 1).$ That contradicts the previous inequality and shows that $g(x)$ can never be greater than $2$.
A similar argument (with most of the signs changed) shows that $g(x)$ can never be less than $-2$. In conclusion, $|g(x)| \leqslant 2$ whenever $-1\leqslant x\leqslant 1.$
Albert's example $f(x) = 2x^2-1$ shows that $|g(x)|$ can attain the value $2$, so $2$ is the best possible constant in this result.
The basic idea in the above proof is that the constant $C$ controls the curvature of the function $g$. Since $|C|\leqslant 1$, the curve cannot bend too quickly. If $g(x)$ takes a value $\leqslant 1$ when $x=-1$, then increases to a value greater than $2$ (at some point $x$) then it cannot bend round sharply enough to get back down to a value $\leqslant 1$ by the time that $x=1$.[/sp]
another proof for $-2\leq A\leq 2$
$-1\leq A+B+C\leq 1---(1)$
$-1\leq A-B+C\leq 1---(2)$
$-1\leq C\leq 1---(3)$
$(1)+(2)$ we have :
$-1\leq A+C\leq 1---(4)$
fom $(3),(4)$
$A-1\leq A+C\leq 1, \rightarrow A\leq 2$
$-1\leq A+C\leq A+1,\rightarrow -2\leq A$
Thank you Albert and Opalg for participating in this challenge problem!
Another solution of other that I wish to share with MHB:
Using also Albert's notation, we have
$|A+B+C|=|f(1)|\le 1$, $|A-B+C|=|f(-1)|\le 1$ and $|C|=|f(0)|<1$
Hence,
$\begin{align*}|g(x)|&=\left|C\cdot(x^2-1)+(A+B+C)\cdot\left(\dfrac{1+x}{2}\right)+(A-B+C)\cdot\left(\dfrac{1-x}{2}\right)\right|\\&\le |x^2-1|+\dfrac{|1+x|}{2}+\dfrac{|1-x|}{2}\\&=1-x^2+\dfrac{1+x}{2}+\dfrac{1-x}{2}\\&=2-x^2\\&\le 2\end{align*}$
for $-1\le x\le 1$, and we're done.
FAQ: How can we prove $|Cx^2+Bx+A|\le 2$ for the given condition?
What does the expression |Cx²+Bx+A|≤ 2 mean?
The expression |Cx²+Bx+A|≤ 2 is a mathematical inequality, where C, B, and A are constants and x is a variable. It means that the absolute value of the quadratic function Cx²+Bx+A is less than or equal to 2.
How do I solve this inequality?
To solve this inequality, you can use various methods such as factoring, completing the square, or the quadratic formula. You can also graph the quadratic function and determine the values of x that satisfy the inequality.
What are the possible values of x that satisfy this inequality?
The possible values of x that satisfy the inequality |Cx²+Bx+A|≤ 2 depend on the specific values of C, B, and A. Generally, there will be two values of x that satisfy the inequality, unless the parabola only touches the horizontal line y=2 at one point, in which case there will be only one value of x.
Can I use this inequality to prove something?
Yes, you can use this inequality to prove various mathematical statements. For example, you can use it to prove that a certain function is bounded, or to show that a given range of values satisfies a specific condition.
Are there any real-life applications of this inequality?
Yes, this inequality has various real-life applications. It can be used in physics and engineering to determine the maximum or minimum values of certain quantities. It can also be used in economics and finance to analyze data and make predictions.
