How Can We Prove This Positive Real Number Inequality?
In summary, we can prove that for positive real numbers $a$ and $b$, the expression $(a+1/b+1)^(b+1)$ is greater than or equal to $(a/b)^(b)$ by using the critical point method and the property of global minimum. Another method is to simplify the expression and use the fact that $1 \le 1$ to prove it for the case where $b < a$.
poissonspot
40
Prove that for positive real numbers a,b (a+1/b+1)^(b+1) is greater than or equal to (a/b)^(b).
The case in which a<b is easy to prove, but after trying to represent the inequality with an integral, I'm a bit stumped.
Any ideas?
Let $b$ be a fixed positive number. Define the following function for $x>0$:
$$ f(x) = \frac{(x+1)^{b+1}}{x^b} $$
Let us find the critical points of $f$ (the points where the derivative is zero). By the quotient rule the numerator of the derivative is equal to (we will ignore the denominator, as you will see why):
$$ \left[ (x+1)^{b+1} \right]' x^b - (x+1)^{b+1} \left[ x^b \right]' $$
This becomes,
$$ (b+1)(x+1)^b x^b - b(x+1)^{b+1}x^{b-1} $$
This is the numerator for $f'(x)$. To find the critical points of $f$ we just need to set the numerator equal to zero:
$$ (b+1)(x+1)^b x^b - b(x+1)^{b+1}x^{b-1} = 0$$
Divide both sides by $(x+1)^bx^{b-1}$ to end up with:
$$ (b+1)x - b(x+1) = 0 \implies bx + x - bx - b = 0 \implies x = b$$
Therefore, as $b$ is the critical point it means $f$ is either increasing or decreasing on the interval $(0,b)$ and that it is either increasing or decreasing on the interval $(b,\infty)$. Note that,
$$ \lim_{x\to 0^+} f(x) = \lim_{x\to 0^+} \frac{(x+1)^{b+1}}{x^b} = \infty $$
This means that $f$ must be decreasing on $(0,b)$.
Also note that,
$$ \lim_{x\to \infty} f(x) = \lim_{x\to \infty} \frac{(x+1)^{b+1}}{x^b} = \infty $$
Therefore, $f$ must be increasing on $(b,\infty)$.
This means that the point $b$ is a global minimum point for $f$. Thus, we have that $f(x) \geq f(b)$ for any point $x$. Now choose $x=a$ where $a$ is any positive number and we get that,
$$ f(a) \geq f(b) \implies \frac{(a+1)^{b+1}}{a^b} \geq \frac{(b+1)^{b+1}}{b^b} \implies \frac{(a+1)^{b+1}}{(b+1)^{b+1}} \geq \frac{a^b}{b^b} \implies \left( \frac{a+1}{b+1} \right)^{b+1} \geq \left( \frac{a}{b} \right)^b $$
Here's another way. You've already said that
$\left(\dfrac{a}{b}\right)^b \le \left( \dfrac{a+1}{b+1}\right)^{b+1}$ for $a < b$ is easy to prove - right?
if $a = b$, this is also easy since $1 \le 1$. Here's the case where $b < a$. Set $a \to \dfrac{1}{a}$ and $b \to \dfrac{1}{b}$
so $\left( \dfrac{\dfrac{1}{a}}{\dfrac{1}{b}}\right)^{\dfrac{1}{b}} \le \left(\dfrac{\dfrac{1}{a}+1}{\dfrac{1}{b}+1} \right) ^{\dfrac{1}{b}+1}$ if $\dfrac{1}{a} < \dfrac{1}{b}$
Now we simplify
$ \left(\dfrac{b}{a}\right)^{\dfrac{1}{b}} \le \left(\dfrac{b}{a}\right)^{\dfrac{1}{b}+1} \left(\dfrac{a+1}{b+1}\right)^{\dfrac{1}{b}+1}$
cancel some
$ 1 \le \dfrac{b}{a} \left(\dfrac{a+1}{b+1}\right)^{\dfrac{b+1}{b}}$ or $ \dfrac{a}{b} \le \left(\dfrac{a+1}{b+1}\right)^{\dfrac{b+1}{b}}$
Now exponenate each side giving
$ \left(\dfrac{a}{b}\right)^b \le \left(\dfrac{a+1}{b+1}\right)^{b+1}$ for $b < a$
FAQ: How Can We Prove This Positive Real Number Inequality?
What is a positive real number?
A positive real number is any number that is greater than zero and can be expressed as a decimal or fraction. Examples include 1, 2.5, 3/4, and 0.333.
What is an inequality?
An inequality is a mathematical expression that compares two quantities, showing that one quantity is greater than or less than the other. It is denoted by symbols such as <, >, ≤, and ≥.
How do you solve a positive real number inequality?
To solve a positive real number inequality, you can use the same methods as solving regular equations, such as combining like terms and isolating the variable. However, you must also pay attention to the direction of the inequality symbol and make sure to flip it if necessary when you multiply or divide by a negative number.
What is the difference between a positive real number inequality and an equation?
The main difference between a positive real number inequality and an equation is that an inequality indicates a range of possible solutions, while an equation only has one specific solution. In an inequality, the solution may include all values greater than or less than a certain number, while an equation has only one specific value as the solution.
Why are positive real number inequalities important in science?
Positive real number inequalities are important in science because they allow us to express relationships between quantities and describe ranges of values that are possible for a given situation. In science, we often use inequalities to represent physical laws and constraints, and solving these inequalities can help us make predictions and analyze data.
