MHB How can we show that one of these congruences hold?
  • Thread starter Thread starter mathmari
The discussion focuses on proving that for all integers squared, the results modulo 8 yield specific congruences: 0, 1, or 4. The set M is defined as the squares of integers, and examples are provided to illustrate the congruences. Participants analyze the periodicity of the remainders when squaring integers, noting a repeating pattern every four integers. The proof is structured by considering even and odd integers separately, demonstrating that the squares of both types yield the required congruences. The conversation emphasizes the mathematical reasoning behind these findings.
mathmari
MHB
Hey! :o
We define the set $M:=\{x^2\mid x\in\mathbb{Z}\}$.
  1. Give 8 different elements of M.
  2. Give for each element of question 1, m, two numbers $q\in \mathbb{Z}, r\in \{0,1,\ldots , 7\}$ such that $m=8q+r$.
  3. Show that for all $x\in M$ one of the following holds:
    $x\overset{(8)}{\equiv}0$, $x\overset{(8)}{\equiv}1$, $x\overset{(8)}{\equiv}4$
I have done the following:
  1. We have $1^2=1, 2^2=4, 3^2=9, 4^2=16, 5^2=25, 6^2=36, 7^2=49, 8^2=64$.
  2. $1=8\cdot 0+1, 4=8\cdot 0+4, 9=8\cdot 1+1, 16=8\cdot 2+0, 25=8\cdot 3+1, 36=8\cdot 4+4, 49=8\cdot 6+1, 64=8\cdot 8+0$
  3. How can we show that? (Wondering)
Mathematics news on Phys.org
3. Show that for all $x\in M$ one of the following holds: $x\overset{(8)}{\equiv}0$, $x\overset{(8)}{\equiv}1$, $x\overset{(8)}{\equiv}4$
Hey mathmari!
If $x\in M$, then there must be a $y\in\mathbb Z$ such that $x=y^2$ yes? (Thinking)
In question 2 we can see there seems to be a repeating pattern, don't we?
The remainers modulo 8 for consecutive values of $y$ are 1,4,1,0,1,4,1,0 after all.
That seem to be periodic with period 4, doesn't it?
Suppose we write $y=4k+r$ for some integer $k$ and $r\in\{0,1,2,3\}$.
What will be the possibilities for $y^2\pmod 8$? (Wondering)
Why do we take the y in this form? Because it is periodic of period 4? (Wondering)
The square is as follows:
$$y^2\mod 8\equiv 16k^2+8kr+r^2\mod 8\equiv r^2$$
The possible values of $r^2$ are $0,1,4,9=1$.
Yep. (Nod)
It seems to be periodic with period 4, so we try to prove that it is indeed the case. And additionally what the possible remainders are.
So? (Wondering)
mathmari said:
Hey! :o
Look at your answers to (2)! Each has 8 times some number plus 1, 4, 1, 0, 1, 4, 1, 0.
Tedious- we need to look at four "cases".
Every number in Z is either even or odd.
1) Suppose n is even. Then n= 2m for some integer m so n^2= 4m^2.
m is either even or odd
1a)Suppose m is even. Then m= 2k and n^2= 4(4k^2)= 8(2k^2) and n^2 is congruent to 0 mod 8.
1b)Suppose m is odd. Then m= 2k+ 1 and n^2= 4(2k+1)^2= 4(4k^2+ 4k+ 1)= 8(2k^2+ 2k)+ 4 and n^2 is congruent to 4 mod 8.
2) Suppose n is odd. Then n= 2m+ 1 for some integer m so n^2= 4m^2+ 4m+ 1= 4(m^2+ m)+ 1.
2a) Suppose m is even. Then m= 2k so n^2= 4(4k^2+ 2k)+ 1= 8(2k^2+ k)+ 1 and n^2 is congruent to 1 mod 8.
2b) Suppose m is odd. Then m= 2k+ 1 so n^2= 4(4k^2+ 4k+ 1+2k+ 1)+ 1= 4(4k^2+ 6k+ 2)+ 1= 8(2k^2+ 3k+ 1)+ 1 and n^2 is congruent to 1 mod 8.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
