How Can We Solve for 'a' and 'b' in This Simultaneous Equation?
  • MHB
  • Thread starter anemone
In summary, the simultaneous equation is solved to find the values of $a$ and $b$. The equations are $\dfrac{a+b}{a+\sqrt{1+a^2}}+b^2=0$ and $\dfrac{a^2}{b^2}+2\sqrt{1+a^2}+b^2=3$. Through various manipulations, it is determined that $a=0$ and $b=-1$ or $b=-1.6$. However, the final equation, $f(b)=0$, cannot be solved for an exact solution.
anemone
MHB
POTW Director
3,883
115
Solve the simultaneous equation and find the values of $a$ and $b$.
Mathematics news on Phys.org
By inspection, $a=0, b=-1$ solves the system. There may be other solutions.
Thanks for participating, Ackbach!:)
Ahem... I can only give you at most half credit because your answer isn't complete!(Wondering):p
My solution:
We're given
$\dfrac{a+b}{a+\sqrt{1+a^2}}+b^2=0$$\dfrac{a^2}{b^2}+2\sqrt{1+a^2}+b^2=3$
If we let $f(a)=a+\sqrt{1+a^2}$, we see thatObserve that
1. $f(a) \ne 0$,
2. $f(a) > 0$ for all $a$ since
$\;\;\;\;$when $a \rightarrow \ -\infty$, $f(a) \rightarrow 0$
$\;\;\;\;$when $a \rightarrow \infty$, $f(a) \rightarrow \infty$
$\sqrt{1+a^2} \ge 1$ for all $a$ and hence we have $2\sqrt{1+a^2} \ge 2$.
Thus, $\dfrac{a^2}{b^2}+2\sqrt{1+a^2}+b^2=3$ is true when the following inequality holds.
$\dfrac{a^2}{b^2}+b^2 \le 1$
$a^2+b^4 \le b^2$
$b^4 \le b^2-a^2$
$b^4 \le (a+b)(b-a)$
Thus, $\dfrac{a+b}{a+\sqrt{1+a^2}}+b^2=0$ is feasible iff $a+b<0$---(*).Since $b^4 \ge 0$, and $a+b<0$(from *), we know $b-a<0$---(**).
These two inequalities (*) and (**) suggest that $b<0$.
Now, if we let
$k=a+\sqrt{1+a^2}=f(a)>0$, $\rightarrow a=\dfrac{k^2-1}{2k}$
and substitute these two into the equation $\dfrac{a+b}{a+\sqrt{1+a^2}}+b^2=0$, we get
$\dfrac{\dfrac{k^2-1}{2k}+b}{k}+b^2=0$
$\dfrac{\dfrac{k^2-1+2bk}{2k}}{k}+b^2=0$
$\dfrac{k^2-1+2bk}{2k^2}+b^2=0$
$k^2-1+2bk+2k^2b^2=0$
$(1+2b^2)k^2-(2b)k-1=0$
Solving it for $k$ by the quadratic formula, we obtain
$k=\dfrac{b\pm \sqrt{3b^2+1}}{1+2b^2}$
Since $k>0$, and $b<0$, we can say at this point that $k=\dfrac{b+ \sqrt{3b^2+1}}{1+2b^2}$, which in turn tells us we have only one value of $x$ as the answer.
Now, the only answer to this problem, like Ackbach has mentioned is $(x,y)=(0, -1)$.
$\dfrac{a+b}{a+\sqrt{1+a^2}}+b^2=0---(1)$
$\dfrac{a^2}{b^2}+2\sqrt{1+a^2}+b^2=3---(2)$
from (2) $b\neq 0$
from (1) it is easy to see a+b<0
from (2)$\dfrac{a^2}{b^2}+2\sqrt{1+a^2}+b^2=3>\dfrac{a^2}{b^2}+2\sqrt{a^2}+b^2>3\times \left |a \right |\sqrt[3]{2}$(AP>GP)
$\therefore 1>\left | a \right |\sqrt[3]{2}$
if $a\in Z$ then a=0 and from (1)b=-1
from (2) $b\neq 0$
from (2)$\dfrac{a^2}{b^2}+2\sqrt{1+a^2}+b^2=3>\dfrac{a^2}{b^2}+2\sqrt{a^2}+b^2>3\times (\pm) a\sqrt[3]{2}$(AP>GP)
$\therefore 1>(\pm a)\sqrt[3]{2}$
Hi Albert,
Thanks for showing me another method to solve this problem and thanks too for participating. But I don't understand why there is a plus minus sign in front of the cube root of 2, after one applied the AM-GM to the terms $\dfrac{a^2}{b^2}, 2\sqrt{a^2}, b^2$:
$\dfrac{a^2}{b^2}+2\sqrt{a^2}+b^2>3(\pm \sqrt[3]{2})$
I see that even if $1>\pm\sqrt[3]{2}(a)$ is true, the solution set for $a$ that I can get from here is $-\dfrac{1}{\sqrt[3]{2}}<a<\dfrac{1}{\sqrt[3]{2}}$, but not what you have concluded...:eek: I'm sure I am missing something here, and I hope you will enlighten me.
from (2) $b\neq 0$
we get a=0 and from (1)b=-1
we get a=0 (if a is an integer),and from (1) b=-1
if a is not an integer ----(please wait )
[sp]This is a follow-up to anemone's solution above. She shows that $b<0$, and also that $a^2+b^4 \leqslant b^2$, from which $a^2 \leqslant b^2(1-b^2).$ It follows that $|a| < |b|$ and also that $|b| \leqslant 1.$ Therefore $-1\leqslant b<0.$
Multiplying out the fractions, we can write the original equations as $$1+b + ab^2 + b^2c = 0, \qquad(1)$$ $$a^2 + 2b^2c + b^4 - 3b^2 = 0, \qquad (2)$$ where $c = \sqrt{1+a^2}$. Multiply (1) by $2$ and subtract (2) (to eliminate $c$): $$2a + 2b + 2ab^2 - a^2 - b^4 + 3b^2 = 0.$$ Write that as a quadratic in $a$ and solve it: $$a^2 - 2(1+b^2)a + (b^4 - 3b^2 - 2b) = 0,\qquad a = 1 + b^2 - \sqrt{5b^2 + 2b + 1} \qquad (3)$$ (we have to take the negative square root in (3) because $|a| < |b|$).
Using the definition of $c$, write (2) as $(c^2 - 1) + 2b^2c + b^4 - 3b^2 = 0$. Write that as a quadratic in $c$ and solve it: $$c^2 + 2cb^2 + (b^4 - 3b^2 - 1) = 0, \qquad c = -b^2 + \sqrt{3b^2+1} \qquad (4)$$ (this time, we have to take the positive square root because $c\geqslant 1$).
Now substitute (4) into (1) and solve for $a$: $$a+b + ab^2 + b^2\bigl(-b^2 + \sqrt{3b^2+1}\bigr), \qquad a = \frac{b^4 - b^2\sqrt{3b^2+1} - b}{1+b^2}. \qquad(5)$$
The next step is to equate the two expressions for $a$ ((3) and (5)), which gives an equation for $b$. After a small amount of simplification, this becomes: $$f(b) \overset{\text{def}}{=} 1+ b + 2b^2 + b^2\sqrt{3b^2+1} - (1+b^2) \sqrt{5b^2 + 2b + 1} = 0.$$
I don't see any hope of solving that equation, but a plot of the graph of $f(b)$ shows that its only zero in the interval $-1\leqslant b<0$ is when $b=-1$ (click on View attachment 1690 to see the printout).[/sp]
  • graph.pdf
Thank you Opalg for participating and showing us another way to tackle the problem.
After reading your post, I realized I have provided a false solution. My apologies.
I will stand in the corner with my nose against the wall for making the silly assumption as follows: (Angry)
In $k=\dfrac{b\pm \sqrt{3b^2+1}}{1+2b^2}$, since $k>0$, and $b<0$, we can say at this point that $k=\dfrac{b+ \sqrt{3b^2+1}}{1+2b^2}$, which in turn tells us we have only one value of $x$ as the answer".
$\dfrac{a+b}{a+\sqrt{1+a^2}}+b^2=0$---(1)
from (1) a+b<0
from (2) $a^2<b^2,\therefore b<a,\,\, (a-b)>0$
$\therefore b<0$
the range of a : -1<a<1---(3)
the range of b:$-1\leq b<0$---(4)
let $\sqrt {1+a^2}=1+x(x\geq 0)$
we get $a^2=x^2+2x$
from (2) $\dfrac {x^2+2x}{b^2}+2+2x+b^2=3$
$\dfrac {x^2+2x+2b^2x+b^4}{b^2}=1=\dfrac{b^2}{b^2}$
$(x^2+2x)+b^2(b^2+2x)=b^2$
compare both side we have:
$(x^2+2x)=0 ,\,\, and (b^2+2x)=1$
x=0 or x=-2 (deleted)
so we get a=0 and b=-1 or (b=1 also deleted)
$\therefore$ (a,b)=(0,-1) is the only solution
Albert said:
from (1) a+b<0
$\therefore b<0$
we get $a^2=x^2+2x$
this statement is not correct. This is correct if it is true for any b and not a particular b.
please note the range of a,and b
in fact b=$\pm 1,\,\, and\,\, b=\pm \sqrt 5$
but b=1, and b=$\pm \sqrt 5$ must be deleted
Albert said:
from (1) a+b<0
$\therefore b<0$
we get $a^2=x^2+2x$
Very nice solution. I would prefer to simplify the final part of it by writing $x^2+2x+2b^2x+b^4 = b^2$ as $(x+b^2)^2 + 2x = b^2$. Since $x\geqslant0$, the left side is clearly greater than the right unless $x=0$.
That proof relies entirely on information from the second of the two given equations; the first one is not needed at all!
some how I am missing the clearly greater than the right part.
if b^2 < 1 then b^4 < b^2 in that case x could be positive. I can neither prove it nor disprove it.
any help in this regards
You are quite right – I was confusing $b^2$ with $b^4$ at some point, and my "simplification" does not work. (Doh)
FAQ: How Can We Solve for 'a' and 'b' in This Simultaneous Equation?
What does "a" and "b" represent in the equation "Solve for a and b"?
In this equation, "a" and "b" represent variables that need to be solved for in order to find the solution to the problem.
How do I solve for "a" and "b" in an equation?
To solve for "a" and "b", you need to isolate them on one side of the equation by using algebraic operations such as addition, subtraction, multiplication, and division.
Can "a" and "b" have multiple solutions?
Yes, depending on the equation and the given constraints, "a" and "b" can have multiple solutions. This is especially true for systems of equations where there are multiple variables involved.
What if "a" or "b" are already given in the equation?
If "a" or "b" are already given in the equation, you can use substitution to solve for the other variable. Simply substitute the given value in place of the variable and solve for the remaining variable.
Are there any special rules or techniques for solving for "a" and "b"?
There are various techniques for solving equations with multiple variables, such as elimination, substitution, and graphing. It is important to understand the properties of algebra and follow the correct steps to solve for "a" and "b" accurately.
