MHB How can we solve the differential equation $y^\prime - 2y = x^2 e^{-2x}$?
  • Thread starter Thread starter karush
The discussion revolves around solving the differential equation y' - 2y = x^2 e^(-2x) using an integrating factor, u(x) = e^(-2x). After multiplying through by the integrating factor, participants clarify the left-hand side as the derivative of a product, leading to the equation e^(-2x)y = ∫x^2 e^(-4x) dx. Integration by parts (IBP) is suggested for the right-hand side, resulting in an expression for y that includes an arbitrary constant and a term involving e^(-2x). There is confusion regarding the correctness of the book's answer, prompting a reevaluation of the original ODE.
karush
MHB
ok going to try the next de!
$$\displaystyle y^\prime - 2y = x^2 e^{-2x}$$
I would assume that first
$$u(x) = e^{-2x}$$
book answer is:
$$y=\color{red}{\displaystyle ce^{2x}+\frac{x^3}{3}e^{2x}}$$
You've correctly computed the integrating factor, so what does the ODE become after you multiply though by this integrating factor?
karush said:
I think we just multiply every term
$$\displaystyle (e^{-2x})y^\prime - 2(e^{-2x})y = x^2 e^{-2x}(e^{-2x})$$
if so the next would be to simplify
Yes, rewrite the LHS as the derivative of a product, and simplify the RHS. :)
karush said:
$$\frac{d}{dx}\left(e^{-2x}2y\right)=e^x(xe^{2x}+1)$$
really?
No, you would have:
$$\frac{d}{dx}\left(e^{-2x}y\right)=x^2e^{-4x}$$
MarkFL said:
No, you would have:
ok it was a product
what happened to the 2?
presumed next step...
$$\displaystyle y=e^{2x}\int x^2e^{-4x} \, dx + ce^{2x}$$
IBP??
karush said:
ok it was a product
I'm not sure which 2 you're talking about...
$$\displaystyle e^{-2x}y=\int x^2e^{-4x} \, dx$$
IBP??
Yes, IBP for the RHS. :)
Personally, I would integrate first and then solve for $y(x)$. Either way though.
W|A returned this I don't see this heading towards the answer
$$\displaystyle\int x^2 e^{-4x} \, dx = -\frac{1}{32}e^{-4x} (8x^2+4x+1)+c$$
then
$$\displaystyle e^{-2x}y= -\frac{1}{32}e^{-4x} (8x^2+4x+1)+c$$
and
$$\displaystyle y= -\frac{1}{32}e^{-2x}(8x^2+4x+1)+ce^{2x}$$
But ? W|A says
$$y(x)=c_1 e^{2e} -\frac{1}{2} e^{-2e}x^2-\frac{1}{2}e^{-2e}x-\frac{ e^{-2e}}{4}$$
The answer you cited as being given by the book is incorrect. Are you sure the ODE is given correctly?
answer #2
https://www.physicsforums.com/attachments/8206
problem #2
W|A returned this:
$$\displaystyle y(x)=c_1 e^{2e} -\frac{1}{2} e^{-2e} x^2-\frac{1}{2} e^{-2e}x-\frac{ e^{-2e}}{4}$$
