How can we visualise a half period zone inside a zone plate?
In summary, the conversation discussed how to visualize a half period zone inside the blackened portion of a positive zone plate. It was explained that the half period zone is the annular area between the (n-1)th and (n)th circle in a plane wavefront. The zone edges were also defined as ##r_n=\sqrt{n\lambda f+n^2\lambda^2/4}##, with the nth zone being the region between ##r_{n-1}## and ##r_n##. To create a zone plate, one would need to paint the regions between the zone edges black and leave the transparent regions unpainted.
Vipanj
how can we consider/ visualise a half period zone inside blackened portion of +ve zone plate ?
It's just a ring of black paint, basically. What more is there to know?
By definition (n)th half period zone is the annular area between (n-1)th and (n)th circle in a plane wavefront. Then how can a black region in zone plate can have a half period zone ?
I'm not sure I understand what you are trying to say.
The zone edges lie at ##r_n=\sqrt{n\lambda f+n^2\lambda^2/4}##. The ##n##th zone is the region between ##r_{n-1}## and ##r_n##. So to make a zone plate you paint the region between ##r_0## and ##r_1## black, leave the region between ##r_1## and ##r_2## transparent, paint the region between ##r_2## and ##r_3## black, etc.
Related to How can we visualise a half period zone inside a zone plate?
1. How does a zone plate work to create a half period zone?
A zone plate is an optical device that uses diffraction to create a pattern of light and dark zones. The half period zone is created by varying the thickness of the zones in a specific pattern, which causes the light to diffract and create a focused image.
2. What is the purpose of visualising a half period zone inside a zone plate?
The half period zone allows for higher resolution and sharper images to be produced by the zone plate. By visualising the half period zone, we can better understand the diffraction pattern and optimize the design of the zone plate for specific applications.
3. How can we physically create a half period zone inside a zone plate?
The most common method is to use lithography techniques to etch the zone plate pattern onto a substrate, such as glass or silicon. This allows for precise control over the thickness and spacing of the zones, resulting in the creation of a half period zone.
4. Are there any limitations to visualising a half period zone inside a zone plate?
One limitation is the size of the zone plate. As the number of zones increases, the size of the zone plate must also increase to maintain the same level of resolution. Additionally, the materials used for the zone plate must have high precision and uniformity to produce an accurate half period zone.
5. How does the half period zone affect the performance of a zone plate?
The half period zone plays a crucial role in the performance of a zone plate. It allows for higher resolution and better contrast in the resulting image. Additionally, the size and shape of the half period zone can be optimized for specific applications, such as microscopy or spectroscopy.
  • Mechanical Engineering
  • Atomic and Condensed Matter
