How Can You Determine the Values of ab+cd Given These Equations?
  • MHB
  • Thread starter anemone
  • Tags
    2016
In summary, to solve for ab+cd with a system of equations, you must identify the equations that involve both ab and cd, and then use algebraic manipulation and substitution to isolate and solve for these variables. It may also be helpful to graph the equations to visually understand their intersection points. One example of solving for ab+cd is by using the equations 2ab + 3cd = 10 and ab - cd = 5. The significance of solving for ab+cd with a system of equations is that it allows us to find the values of two variables that satisfy both equations simultaneously, which can be useful in real-world applications. Some tips for solving these types of equations include identifying the equations involving the variables, manipulating the equations
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Suppose that 4 real numbers $a,\,b,\,c,\,d$ satisfy the conditions as shown below:
$a^2+b^2=4$
$c^2+d^2=4$
$ac+bd=2$
Evaluate all possible values for $ab+cd$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution::)
1. greg1313
2. kaliprasad
Solution from greg1313:
Let $a=2\cos(x),b=2\sin(x),c=2\cos(y),d=2\sin(y)$ then the first two conditions are satisfied.
For $ac+bd$ we have $4\cos(x)\cos(y)+4\sin(x)\sin(y)=4\cos(x-y)=2$ so we must have $x-y=\pm\dfrac{\pi}{3}+2k\pi,k\in\mathbb Z$
From all of that, $ab+cd=4\cos(x)\sin(x)+4\cos(y)\sin(y)=2(\sin(2x)+\sin(2y))=2(2\sin(x+y)\cos(x-y))=2\sin(x+y)$
Hence $-2\le ab+cd\le2$
FAQ: How Can You Determine the Values of ab+cd Given These Equations?
How do you solve for ab+cd with a system of equations?
To solve for ab+cd with a system of equations, you must first identify the equations that involve both ab and cd. Then, you can use algebraic manipulation and substitution to isolate and solve for these variables. It may also be helpful to graph the equations to visually understand their intersection points.
Can you provide an example of solving for ab+cd with a system of equations?
Sure, let's say we have the equations 2ab + 3cd = 10 and ab - cd = 5. To solve for ab+cd, we can rearrange the second equation to get ab = cd + 5. Then, we can substitute this value into the first equation to get 2(cd+5) + 3cd = 10. Solving for cd, we get cd = 1. Finally, we can plug this value back into the equation ab = cd + 5 to get ab = 6. Therefore, ab+cd = 6 + 1 = 7.
What is the significance of solving for ab+cd with a system of equations?
Solving for ab+cd with a system of equations allows us to find the values of two variables that satisfy both equations simultaneously. This can be useful in real-world applications where two equations represent different relationships, and we need to find the common point of intersection.
Are there any tips for solving these types of equations?
One helpful tip is to start by identifying the equations that involve both ab and cd. Then, try to manipulate the equations to eliminate one of the variables so that you can solve for the other. It may also be useful to graph the equations to visually understand their intersection points.
Can this method be applied to solve for other variables in a system of equations?
Yes, this method can be applied to solve for any combination of variables in a system of equations. The key is to identify which equations involve those variables and use algebraic manipulation and substitution to isolate and solve for them. In some cases, it may be necessary to solve for one variable first and then use that value to solve for the other variable.
