How Can You Effectively Evaluate a Challenging Definite Integral?
In summary, a definite integral is a mathematical concept used to find the total value of a function within a specific range. The "Definite Integral Challenge" is important for practicing and strengthening skills in calculating definite integrals, which can benefit scientific research by providing a tool for data analysis. Some strategies for solving the challenge include breaking the integral into smaller parts and using properties of integrals. This concept can also be applied to real-world problems in various fields.
anemone
MHB
POTW Director
3,883
115
Evaluate \(\displaystyle \int_2^4 \frac{\sqrt{\ln (9-x)}\,dx}{\sqrt{\ln (9-x)}+\sqrt{\ln (x+3)}}\)
Mathematics news on Phys.org
My solution:
We are given to evaluate:
\(\displaystyle I=\int_2^4 \frac{\sqrt{\ln (9-x)}\,dx}{\sqrt{\ln (9-x)}+\sqrt{\ln (x+3)}}\)
Let:
\(\displaystyle u=x-3\,\therefore\,du=dx\)
and we have:
\(\displaystyle I=\int_{-1}^{1}\frac{\sqrt{\ln(6-u)}}{\sqrt{\ln(6-u)}+\sqrt{\ln(6+u)}}\,du\)
Using the property of definite integrals:
\(\displaystyle \int_{-a}^a f(x)\,dx=\int_0^a \left[f(x)+f(-x) \right]\,dx\)
we may write:
\(\displaystyle I=\int_{0}^{1}\frac{\sqrt{\ln(6-u)}}{\sqrt{\ln(6-u)}+\sqrt{\ln(6+u)}}+\frac{\sqrt{\ln(6+u)}}{\sqrt{\ln(6+u)}+\sqrt{\ln(6-u)}}\,du\)
\(\displaystyle I=\int_{0}^{1}\frac{\sqrt{\ln(6-u)}+\sqrt{\ln(6+u)}}{\sqrt{\ln(6-u)}+\sqrt{\ln(6+u)}}\,du\)
\(\displaystyle I=\int_{0}^{1}\,du=_0^1=1-0=1\)
MarkFL said:
My solution:
Let:
and we have:
we may write:
That's a smart approach, MarkFL! Well done!(Clapping)
A little more direct
Let $x = 6-u$ so the integral become
$I = \displaystyle - \int_4^2 \dfrac{\sqrt{\ln (3+u)}}{ \sqrt{\ln (3+u)} +\sqrt{\ln (9-u)}}\;du$
Replace $u$ with $x$ and add to the original and like Mark said $2I = \int_2^4 1dx$ gives $I = 1$
There are a few different approaches one could take to evaluate this definite integral. One possible method is to use the substitution u = ln(9-x), which would result in the integral becoming \int_{ln7}^{ln5} \frac{\sqrt{u}\,du}{\sqrt{u}+\sqrt{ln(12-e^u)}}. From here, one could potentially use integration by parts or another technique to further simplify the integral.
Another approach could be to use a numerical method, such as the trapezoidal rule or Simpson's rule, to approximate the value of the integral. This would involve breaking the interval [2,4] into smaller subintervals and using a formula to calculate the area under the curve on each subinterval.
Ultimately, the method chosen would depend on the specific goals and context of the problem. It may also be helpful to graph the integrand and visually estimate the area under the curve, or to use a computer program or calculator to numerically evaluate the integral.
FAQ: How Can You Effectively Evaluate a Challenging Definite Integral?
What is a definite integral?
A definite integral is a mathematical concept that represents the area under a curve on a graph. It is calculated by finding the limit of a Riemann sum as the width of the intervals approaches zero. In simpler terms, it is a way to find the total value of a function within a specific range.
Why is the "Definite Integral Challenge" important?
The "Definite Integral Challenge" is important because it allows scientists and mathematicians to practice and strengthen their skills in calculating definite integrals. It also helps them develop problem-solving strategies and improve their understanding of the concept.
How does the "Definite Integral Challenge" benefit my scientific research?
The "Definite Integral Challenge" can benefit your scientific research by providing a tool for analyzing and interpreting data. Many scientific experiments involve measuring and graphing data, and definite integrals can be used to find the total value of a function that represents the data. This can help you draw conclusions and make predictions about your research.
What are some strategies for solving the "Definite Integral Challenge"?
Some strategies for solving the "Definite Integral Challenge" include breaking the integral into smaller, simpler parts, using properties of integrals such as linearity and the fundamental theorem of calculus, and using substitution or integration by parts to simplify the integral.
Can the "Definite Integral Challenge" be applied to real-world problems?
Yes, the "Definite Integral Challenge" can be applied to real-world problems. Many real-world scenarios involve finding the total value of a function within a specific range, such as calculating the area under a curve on a velocity vs. time graph to find the displacement of an object. Definite integrals can also be used in economics, physics, and other fields to model and analyze data.
