How Can You Evaluate a Tricky Integral of Sin^5(3x) dx?
  • MHB
  • Thread starter karush
  • Tags
    Dx
In summary, the conversation is about evaluating the integral $\displaystyle I_8 = \int_0^{\pi/4} \sin^5{2x} \, dx$ by using the substitution $u = \cos{2x}$ and the fact that $\displaystyle \mathrm{d}u = -2\sin{(2x)} \, \mathrm{d}x$. It is mentioned that $\displaystyle I_8 = -\int_0^{\pi/4} (\sin^2(2x))^2 \sin(2x) \, dx$ and the substitution is used to simplify the integral. The final answer is $\displaystyle \frac{4}{15}$,
karush
MHB
3,269
$\tiny{8.3.8}$
$\textit{evaluate}$
\begin{align*}\displaystyle
I_{8}&=\int_{0}^{\pi/4}
\sin^5{2x},dx\\
&=-\int_{0}^{\pi/4} (\sin^2(2x))^2 sin(2x) \, dx
\end{align*}
$\textit{set $u=\cos{2x} \therefore du=-2\sin{(2x)} \, dx$
then $u(0)=1$ and $\displaystyle u(\pi/4)=0$}$
&=-\int_{1}^{0} (1-u^2)^2 \,du \\
&=-\int_{1}^{0} (u-2u^2+u^4) \,du \\
&=-\left[ \frac{u^2}{2}-\frac{2u^3}{3}+\frac{u^5}{5}\right]_1^{0}\\
&=\frac{4}{15}\textit{ (book answer)}
\end{align*}
$\textit{ok something ? can't get book answer}$
karush said:
$\tiny{8.3.8}$
$\textit{evaluate}$
\sin^5{2x},dx\\
\end{align*}
\end{align*}
Remember you said $\displaystyle \begin{align*} \mathrm{d}u = -2\sin{(2\,x)} \,\mathrm{d}x \end{align*}$. You do NOT have that -2 factor in your integrand. What can you do to put it there?
It is also slightly simpler to use the fact that [tex]-\int_1^0 f(x)dx= \int_0^1 f(x)dx[/tex]
sorry everyone I made some typos in this so I'll just close the post.
FAQ: How Can You Evaluate a Tricky Integral of Sin^5(3x) dx?
1. What is the meaning of "8.3.8 int sin^5 (3x) dx"?
This expression represents the definite integral of the function sin^5(3x) with respect to x, evaluated from 8 to 3.
2. How do you solve the integral in "8.3.8 int sin^5 (3x) dx"?
To solve this integral, you can use techniques such as substitution, integration by parts, or trigonometric identities. The specific method will depend on the complexity of the function.
3. Can "8.3.8 int sin^5 (3x) dx" be solved analytically?
Yes, this integral can be solved analytically using integration techniques. However, the resulting integral may be complex and may require the use of a computer or calculator for numerical evaluation.
4. What are the applications of "8.3.8 int sin^5 (3x) dx" in science?
This integral has various applications in physics, engineering, and other scientific fields. It can be used to model periodic phenomena, such as the motion of a pendulum or the behavior of waves. It can also be used to solve differential equations and to calculate work and energy in certain systems.
5. How can "8.3.8 int sin^5 (3x) dx" be visualized?
The integral can be visualized as the area under the curve of the function sin^5(3x) between the limits of integration 8 and 3 on the x-axis. It can also be graphed using a graphing calculator or software to better understand its behavior and properties.
