How can you evaluate the double integral using a geometric series?
  • MHB
  • Thread starter Chris L T521
In summary, setting up a double integral involves identifying the limits of integration and writing the integrand in terms of the variables being integrated over. A geometric series is a sequence where each term is multiplied by a constant ratio, and it can be used to evaluate a double integral by converting the integrand into a series. This method can simplify the evaluation process and lead to closed-form solutions, but it may not always be applicable or result in a closed-form solution.
Chris L T521
MHB
915
Thanks again to those who participated in last week's POTW! Here's this week's problem!
Problem: The double integral
\[\int_0^1\int_0^1 \frac{1}{1-xy}\,dx\,dy\]
is an improper integral and could be defined as the limit of double integrals over the rectangle $[0,t]\times[0,t]$ as $t\to 1^{-}$.
  1. Expand the integrand as a geometric series to show that
    \[\int_0^1 \int_0^1 \frac{1}{1-xy}\,dx\,dy = \sum_{n=1}^{\infty}\frac{1}{n^2}\]
  2. Leonhard Euler proved that
    \[\sum_{n=1}^{\infty} \frac{1}{n^2}=\frac{\pi^2}{6}\]
    Prove this fact by evaluating the integral found in (1).
Hints:
For (2), start by making the change of variables
\[x=\frac{u-v}{\sqrt{2}},\qquad y=\frac{u+v}{\sqrt{2}}.\]
It may be ideal to plot the corresponding region in the $uv$-plane. If, in evaluating the integral, you encounter either of the expressions
\[\frac{1-\sin\theta}{\cos\theta}\text{ or }\frac{\cos\theta}{1+\sin\theta}\]
you might want to consider using the identity
\[\cos\theta= \sin\left(\frac{\pi}{2}-\theta\right)\]
and the corresponding identity for $\sin\theta$.
This week's problem was correctly answered by MarkFL. You can find his very detailed (and great) solution below.
1.) Expanding the integrand as a geometric series, we may write:
\(\displaystyle \frac{1}{1-xy}=\sum_{n=0}^{\infty}(xy)^n\)
Hence the integral becomes:
\(\displaystyle \int_0^1\int_0^1 \sum_{n=0}^{\infty}(xy)^n\,dx\,dy=\int_0^1\left[\sum_{n=0}^{\infty}\frac{x^{n+1}y^n}{n+1} \right]_0^1\,dy=\)
\(\displaystyle \int_0^{1}\sum_{n=1}^{\infty}\frac{y^{n-1}}{n}\,dy=\left[\sum_{n=1}^{\infty}\frac{y^{n}}{n^2} \right]_0^1=\sum_{n=1}^{\infty}\frac{1}{n^2}\)
2.) Using the change of variables:
\(\displaystyle (x,y)=(u-v,u+v)\)
we obtain:
\(\displaystyle \sum_{n=1}^{\infty}\frac{1}{n^2}=\iint_{R}\frac{1}{1-u^2+v^2}\left|\frac{\partial (x,y)}{\partial (u,v)} \right|\,du\,dv\)
Calculating the Jacobian matrix, we find:
\(\displaystyle \frac{\partial (x,y)}{\partial (u,v)}=\begin{vmatrix}\frac{\partial x}{\partial u}&\frac{\partial x}{\partial v}\\\frac{\partial y}{\partial u}&\frac{\partial y}{\partial v}\\\end{vmatrix}=\begin{vmatrix}1&-1\\1&1\\\end{vmatrix}=1(1)-(-1)(1)=2\)
Thus, we have:
\(\displaystyle \sum_{n=1}^{\infty}\frac{1}{n^2}=2\iint_{R}\frac{1}{1-u^2+v^2}\,du\,dv\)
Remapping the boundaries in terms of the new variables, we find $R$ is a square in the $uv$-plane with vertices:
\(\displaystyle (0,0),\,\left(\frac{1}{2},-\frac{1}{2} \right),\,\left(\frac{1}{2},\frac{1}{2} \right),\,(1,0)\)
Reversing the order of integration and using the symmetry of the square, we obtain:
\(\displaystyle \sum_{n=1}^{\infty}\frac{1}{n^2}=4\left(\int_0^{ \frac{1}{2}}\int_0^u \frac{dv\,du}{1-u^2+v^2}+\int_{ \frac{1}{2}}^1\int_0^{1-u} \frac{dv\,du}{1-u^2+v^2} \right)\)
Next, we may compute:
\(\displaystyle \int_0^u\frac{dv}{1-u^2+v^2}=\left[\frac{1}{\sqrt{1-u^2}}\tan^{-1}\left(\frac{v}{\sqrt{1-u^2}} \right) \right]_0^u=\frac{1}{\sqrt{1-u^2}}\tan^{-1}\left(\frac{u}{\sqrt{1-u^2}} \right)=\frac{1}{\sqrt{1-u^2}}\sin^{-1}(u)\)
\(\displaystyle \int_0^{1-u}\frac{dv}{1-u^2+v^2}=\left[\frac{1}{\sqrt{1-u^2}}\tan^{-1}\left(\frac{v}{\sqrt{1-u^2}} \right) \right]_0^{1-u}=\frac{1}{\sqrt{1-u^2}}\tan^{-1}\left(\frac{1-u}{\sqrt{1-u^2}} \right)=\frac{1}{\sqrt{1-u^2}}\tan^{-1}\left(\sqrt{\frac{1-u}{1+u}} \right)\)
If we let:
\(\displaystyle \tan(\theta)=\sqrt{\frac{1-u}{1+u}}\)
Squaring, we obtain:
\(\displaystyle \tan^2(\theta)=\frac{1-u}{1+u}\)
Add through by 1:
\(\displaystyle \tan^2(\theta)+1=\frac{1-u}{1+u}+1\)
Apply a Pythagorean identity on the left and combine terms on the right:
\(\displaystyle \sec^2(\theta)=\frac{2}{1+u}\)
Invert both sides:
\(\displaystyle \cos^2(\theta)=\frac{u+1}{2}\)
Solving for $u$, we find:
\(\displaystyle u=2\cos^2(\theta)-1=\cos(2\theta)\)
Hence, we find:
\(\displaystyle \tan^{-1}\left(\sqrt{\frac{1-u}{1+u}} \right)=\theta=\frac{1}{2}\cos^{-1}(u)\)
Using the identity \(\displaystyle \sin^{-1}(u)+\cos^{-1}(u)=\frac{\pi}{2}\) we finally have:
\(\displaystyle \tan^{-1}\left(\sqrt{\frac{1-u}{1+u}} \right)=\frac{1}{2}\left(\frac{\pi}{2}-\sin^{-1}(u) \right)\)
Utilizing these results, we now may state:
\(\displaystyle \sum_{n=1}^{\infty}\frac{1}{n^2}=4\left(\int_0^{ \frac{1}{2}}\frac{1}{\sqrt{1-u^2}}\sin^{-1}(u)\,du+\frac{1}{2}\int_{ \frac{1}{2}}^1 \frac{1}{\sqrt{1-u^2}}\left(\frac{\pi}{2}-\sin^{-1}(u) \right)\,du \right)\)
Now, let's look at the first integral:
\(\displaystyle \int_0^{ \frac{1}{2}}\frac{1}{\sqrt{1-u^2}}\sin^{-1}(u)\,du\)
Using the substitution:
\(\displaystyle \alpha=\sin^{-1}(u)\,\therefore\,d\alpha=\frac{1}{\sqrt{1-u^2}}\,du\)
we now have:
\(\displaystyle \int_0^{\frac{\pi}{6}}\alpha\,d\alpha=\frac{1}{2} \left[\alpha^2 \right]_0^{\frac{\pi}{6}}= \frac{1}{2}\left(\frac{\pi}{6} \right)^2=\frac{\pi^2}{72}\)
Next, let's break the second integral into two parts:
i) \(\displaystyle \frac{\pi}{4}\int_{\frac{1}{2}}^1 \frac{1}{\sqrt{1-u^2}}\,du=\frac{\pi}{4}\left[\sin^{-1}(u) \right]_{\frac{1}{2}}^1=\frac{\pi}{4}\left(\frac{\pi}{2}-\frac{\pi}{6} \right)=\frac{\pi^2}{12}\)
ii) \(\displaystyle -\frac{1}{2}\int_{\frac{1}{2}}^1 \frac{1}{\sqrt{1-u^2}}\sin^{-1}(u)\,du\)
we now have:
\(\displaystyle -\frac{1}{2}\int_{\frac{\pi}{6}}^{\frac{\pi}{2}} \alpha\,d\alpha=-\frac{1}{4}\left[\alpha^2 \right]_{\frac{\pi}{6}}^{\frac{\pi}{2}}=-\frac{1}{4}\left(\left(\frac{\pi}{2} \right)^2-\left(\frac{\pi}{6} \right)^2 \right)=-\frac{\pi^2}{18}\)
Thus, putting these results together, there results:
\(\displaystyle \sum_{n=1}^{\infty}\frac{1}{n^2}=4\left(\frac{\pi^2}{72}+\frac{\pi^2}{12}-\frac{\pi^2}{18} \right)=4\left(\frac{\pi^2}{24} \right)\)
And, we may then state:
\(\displaystyle \sum_{n=1}^{\infty}\frac{1}{n^2}=\frac{\pi^2}{6}\)
Shown as desired.
FAQ: How can you evaluate the double integral using a geometric series?
How do you set up a double integral?
The first step in setting up a double integral is to identify the limits of integration for both the inner and outer integrals. This involves determining the range of values for each variable that is being integrated over. Once the limits are established, the integrand (the function being integrated) is written in terms of the variables of integration.
What is a geometric series?
A geometric series is a sequence of numbers where each successive term is found by multiplying the previous term by a constant ratio. For example, the series 2, 4, 8, 16, 32... is a geometric series with a common ratio of 2.
How can you use a geometric series to evaluate a double integral?
A geometric series can be used to evaluate a double integral by converting the integrand into a series using partial fraction decomposition. This allows the integral to be evaluated term by term, making it easier to solve. The series can then be evaluated using known formulas or by recognizing patterns.
What are the benefits of using a geometric series to evaluate a double integral?
One benefit of using a geometric series is that it can simplify a complex integral into a series of simpler integrals. This can make the evaluation process more manageable and efficient. Additionally, using a geometric series can often lead to closed-form solutions for the integral.
Are there any limitations to using a geometric series to evaluate a double integral?
While using a geometric series can be a useful method for evaluating double integrals, it is not always applicable. If the integrand does not have a suitable form for conversion into a series, this method may not be feasible. Additionally, using a geometric series may not always lead to a closed-form solution, which can be a limitation in some cases.
