High School How Can You Express Cos(a-b) in Terms of m and n?
  • Thread starter Thread starter anemone
The discussion focuses on expressing cos(a - b) in terms of the variables m and n, derived from the given ratios of sine and cosine functions. Participants have provided solutions, confirming that the relationships between the angles can be manipulated using trigonometric identities. The correct expressions for cos(a - b) have been successfully identified by several members, showcasing their understanding of the problem. The thread highlights the importance of applying trigonometric properties to solve complex equations. Overall, the problem emphasizes the connection between angles and their sine and cosine ratios.
anemone
MHB
POTW Director
Here is this week's POTW:
Given that $$\frac{\sin (x-a)}{\sin (x-b)}=m$$ and $$\frac{\cos (x-a)}{\cos (x-b)}=n$$ where $$0\lt x \lt \frac{\pi}{2}$$ and $m$ and $n$ are two positive real numbers.
Express $$\cos (a − b)$$ in terms of $m$ and $n$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution::)
1. Ackbach
2. Theia
3. lfdahl
4. kaliprasad
5. Opalg
Solution from Ackbach:
Given that $\sin(x-a)=m \sin(x-b)$ and $\cos(x-a)=n \cos(x-b)$, we can rewrite these two equations as
\begin{align*}
\sin(x)\cos(a)-\cos(x)\sin(a)&=m\left[\sin(x)\cos(b)-\cos(x)\sin(b)\right] \\
\cos(x)\cos(a)+\sin(x)\sin(a)&=n\left[\cos(x)\cos(b)+\sin(x)\sin(b)\right].
\end{align*}
We view this system as equations in $\sin(x)$ and $\cos(x)$:
\begin{align*}
\sin(x)\left[\cos(a)-m\cos(b)\right]+\cos(x)\left[-\sin(a)+m\sin(b)\right]&=0 \\
\sin(x)\left[\sin(a)-n\sin(b)\right]+\cos(x)\left[\cos(a)-n\cos(b)\right]&=0.
\end{align*}
It is impossible for $\sin(x)=\cos(x)=0$, so this system must be degenerate, which forces the determinant to be zero:
$$(\cos(a)-m\cos(b))(\cos(a)-n\cos(b))-(-\sin(a)+m\sin(b))(\sin(a)-n\sin(b))=0,$$
or
$$\cos^2(a)-(m+n)\cos(a)\cos(b)+mn\cos^2(b)+\sin^2(a)-(m+n)\sin(a)\sin(b)+mn\sin^2(b)=0,$$
or
$$1+mn-(m+n)\left[\cos(a)\cos(b)+\sin(a)\sin(b)\right]=0,$$
and hence
$$\cos(a-b)=\frac{1+mn}{m+n}.$$
Since $m$ and $n$ are both positive, the denominator cannot be zero.
Solution from Opalg:
Write the equations as $$\sin(x-a) = m\sin(x-b), \qquad \cos(x-a) = n\cos(x-b).$$ Square both equations and add, to get $$1 = n^2\cos^2(x-b) + m^2\sin^2(x-b). \qquad(1)$$ Next, $$\begin{aligned}\cos(a-b) &= \cos\bigl((x-b) - (x-a)\bigr) \\ &= \cos(x-b)\cos(x-a) + \sin(x-b)\sin(x-a) \\ &= n\cos^2(x-b) + m\sin^2(x-b). \qquad(2) \end{aligned}$$ Now multiply (2) by $n$ and subtract (1), to get $$n\cos(a-b) - 1 = m(n-m)\sin^2(x-b). \qquad(3)$$ Similarly, multiply (2) by $m$ and subtract (1), to get $$m\cos(a-b) - 1 = n(m-n)\cos^2(x-b). \qquad(4)$$ If $m=n$ then it follows from (1) that $m=n= 1$ and then from (3) or (4) that $\cos(a-b) = 1.$
Otherwise, if $m\ne n$ then it follows from (3) and (4) that $$\frac{n\cos(a-b) - 1}{m(n-m)} + \frac{m\cos(a-b) - 1}{n(m-n)} = \sin^2(x-b) + \cos^2(x-b) = 1.$$ Therefore $$n(n\cos(a-b) - 1) - m(m\cos(a-b) - 1) = mn(n-m),$$ $$(n^2-m^2)\cos(a-b) = mn(n-m) + n - m,$$ $$(m+n)\cos(a-b) = mn+1$$ and finally $$\boxed{\cos(a-b) = \frac{mn+1}{m+n}}.$$ Notice that this last formula also covers the case when $m=n=1$, since it then gives the correct value $\cos(a-b) = 1.$
