How can you express this w/o zero or negative exponents?
In summary, the expression (9 - 9y^-2) / (y^-1 - y^0) raised to the power of 2 can be simplified to (9(1 - 1/y^2) / (1/y - 1))^2 by multiplying both the numerator and denominator by y^2. This ensures that the value of the expression remains the same.
haengbon
38
9 - 9y-2
____________
y-1 - y0
this whole thing is then raised to 2 (I can't seem to format it that way:( )
none
I'm hoping someone would guide me through this :(
Well, anything raised to the 0-th power is 1 so that simplifies that. I'm not entirely sure about your general question however. Are you looking for something that is simply expressed as positive exponents?
yes xD !
Well you can't get away from the fact that you'll have negative exponents. You can express the entire thing as a fraction of positive exponents however if that's what you're looking for; that is, you can get to [tex]\frac{something}{y^2}[/tex].
haengbon said:
9 - 9y-2
____________
y-1 - y0
[tex]\left(\frac{9- 9y^{-2}}{y^{-1}- y^{0}}\right)^2[/tex]
[tex]\left(9\frac{1- \frac{1}{y^2}}{\frac{1}{y}- 1}\right)^2[/tex]
Multiply both numerator and denominator by [itex]y^2[/itex].
none
I can't seem to understand why both the numerator and denominator needs to be multiplied by y2 :(
Because if you multiply only the numerator but not the denominator (or vice versa) by y2, you'll get something with a different value. If you multiply both numerator and denominator by the same value, you are multiplying by 1, which is the only number you can multiply by that doesn't change the value of the expression it multiplies.
FAQ: How can you express this w/o zero or negative exponents?
What is a zero exponent and why is it important to avoid it?
A zero exponent is when a number is raised to the power of 0. The result of any number to the power of 0 is always 1. It is important to avoid zero exponents because it can lead to incorrect answers and confusion in mathematical calculations.
How can you express a number without using zero or negative exponents?
To express a number without using zero or negative exponents, you can use positive exponents or convert the number into a fraction. For example, instead of writing 50, you can write it as 51/1 or 5. This would give the same result of 1.
Why is it important to simplify expressions with exponents?
Simplifying expressions with exponents makes it easier to perform mathematical operations and understand the relationship between different numbers. It also helps to avoid mistakes and confusion while solving complex equations.
What are some common mistakes people make when dealing with exponents?
Some common mistakes people make when dealing with exponents include forgetting to apply the exponent to every term in an expression, using the wrong exponent rule, and not simplifying the expression before solving it.
How can you check if your answer is correct when working with exponents?
You can check if your answer is correct by substituting the calculated value back into the original equation and simplifying it. If the simplified equation gives the same result as your answer, then it is correct. You can also use a calculator to verify the answer.
