How Can You Prove the Trigonometric Identity Cos^6A+Sin^6A=1-3Sin^2ACos^2A?
In summary, a trigonometric identity is an equation that is always true for any values of the variables involved. They are important because they allow for simplification of complex expressions and help establish relationships between trigonometric functions. These identities can be proven using various methods such as algebraic manipulations, unit circle, and sum and difference identities. The most commonly used trigonometric identity is the Pythagorean identity, and they have practical applications in fields such as engineering, physics, and music.
Silver Bolt
Prove $Cos^6A+Sin^6A=1-3 \hspace{0.2cm}Sin^2 A\hspace{0.02cm}Cos^2A$
So far,
$L.H.S=(Cos^2A)^3+(Sin^2A)^3$
$=(Cos^2A+Sin^2A)(Cos^4A-Cos^2ASin^2A+Sin^4A)$
$=\underbrace{(Cos^2A+Sin^2A)}_{\text{1}}(Cos^4A-Cos^2ASin^2A+Sin^4A) $
$=1(Cos^4A-Cos^2ASin^2A+Sin^4A)$
Can someone help from here?
Mathematics news on Phys.org
$$\sin^4(A)-\sin^2(A)\cos^2(A)+\cos^4(A)=(\sin^2(A)+\cos^2(A))^2-3\sin^2(A)\cos^2(A)$$
A little explanation on how did that -3 come in $\sin^2(A)+\cos^2(A))^2-3\sin^2(A)\cos^2(A)$
Expand $(\sin^2(A)+\cos^2(A))^2$. The result should answer your question.
This part can be rewritten as
$\sin^4(A)+\cos^4(A)-\sin^2(A)\cos^2(A)=(\sin^2(A)+\cos^2(A))^2-\sin^2(A)\cos^2(A)$
Expanding $(\sin^2(A)+\cos^2(A))^2=\sin^4(A)+2\sin^2(A)\cos^2(A)+cos^4(A)$
Now using it instead of$ (\sin^2(A)+\cos^2(A))^2$
$\sin^4(A)+2\sin^2(A)\cos^2(A)+cos^4(A)-\sin^2(A)\cos^2(A)=\sin^4(A)+\sin^2(A)\cos^2(A)+cos^4(A)$
which is not the desired answer.Where have I gone wrong?
Start with the line above and expand the RHS.
An alternate approach would be to factor the LHS as the sum of two cubes:
\(\displaystyle \cos^6(A)+\sin^6(A)=\left(\cos^2(A)+\sin^2(A)\right)\left(\cos^4(A)-\cos^2(A)\sin^2(A)+\sin^4(A)\right)\)
Now, for the first factor on the RHS, we can apply a Pythagorean identity to state:
\(\displaystyle \cos^6(A)+\sin^6(A)=\cos^4(A)-\cos^2(A)\sin^2(A)+\sin^4(A)\)
We can also use this same Pythagorean identity to state:
\(\displaystyle 1=\left(\cos^2(A)+\sin^2(A)\right)^2=\cos^4(A)+2\cos^2(A)\sin^2(A)+\sin^4(A)\implies \cos^4(A)+\sin^4(A)=1-2\cos^2(A)\sin^2(A)\)
And so, there results:
\(\displaystyle \cos^6(A)+\sin^6(A)=1-3\cos^2(A)\sin^2(A)\)
FAQ: How Can You Prove the Trigonometric Identity Cos^6A+Sin^6A=1-3Sin^2ACos^2A?
What is a trigonometric identity?
A trigonometric identity is an equation that is true for all values of the variables involved. In other words, it is a statement that is always true, regardless of the values of the angles involved.
Why are trigonometric identities important?
Trigonometric identities are important because they allow us to simplify complex trigonometric expressions and solve equations involving trigonometric functions. They also help us establish relationships between different trigonometric functions, making it easier to understand and manipulate them.
How do you prove a trigonometric identity?
There are several methods for proving a trigonometric identity, including using algebraic manipulations, using the unit circle, and using the sum and difference identities. The key is to manipulate the expressions on both sides of the equation until they are equal to each other.
What is the most commonly used trigonometric identity?
The most commonly used trigonometric identity is the Pythagorean identity, which states that sin²θ + cos²θ = 1 for any angle θ. This identity is widely used in calculus, physics, and engineering.
How can trigonometric identities be applied in real life?
Trigonometric identities have many practical applications in fields such as engineering, physics, and astronomy. They can be used to solve problems involving angles and distances, to design and construct structures, and to analyze the motion of objects. Trigonometric identities are also used in music and sound engineering to manipulate and create different types of waves and frequencies.
