How Can You Prove This Complex Integral Equals $\frac{\sqrt{6\pi}}{4}$?
  • MHB
  • Thread starter Euge
  • Tags
    2015
In summary, POTW stands for "Problem of the Week" and is a challenging problem or puzzle presented for scientific and mathematical communities to solve. The purpose of POTW #169 is to stimulate critical thinking and problem-solving skills. The difficulty level varies, but the goal is to engage in the problem-solving process and learn from it. There are no specific rules or guidelines, but a systematic and logical approach is recommended. There is no official prize, but the satisfaction and learning experience are the main rewards.
Euge
MHB
POTW Director
2,073
244
Here is this week's POTW:
Prove that
$$\int_0^\infty t^{-1/2}e^{-t}\cos(t\sqrt{3})\, dt = \frac{\sqrt{6\pi}}{4}.$$
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to Ackbach for solving this problem correctly! His solution is clever. You can read it below.
We have:
\begin{align*}
\int_0^{\infty}\frac{e^{-t}\cos(t\sqrt{3})}{\sqrt{t}} \, dt&=\text{Re}\int_0^{\infty}\frac{e^{-t}e^{it\sqrt{3}}}{\sqrt{t}} \, dt \\
&=\text{Re}\int_0^{\infty}\frac{e^{t(-1+i\sqrt{3})}}{\sqrt{t}} \, dt \qquad \left[u=\sqrt{t},\quad 2 \, du=\frac{dt}{\sqrt{t}}\right] \\
&=2\,\text{Re}\int_0^{\infty}e^{u^2(-1+i\sqrt{3})} \, du.
\end{align*}
Let $\displaystyle I=\int_0^{\infty}e^{u^2(-1+i\sqrt{3})} \, du$. Then
\begin{align*}
I^2&=\int_0^{\infty}e^{u^2(-1+i\sqrt{3})} \, du \cdot \int_0^{\infty}e^{v^2(-1+i\sqrt{3})} \, dv \\
&=\int_0^{\infty} \int_0^{\infty}e^{(-1+i\sqrt{3})(u^2+v^2)} \, du \, dv \\
&=\int_0^{\pi/2}\int_0^{\infty}e^{(-1+i\sqrt{3})r^2} \, r \, dr \, d\theta \qquad (\text{switching to polar})\\
&=\frac{\pi}{2}\int_0^{\infty}e^{(-1+i\sqrt{3})r^2} \, r \, dr \qquad \left[ s=r^2, \quad \frac{ds}{2}=r \, dr \right] \\
&=\frac{\pi}{4}\int_0^{\infty}e^{(-1+i\sqrt{3})s} \, ds \\
&=\frac{\pi}{4}\left(\frac{e^{(-1+i\sqrt{3})s}}{-1+i\sqrt{3}}\right)\Bigg|_{0}^{\infty \, \to \, 0} \\
&=\frac{\pi}{4} \, \frac{1+i\sqrt{3}}{4} \\
I^2&=\frac{\pi(1+i\sqrt{3})}{16} \\
I&=\pm\frac{\sqrt{\pi}}{2\sqrt{2}} \, e^{i\pi/6}.
\end{align*}
Now then,
\begin{align*}
\int_0^{\infty}\frac{e^{-t}\cos(t\sqrt{3})}{\sqrt{t}} \, dt&=2\,\text{Re}\int_0^{\infty}e^{u^2(-1+i\sqrt{3})} \, du \\
&=2 \, \text{Re} \left[ \pm\frac{\sqrt{\pi}}{2\sqrt{2}} \, e^{i\pi/6} \right] \\
&=\pm\frac{\sqrt{\pi}}{\sqrt{2}} \cdot \frac{\sqrt{3}}{2} \\
&=\pm\frac{\sqrt{6\pi}}{4}.
\end{align*}
Now here is the justification for ruling out the minus sign. The function $1/(e^t \sqrt{t})$ is monotone decreasing on the interval of integration. $\cos(t\sqrt{3})$ is oscillating. Let us examine the first period of this function carefully - this would be the interval $\displaystyle (0,2\pi/\sqrt{3})$. On $(0,\pi/(2\sqrt{3}))$, the cosine function is positive, and on $(\pi/(2\sqrt{3}),\pi/\sqrt{3})$, the cosine is negative. Because the multiplying function is decreasing, the positive portion will outweigh the negative. Next, we compare the interval $(\pi/\sqrt{3},3\pi/(2\sqrt{3}))$ to $(3\pi/(2\sqrt{3}),2\pi/\sqrt{3})$. The cosine function will be negative for the former, and positive for the latter. Hence, the integral, considered on these two intervals, will be negative overall. So, on the first half-period, the integral is positive, and on the second half-period, it is negative. Because the multiplying function is decreasing, however, the positive portion will dominate the negative, making the entire integral positive. We can repeat this analysis for any period, hence we can rule out the negative sign.
FAQ: How Can You Prove This Complex Integral Equals $\frac{\sqrt{6\pi}}{4}$?
What does POTW stand for?
POTW stands for "Problem of the Week". It is a term commonly used in scientific and mathematical communities to refer to a challenging problem or puzzle that is presented for others to solve.
What is the purpose of POTW #169?
The purpose of POTW #169 is to provide a stimulating and thought-provoking problem for scientists and mathematicians to solve. It encourages critical thinking and problem-solving skills, and allows individuals to showcase their knowledge and abilities.
What is the difficulty level of POTW #169?
The difficulty level of POTW #169 varies depending on an individual's background and expertise. It may be considered challenging for some and relatively easy for others. However, the goal is not to solve the problem quickly or easily, but to engage in the problem-solving process and learn from it.
Are there any specific rules or guidelines for solving POTW #169?
There are no specific rules or guidelines for solving POTW #169. However, it is recommended to approach the problem systematically and logically, and to provide clear and concise explanations for the solution. Collaboration and discussion with others may also be helpful in finding a solution.
Is there a prize or reward for solving POTW #169?
There is no official prize or reward for solving POTW #169. The satisfaction of solving a challenging problem and the learning experience gained from it are the main rewards. Some scientific and mathematical communities may offer recognition or awards for exceptional solutions, but it is not guaranteed.
