MHB How can you rewrite expressions using the definition of absolute value?
  • Thread starter Thread starter mathdad
    Absolute
The definition of absolute value indicates that |x| equals x for non-negative values and -x for negative values. An example provided is the expression |-sqrt{3} - sqrt{5}|, which is negative. By applying the definition, this expression can be rewritten as -(-sqrt{3} - sqrt{5}), resulting in sqrt{3} + sqrt{5}. This confirms the correct application of the absolute value definition in rewriting expressions.
mathdad
The definition of absolute value states the following:
| x | = x when x is > or = 0
| x | = -x when x < 0
I can use the above definition to rewrite expressions that do not contain absolute values.
| -sqrt{3} - sqrt{5} |
Since the expression in the absolute value is less than 0, we can say -(-sqrt{3} - sqrt{5}), which becomes
sqrt{3} + sqrt{5}.
Correct?
Mathematics news on Phys.org
Yes, that is correct.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
