How Can You Rewrite x²/(x⁴+x²+1) Using u?
  • MHB
  • Thread starter anemone
  • Tags
    2016
In summary, expressing the fraction $\frac{x^2}{x^4+x^2+1}$ in terms of $u$ simplifies the expression and makes it easier to work with in mathematical calculations. To determine the value of $u$, the denominator of the fraction is set equal to $u$ and solved for $x$. This expression is equivalent to $\frac{1}{x^2+1}$ because plugging in the value of $x$ for $u$ results in a simplified form. Expressing the fraction in terms of $u$ also makes it easier to integrate as it can be rewritten as $\ln|x^4+x^2+1| + C$. However, this substitution is limited to certain values
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Given that $u=\dfrac{x}{x^2+x+1}$. Express in terms of $u$ the value of the expression $\dfrac{x^2}{x^4+x^2+1}$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution::)
1. kaliprasad
2. Theia
3. lfdahl
4. greg1313
5. Opalg
Solution from Theia:
We have
\(\displaystyle u = \frac{x}{x^2 + x + 1}\).
Let's rise both sides to square and one obtains
\(\displaystyle u^2 = \frac{x^2}{x^4 + x^2 + 1 + 2x^3 + 2x^2 + 2x}\).
If one then multiplies the denominator to left hand side and groups the terms, one obtains
\(\displaystyle u^2(x^4 + x^2 + 1) + 2xu^2(x^2 + x + 1) = x^2\).
Now one can substitute the \(\displaystyle (x^2 + x + 1)\) to be equal to \(\displaystyle \frac{x}{u}\) by using the original equation. Thus the expression simplifies to
\(\displaystyle u^2(x^4 + x^2 + 1) + 2x^2u = x^2 \quad \Leftrightarrow \quad u^2(x^4 + x^2 + 1) = x^2(1 - 2u) \),
and further be dividing both sides by \(\displaystyle (x^4 + x^2 + 1)(1 - 2u)\)
\(\displaystyle \frac{x^2}{x^4 + x^2 + 1} = \frac{u^2}{1 - 2u}\).
Alternate solution from Opalg:
Let $u = \dfrac x{x^2+x+1}, \quad v = \dfrac x{x^2-x+1}$. Then $$\frac1u = x + 1 + \frac1x,\qquad \frac1v = x - 1 + \frac1x.$$ Therefore $\dfrac1v = \dfrac1u - 2 = \dfrac{1-2u}u,$ so that $v = \dfrac u{1-2u}.$
It follows that $\dfrac{x^2}{x^4 + x^2 + 1} = \dfrac{x^2}{(x^2 + x + 1)(x^2 - x + 1)} = uv = \dfrac{u^2}{1-2u}.$
FAQ: How Can You Rewrite x²/(x⁴+x²+1) Using u?
What is the purpose of expressing $\frac{x^2}{x^4+x^2+1}$ in terms of $u$?
The purpose of expressing this fraction in terms of $u$ is to simplify the expression and make it easier to work with in various mathematical calculations. By substituting $u$ for the denominator, we can rewrite the fraction as $\frac{1}{u}$, which is a simpler form.
How do you determine the value of $u$ in this expression?
To determine the value of $u$, we need to set the denominator of the fraction equal to $u$ and solve for $x$. In this case, the denominator $x^4+x^2+1$ can be factored into $(x^2+1)^2$, so we can set $u = (x^2+1)^2$. This allows us to rewrite the fraction as $\frac{1}{u}$, making it easier to work with.
Can you explain why this expression is equivalent to $\frac{1}{x^2+1}$?
The expression $\frac{x^2}{x^4+x^2+1}$ is equivalent to $\frac{1}{x^2+1}$ because by substituting $u = (x^2+1)^2$ and then solving for $x$, we find that $x = \pm\sqrt{-1} = \pm i$. Plugging this value of $x$ back into the original expression results in $\frac{1}{(i^2)^2 + i^2 + 1} = \frac{1}{-1 + (-1) + 1} = \frac{1}{1} = 1$, which is equivalent to $\frac{1}{x^2+1}$.
How does expressing this fraction in terms of $u$ make it easier to integrate?
Expressing the fraction in terms of $u$ makes it easier to integrate because integration often involves simplifying and rewriting expressions. By substituting $u$ for the denominator, we can easily integrate the fraction as $\int \frac{1}{u} du = \ln|u| + C = \ln|x^4+x^2+1| + C$, which would have been more complicated to integrate in its original form.
Are there any limitations to expressing this fraction in terms of $u$?
One limitation to expressing this fraction in terms of $u$ is that it only works for certain values of $x$. In this case, the substitution of $u = (x^2+1)^2$ is only valid for real values of $x$, as it would result in an imaginary solution for $x$ when solving for $u$. Additionally, this substitution may not always lead to a simpler expression, so it may not always be useful for certain mathematical calculations.
