How Can You Simplify This Complex Fraction Problem?
In summary: I don't know how one would prove that $1+x^4+(x+1)^4 = 2(x^2+x+1)^2$ other than the OP's way, so I haven't really added anything. (To be sure, you can do the algebra on paper, but...)In summary, the solution to finding the value of $\displaystyle \frac{1^4+
anemone
MHB
POTW Director
3,883
115
Problem:
Find the value of $\displaystyle \frac{1^4+2007^4+2008^4}{1^2+2007^2+2008^2}$.
My Attempt:
For the numerator, I expand them using the Binomial Theorem and get:
$\displaystyle 1^4+2007^4+2008^4$
$\displaystyle=1+(2000+7)^4+(2000+8)^4$
$\displaystyle
=1+2000^4+4(2000)^3(7)^1+6(2000)^2(7)^2+4(2000)^1(7)^3+7^4$
$\displaystyle
+2000^4+4(2000)^3(8)^1+6(2000)^2(8)^2+4(2000)^1(8)^3+8^4$
$\displaystyle
=2(2000^4)+60(2000)^3+678(2000)^2+3420(2000)+6498$I do the same for the denominator and get:
$\displaystyle 1^2+2007^2+2008^2$
$\displaystyle=1+(2000+7)^2+(2000+8)^2$
$\displaystyle=1+(2000)^2+14(2000)+49+(2000)^2+16(2000)+64$
$\displaystyle=2(2000^2)+30(2000)+114$
I noticed that if I square the denominator, I get twice the value as the numerator, let's see...
$\displaystyle (1^2+2007^2+2008^2)^2$
$\displaystyle
=4(2000^4)+120(2000)^3+1356(2000)^2+6840(2000)+12996$
$\displaystyle
=2(2(2000^4)+60(2000)^3+678(2000)^2+3420(2000)+6498)$So, we can say that
$\displaystyle \frac{1^4+2007^4+2008^4}{(1^2+2007^2+2008^2)^2}= \frac{1}{2}$
Therefore,
$\displaystyle \frac{1^4+2007^4+2008^4}{1^2+2007^2+2008^2}=\frac{1}{2}(1^2+2007^2+2008^2)=\frac{1}{2} (2(2000^2)+30(2000)+114)=4,030,057$My question is, are there any other approaches to solve this problem?
Thanks in advance.
Mathematics news on Phys.org
You can use the well known relations...
$\displaystyle \sum_{k=1}^{n} k^{2} = \frac{n\ (n+1)}{2}\ \frac{2 n +1}{3}$ (1)
$\displaystyle \sum_{k=1}^{n} k^{4} = \frac{n\ (n+1)}{2}\ \frac{2 n +1}{3}\ \frac{3 n^{2} + 3 n -1}{5} $ (2)
... but I doubt that that is a more comfortable way respect to direct computation...
Kind regards
$\chi$ $\sigma$
If you know in advance that the fraction is an integer, you can use the following approach.
Let $f$ be the fraction we want to evaluate. Select $n = 2007$. Then:
$$1^4 + 2007^4 + 2008^4 \equiv 1^4 + 0^4 + 1^4 \equiv 2 \pmod{2007}$$
$$1^2 + 2007^2 + 2008^2 \equiv 1^2 + 0^2 + 1^2 \equiv 2 \pmod{2007}$$
Therefore:
$$f \equiv 1 \pmod{2007} \tag{1}$$
Now use $n = 2008$. We get:
$$1^4 + 2007^4 + 2008^4 \equiv 1^4 + (-1)^4 + 0^4 \equiv 2 \pmod{2008}$$
$$1^2 + 2007^2 + 2008^2 \equiv 1^2 + (-1)^2 + 0^2 \equiv 2 \pmod{2008}$$
And therefore:
$$f \equiv 1 \pmod{2008} \tag{2}$$
And we note that $\gcd{(2007, 2008)} = 1$, and so, using the CRT on (1) and (2):
$$f \equiv 1 \pmod{2007 \times 2008} ~ ~ \implies ~ ~ f \equiv 1 \pmod{4030056} \tag{3}$$
And now, observe that we can write:
$$\frac{1^4 + 2007^4 + 2008^4}{1^2 + 2007^2 + 2008^2} \approx \frac{2 \cdot 2000^4}{2 \cdot 2000^2} \approx 2000^2 \approx 4000000 \tag{4}$$
Which shows that the correct solution must be $f = 4030057$. To be absolutely rigorous, it is enough to prove that:
$$\text{The approximation error is less than the distance between two possible solutions}$$
$$\therefore$$
$$\left | \frac{1^4 + 2007^4 + 2008^4}{1^2 + 2007^2 + 2008^2} - \frac{2 \cdot 2000^4}{2 \cdot 2000^2} \right | < 4030056$$
This probabilistic approach may be overkill for the problem and is perhaps not what you were looking for, but I thought this was worth posting to illustrate a different -albeit number-theoretical - point of view.
Therefore:
And therefore:
Which shows that the correct solution must be $f = 4030057$, as the approximation is more than sufficient:
Thanks, Bacterius, as you may have already noticed, it's all Greek to me.:eek: But I enjoy reading it very much...(Happy)
Kind regards
$\chi$ $\sigma$
Thanks, chisigma...what you've suggested has certainly given me food for thought, but I've got to run now, I will work with it to check if your suggestion could be simplified out neatly and that we don't have to deal with bigger figures too.
anemone said:
Problem:
My Attempt:
$\displaystyle
$\displaystyle
$\displaystyle
$\displaystyle
$\displaystyle
Therefore,
Thanks in advance.
I think that the OP's solution is as good as you can get. My approach was to calculate $1+x^4+(x+1)^4 = 2(x^4+2x^3+3x^2 + 2x+1) = 2(x^2+x+1)^2$, and $1+x^2+(x+1)^2 = 2(x^2+x+1)$, so that $$\frac{1+x^4+(x+1)^4}{1+x^2+(x+1)^2} = \frac{2(x^2+x+1)^2}{2(x^2+x+1)} = x^2+x+1.$$ That is the same as what anemone did for $x=2007$. Then when you use the fact that $2007 = 2000 + 7$, you easily get the answer $4030057$.
I was trying to post this , but the browser just crashed ... :)
Hi Opalg, your approach is much more better than mine because I didn't think of $2(x^4+2x^3+3x^2 + 2x+1)$ could be factorized as $ 2(x^2+x+1)^2$, thanks for giving me a lot of inspirations (both in the past and now) on how to tackle a maths problem more effectively.
Thanks!:)
Hello, anemone
I have a different approach.
I wouldn't claim that it is "better".
$\text{Evaluate: }\:N \;=\;\dfrac{2008^4+2007^4 + 1^4}{2008^2 + 2007^2+1^2}$
Let $u \:=\:2008$
We have: .$N \;=\;\dfrac{u^4 + (u-1)^4 + 1}{u^2 + (u-1)^2 + 1} \;=\;\dfrac{u^4+u^4-4u^3+6u^2-4u+1+1}{u^2+u^2-2u+1+1} $
. . . . . . . . . .$=\; \dfrac{2u^4-4u^3 + 6u^2 - 4u + 2}{2u^2-2u+2} \;=\;\dfrac{2(u^4-2u^3+3u^2 - 2u + 1)}{2(u^2-u+1)} $
. . . . . . . . . .$=\;\dfrac{u^4-2u^3 + 3u^2 - 2u + 1}{u^2-u+1} \;=\;\dfrac{(u^2-u+1)(u^2-u+1)}{u^2-u+1} $
. . . . . . . . . .$=\;u^2-u+1$Back-substitute: .$N \;=\;2008^2 - 2008 + 1 \;=\;4,\!030,\!057$
Just in case factorizing isn't clear , long division will do the task ...
FAQ: How Can You Simplify This Complex Fraction Problem?
What is a fraction?
A fraction is a number that represents a part of a whole. It is written in the form of a numerator (top number) over a denominator (bottom number).
How do you find the value of a fraction?
To find the value of a fraction, you need to divide the numerator by the denominator. The resulting quotient is the decimal equivalent of the fraction.
How do you simplify a fraction?
To simplify a fraction, you need to find the greatest common factor (GCF) of the numerator and denominator. Divide both numbers by the GCF to get the simplest form of the fraction.
What is an improper fraction?
An improper fraction is a fraction where the numerator is larger than the denominator. It can be converted to a mixed number (a whole number and a proper fraction) by dividing the numerator by the denominator and using the remainder as the numerator of the proper fraction.
How do you compare fractions?
To compare fractions, you can convert them to equivalent fractions with a common denominator and then compare the numerators. The fraction with the larger numerator is the greater fraction.
10K
11K
