How capacitance, charge, and energy stored changes on a capacitor?
In summary: As gleem said it's a geometrically determined characteristic as evident from:C = εA/d...(2)If you substitute for C in (1) you get..Q = (εA/d) * VIn summary, the capacitance decreases as the potential difference increases.
eprparadox
138
You charge a parallel-plate capacitor, remove it from the battery, and prevent the wires connected to the plates from touching each other. When you pull the plates apart to a larger separation, do the following quantities increase, decrease, or stay the same?
(a) C
(b) Q
(c) E between the plates
(d) V
[tex] C = \frac{Q}{V} [/tex]
[tex] C = \frac{\epsilon_0A}{d} [/tex]
[tex] E = \frac{\sigma}{\epsilon_0} [/tex]
[/B]
I'm doing some self study here and I'm trying to understand this problem. I'd love some thoughts on areas I'm confused on.
To start off, we are charging up this capacitor so that it holds charge Q and has a potential difference of V.
After disconnecting the battery, I know that the charge, Q, must stay the same because there's physically nowhere for the charge to go. So (b) remains the same.
Now, I wanted to tackle the potential difference, V, across the plates as we pull them apart. The potential difference between the two plates is equal to the work needed per unit charge in moving from one plate to the other. That is, if I physically move a charge from one plate to another, the work I do (per unit charge) is equal to the potential difference. This work will increase (because we're moving over a longer distance) if we increase the spacing on the plates. And that's why the potential difference will increase as we increase the space between the plates. So (d) increases.
The electric field, E, is given by the equation above, and is constant so it will remain the same. (c) remains the same. CONFUSION HERE: I don't have a good intuition on why it is the electric field remains the same when the potential difference increases. Any thoughts here?
And finally, the capacitance. I think I have a hard time reconciling the geometry relationship for capacitance with the formula that relates it to charge/voltage. From the formulas above, we see that if the potential difference increases, that the capacity decreases. CONFUSION HERE: But I always see this as the capacity to store charge and if the capacitance decreased, then its capacity to hold charge has decreased and so it should have less charge on it. But the Q can't go anywhere so I'm unclear as to how the capacitance decreases.
Any insight into the last two paragraphs would be great.
First what is the definition of electric field.(how is it related to the potential difference. Note that the electric field for a parallel plate capacitor is considered uniform.
Second If the charge is fixed as you already have noted then as the capacitance (a geometrically determined characteristic) is decreased what is the only thing that can happen as you increase the distance.?
No, in the equation...
Q = CV.... (1)
..C (Capacitance) is a constant, in that it's not dependent on Q or V (The size of a bucket doesn't depend on the volume of water in it). As gleem said it's a geometrically determined characteristic as evident from:
C = εA/d...(2)
Q = (εA/d) * V
You correctly stated that Q is constant so what's the relationship between d and V ?
You know voltage is the displacement integral of the E field, so V = Ed if d is the distance between plates. You have already correctly deduced that V goes up as d goes up, so E = V/d = constant should not surprise.
If you have covered Gauss's law that is a nice alternative way to find E.
It's capacity to store charge at a given voltage. So since V went up it shouldn't surprise that C had to go down.
Q = CV.... (1)
C = εA/d...(2)
In the problem, the distance between the plates increases, so capacitance is not constant here.
Yes, exactly.
That's one way to look at it. If you consider the plates to be very large, then the electric field is constant between the plates; since ##E=-\Delta V/d##, if ##d## increases then so must ##V## in order to keep ##E## constant.
See above. ##E## must be constant due to Gauss's Law, again assuming the plates are large.
##C=Q/V##. If ##Q## is constant and ##V## is increasing, then ##C## must be decreasing as you stated. Capacitance is the ability to hold charge at a given voltage. A high value capacitor can store a lot of charge using only a small potential difference while the opposite is true of a small value capacitor. Here the charge has stayed the same but the voltage of that charge has increased.
I know that but the OP wrote..
The capacitance is not dependant on Q or V.
Why not? It is related to those vales by definition. At any point in time ##C=Q/V##. The voltage is changing and the charge is constant. So ##C## must change to satisfy this definition at all times. The capacitance of a device does not have to be constant. Older radios used variable capacitors for the tuning knob.
He never said capacitance has to be constant. Vary d and you change C just as your "old radios" did. He said capacitance is not a function of Q or V.
I take a capacitor and put V on it. Q = CV. I then change V to V'. Q' = CV' but C does not change.
I know, I built my first about 47 years ago when I was 11.
I'm also reasonably familiar with variable capacitance diodes (which do indeed vary their capacitance when the voltage is changed), but none of this helps the OP understand the problem.
Except that ##Q=Q^{\prime}## for this problem, so which variable must change?
NFuller said:
Except that Q=Q′Q=Q′Q=Q^{\prime} for this problem, so which variable must change?
V must change.
C may change if the plates are moved.
No matter how much you try and change the voltage the capacitance won't change on it's own (for the type of capacitance this problem is concerned with).
Related to How capacitance, charge, and energy stored changes on a capacitor?
1. How does capacitance change on a capacitor?
The capacitance of a capacitor is determined by the physical characteristics of the capacitor, such as the distance between the plates, the area of the plates, and the type of dielectric material used. These factors affect the amount of charge a capacitor can hold, and therefore determine the capacitance.
2. How does charge change on a capacitor?
The charge on a capacitor is directly proportional to the voltage applied across it. This means that as the voltage increases, so does the charge on the capacitor. The charge can also change when the capacitor is connected to a circuit and is being charged or discharged.
3. How does energy stored change on a capacitor?
The energy stored on a capacitor is directly proportional to the capacitance and the square of the voltage applied. This means that as the capacitance or voltage increases, so does the energy stored. Energy can also change when the capacitor is being charged or discharged.
4. What factors affect how capacitance, charge, and energy stored change on a capacitor?
The main factors that affect the changes in capacitance, charge, and energy stored on a capacitor are the physical characteristics of the capacitor, the voltage applied, and the type of circuit it is connected to. Other factors, such as temperature and aging of the capacitor, can also have an impact.
5. How can one calculate the changes in capacitance, charge, and energy stored on a capacitor?
The changes in capacitance, charge, and energy stored on a capacitor can be calculated using equations that relate these variables. The capacitance can be calculated using the formula C = Q/V, where Q is the charge and V is the voltage. The energy stored can be calculated using the formula E = 1/2 * C * V^2, where C is the capacitance and V is the voltage.
