How certain are we about black hole mass density?
In summary, astronomers have calculated that an earth-mass black hole has a critical density of 2 x 1030, about 13 orders of magnitude denser than atomic nuclei.
hkyriazi
175
The Wikipedia entry on "White dwarf" has a table listing the densities (in kg/m3) of various objects/substances, and states that an earth-mass black hole has a critical density of 2 x 1030, about 13 orders of magnitude denser than atomic nuclei. Has such an enormous density been calculated, based on a black hole's observed gravitational pull and its observed (Schwarzschild?) radius, or is this a purely theoretical result? Basically, I'm wondering how certain, if at all, we are that such densities are possible.
This is purely theoretical. It is also one reason why we believe there are no natural earth-mass black holes. A larger black hole has a lower critical density.
Likes hkyriazi
Hi @hkyriazi:
You might want to do a bit of arithmetic. One way to define the density of a black hole is its mass M divided by the volume of a sphere with a radius equal to its Schwarzschild radius rs.
Wikipedia gives a formula for the Schwarzschild radius as
rs = 2.95 M/Msun km.​
https://en.wikipedia.org/wiki/Black_hole#Physical_properties
I was unable to find any usage of he term "critical density" with respect to a black hole except in the table in the article
https://en.wikipedia.org/wiki/White_dwarf .
I do not know the definition of "critical" in this usage.
Regards,
Buzz
Likes hkyriazi
It's a calculation, but the gravitational pull doesn't come into it. If all the mass were not inside the event horizon it wouldn't be a black hole, so knowing the mass and the "volume" from the Schwarzschild radius is enough to calculate the "density". (The scare-quotes around the word "volume" are because we're defining the "volume" of the black hole to be the volume of a sphere whose surface area is ##4\pi{R_S}^2##; the actual volume of space inside the event horizon is not well defined.)
Likes Ibix and Buzz Bloom
This "density" is just a numerical calculation that assumes that the hole's mass is contained within a Euclidean sphere with the surface area of the hole's horizon. Such a calculation has no physical meaning; it's just a number that pop science treatments sometimes throw out for no good reason. A black hole is not a static object with mass contained in a Euclidean 3-sphere with the surface area of the horizon. It's something very different.
Likes SiennaTheGr8, vanhees71 and hkyriazi
I don't think this is correct. As I said in my previous post, this "density" calculation has no physical meaning. AFAIK it does not play a role in any hypotheses about what masses of black holes we should expect to observe.
I assume astronomers have looked at the rotation rates of galactic cores, and calculated central "super-massive black hole" masses based on the gravitational pull apparently exerted. I doubt they're able to visualize the black hole event horizon (due to gravitational lensing?) sufficiently to do a pedestrian density calculation.
So, then, is it safe to assume that no pedestrian but respectable, pop science-type calculations have been made of mass densities in black holes, that yield densities much greater than those of neutron star cores?
You're missing the point. A black hole is not an ordinary object full of matter. It doesn't have a well-defined density at all.
Likes m4r35n357
It's not necessary to visualize or otherwise measure the size of the event horizon. The Schwarzschild radius is a function only of the mass, so if you know the mass you also know the "volume" and hence the density.
Note also that the "volume" goes up as the cube of the Schwarzschild radius while the Schwarzschild radius is directly proportional to the mass. Thus the "density" goes as the inverse square of the mass; an earth-mass black hole may be 13 orders of magnitude denser than an atomic nucleus, but a supermassive black hole is less dense than ordinary boring room temperature water. Thus, no extraordinary mechanisms are needed to turn a sufficiently large amount of gas into a supermassive black hole; its own ordinary gravitational attraction is enough to compress it to below the Schwarzschild radius and form the black hole.
Likes hkyriazi and berkeman
I don't think this intuitive reasoning is correct, because, as I've already said, the "density" calculated this way has no physical meaning. Even if we are considering a vast cloud of gas, if it is true that "its own ordinary gravitational attraction" is enough to cause it to become a black hole, then its spacetime geometry is already sufficiently different from flat that its density, even before it forms the hole, can't be calculated by assuming it is occupying a Euclidean volume of space bounded by its surface. So I don't think any intuitions along these lines should be used.
The density (usually of a presureless cloud of "dust") to form a black hole of a given size/mass is well defined though, and I believe is what the popularizations are calculating.
It'd be more interesting (but more complicated) to consider some sort of idealized fluid model that represented matter, and calculate the amount of pressure needed to compress an Earth-sized cloud of this idealized fluid to a low enough volume for it to form a black hole.
The usual model would be degenrate matter, <<wiki link>>
I don't know the experimental bounds on our understanding of neutron degenreate matter (the most reasonable case for a small black hole) would be though. I don't think they're terribly tight, but I'd be surprised if we didn't at least know the correct order of magnitude - at a guess.
Only in the sense that, in an idealized model such as the Oppenheimer-Snyder model of collapse of dust, given an externally measured mass (which is constant throughout the process), and an initial radius for the object when it starts collapsing from rest (which must be at least 9/8 of the Schwarzschild radius for the given mass because of Buchdahl's Theorem, and in practice will be much larger), one can calculate the density of the dust (which is uniform throughout the dust) at the instant when it is just crossing the event horizon of the spacetime as it collapses. But this density is not the same as the density being calculated by these pop science calculations. It is also not "the density of the black hole" in any meaningful sense. Nor is it the density of the dust when it starts collapsing from rest (that will be smaller).
This would be relevant for primordial black hole formation (i.e., formation by pressure and density fluctuations in the early universe), but not for formation of black holes by gravitational collapse. Such a collapse does not involve "pushing matter inward" by pressure.
As far as the densities we have a reasonable understanding of? IIRC we have a reasonable approximate model of the equation of state of neutron degenerate matter up to about a hundred times nuclear densities, or about ##10^{18} \text{kg/m^3}##.
Likes hkyriazi
May be it is along the line with this that I once calculated the integration of energy momentum pseudo tensor t in region outside Schwartzshild boundary sphere of BH. I got the result equals Mc^2 where M is mass of BH. It could be interpreted that all energy exist outside Schwatzshild sphere, not inside.
That statement is somewhat misleading. The matter within the black hole has collapsed completely, so aside from any matter falling into a black hole, the interior doesn't contain any matter. All of the matter ends up at the singularity and the interior is just empty space. It would be more accurate to just state the schwarzschild radius of a black hole having the mass of the Earth and leave it at that. A better way to understand this is to ask why all matter doesn't end up in black holes and why there are any objects that have the densities like that of white dwarf stars. The answer to that requires more than just general relativity and the relationship you get between a black hole mass and its corresponding schwarzschild radius.
What gives a white dwarf such a large density is what prevents it from collapsing any further and that is due to quantum mechanics and forces other than gravity. In particular, there is a limit to the number of particles you can confine to a given volume due to the exclusion principle. this results in a pressure that resists gravity trying to squeeze those particles into a smaller volume. Finding out the volume at which the pressure balances gravity requires knowing something called the density of states, which depends on things other than just mass and volume. You can look up Chandrasekhar limit to see how this is obtained for a white dwarf and Oppenheimer-Volkoff-Tolman limit for neutron stars. Whether or not further collapse into a more dense, stable body (like a strange star made of uds quarks) is possible is an open question. In any case, the density of matter alone is not sufficient determine whether or not the matter will further collapse. You have to know what is preventing matter from collapsing which requires knowing the number of quantum mechanical states available to the particles confined to that volume.
The density of a neutron star (which is much denser than a white dwarf) is certainly possible because the density of a neutron star is not estimated to be that much different than the density of your average heavy nucleus. Lots of experiments have been done to determine nuclear densities, so a density on the order of 10^17 kg/m^3 is not just a theoretical result. One of the reasons nuclear physicists study nuclei is to better understand nuclear matter and refine the equation of state for nuclear matter and consequently for understanding neutron stars and how large they can be without collapsing further.
Likes hkyriazi
I disagree. We don’t know of any natural process which will take an isolated Earth mass and compress it to a density ~13 times the density of atomic nuclei. We do know of natural processes which will take an isolated million solar mass and compress it to the density of water. Therefore we expect to see million solar mass black holes but not Earth mass black holes.
If an amount of matter is uniformly distributed throughout its schwarzschild radius then it is already a black hole fully inside its event horizon. It will of course not remain uniformly distributed, but it is a perfectly valid initial condition that gives an easy plausibility check.
Leonard Susskind uses this type of argument in his GR course.
Likes Buzz Bloom
A black hole is vacuum everywhere, outside and inside, so this integral will give zero. If you got M, you did it wrong.
We know of natural processes which will take a million solar masses worth of highly diffuse matter and have it eventually collapse to a black hole whose "density", if it is calculated using the physically meaningless method described earlier, comes out to the density of water. But, as I've already said several times, this "density" is physically meaningless, and the process is not a process of anything being "compressed". It's gravitational collapse, which is something different.
Also, as I've already said, the physically meaningless "density" calculation has nothing to do with the arguments for why we expect to see million solar mass black holes but not Earth mass black holes. Those arguments are about what kinds of objects can undergo gravitational collapse to black holes, and do not depend on the physically meaningless "density" of the hole once it is formed.
Not if the matter is claimed to be at rest. It is impossible for any distribution of matter to be at rest inside a sphere with a surface area having an areal radius less than 9/8 of the Schwarzschild radius corresponding to its externally measured mass. This is a simple consequence of Buchdahl's Theorem.
If the matter is not at rest but collapsing inward, then, while technically this counts as an "initial condition" (since in a deterministic theory you can call any condition an "initial condition" if you like), calling it that does not strike me as a good use of ordinary language, and trying to describe things that way is very likely to confuse people into thinking that a black hole can be viewed as some kind of static object where the matter just happens to be sitting just inside the Schwarzschild radius. Which it isn't.
Then that just gives me another reason not to be a fan of Susskind. :wink:
I am not talking about gravitational collapse. I am talking about the initial conditions prior to the collapse.
I am not making any claims about being at rest, just density. However, my understanding of Buchdahl’s theorem is that it places a limit on static configurations, I.e. momentarily at rest is fine it just won’t remain at rest.
I agree.
That is fine, but I liked the lecture series. It was not pop sci, but a gentle introduction. The point that he made was a valid point. Basically, the point is that for any given density, there is a finite amount of mass that at that density will form a black hole. So the conditions for formation of a black hole are not at all exotic, all you need is a lot of ordinary matter. Thus we are almost guaranteed that they exist since the conditions for their formation are so ordinary.
Likes Buzz Bloom
I don't think this is true either, at least not in any physically reasonable sense.
Mathematically speaking, yes, I think there are solutions that describe a spherically symmetric region of dust with finite extent that starts out with zero surface area, expands to a maximal surface area that could correspond to an areal radius less than 9/8 of the Schwarzschild radius corresponding to its externally measured mass, but still greater than that Schwarzschild radius, is momentarily at rest at that maximal areal radius, and then collapses back to zero radius. But such a solution would have an initial "white hole" singularity as well as a final "black hole" singularity, and is therefore not physically reasonable. (Such a solution would also have a "white hole" past horizon as well as a "black hole" future horizon.)
Also, even mathematically speaking, I don't think there are any valid solutions that have a maximal areal radius that is less than or equal to the Schwarzschild radius corresponding to the externally measured mass. The reason is that such a solution would have to have a single horizon that played the role of both the past and future horizons (since the matter never goes outside the horizon), and that is not possible, because those two horizons must be distinct (for example, on a Kruskal spacetime diagram they are perpendicular to each other--looking at a Kruskal diagram and trying to imagine how the region of matter would look if it never went outside the horizon can also help to see why such a solution is not possible). So if we are talking about the matter occupying a region with surface area less than the horizon area, it is impossible for it to be at rest even momentarily.
I agree with this statement as a general statement, but I do not agree with Susskind's way of justifying it.
Btw, an even simpler way of seeing that even "momentarily at rest" is impossible inside the horizon is to note that, for the matter to be even momentarily at rest, there must be a point on its worldline at which its 4-velocity points in a direction of constant areal radius (this will be the point at which it is momentarily at rest). But there are no such vectors inside the horizon that are timelike, or even null; all vectors pointing in the direction of constant areal radius inside the horizon are spacelike.
Yes, that’s a good point. Anyway, as I said above, I am not making any claims about the initial velocity. But regardless of the velocity the density is a valid thing to include in the characterization of the initial conditions.
It made sense to me.
Again, while this is technically true, since in a deterministic system you can call conditions at any time "initial", I don't think referring to the state of dust collapsing inward with a surface area just a bit less than the horizon area as "initial conditions" is a good choice of language. The "initial condition" should be the condition of the original object that started the collapse.
I can make sense of it if I interpret him as describing a cloud of dust that is collapsing inward and has a surface area just a bit less than the horizon area for its mass. But for the reasons I have given, I think describing this as an "initial condition" is seriously misleading. Such a cloud will never just occur on its own; it will always be an intermediate state in a process of gravitational collapse from some larger object like a massive star.
Honestly I could integrate t only outside Schwartzshild sphere. I did not and even now do not know formula of t inside the shere.
So what? The region is still vacuum and the integral still gives zero.
[tex](T^{\mu\nu}+t^{\mu\nu})_{,\nu}=0[/tex]
I am afraid you refer to T. I am referring t, stress-energy pseudotensor for the gravitational field.
There is no unique definition for this. Which definition are you using? What reference are you taking it from?
So, do we think there are any black holes (BHs) of mass in between that of the Earth and a million suns, such that a naive calculation of their density, based on their mass and Schwarzschild radius, comes out in between that of a neutron star (1018 kg/m3 max) and the extremely high, 1030 kg/m3 calculated as required for any Earth mass BH?
Of course. We expect black holes we can observe in our universe now to fall into at least two categories: stellar mass holes massing a few suns to a few tens of suns, formed by gravitational collapse of stars; and supermassive holes, massing millions to billions of suns or more, formed most likely by conglomeration of many smaller holes (or possibly a combination of that and many stars falling into the hole as it grows).
We do not expect earth-mass black holes (or holes of any mass much smaller than the mass of the sun or so) to form by gravitational collapse because the collapse would stop at the white dwarf or neutron star stage and never proceed further. It is possible that earth-mass black holes were formed in the very early universe, due to fluctuations in the density and pressure of matter and energy; we still have a rather sketchy understanding of the constraints on any such process, so it is hard to say whether any significant number of holes much smaller than the mass of the sun might have been formed in this way. My sense is that most cosmologists consider it unlikely, but the question is still open (and cosmologists continue to look for ways of pinning down the possibilities more tightly).
I agree with you that t, a pseudotensor not a tensor, is not unike. I took t_E for my calculation, not t_L-L or others, where E means Einstein's definition and L-L means definition in Landau Lifshitz text. I took these names from Gravitation by Misner, Thorne and Wheeler.
I just want to know right answer to the question:
Where is the rest energy, or mass, of BH ?
(a)All rest energy is within Schwartzshild's sphere.
(b)All rest energy is outside Schwatrtzshild's sphere.
(c)Some are within and others are outside Sphere.
(d)It has no unike defined location.
(e)a catefory-error, silly question!
  • #31
What about up-scaling the initial "cloud" to entire Galaxies that are somewhat doomed to cross each others (which is not so unrealistic, I think)
How many of those (no so dense) object are needed to be superposed to "become" a black hole ?
A related question, given the theoretical density of the universe, does it have a Schwartzshild radius (most probably bigger than the observable universe) or is the concept not even correct at such scale ?
  • #32
In the idealized, maximally extended Schwarzschild spacetime, it's nowhere; the spacetime has zero stress-energy everywhere.
In a more realistic model like the Oppenheimer-Snyder model of gravitational collapse, the region of nonzero stress-energy is mostly in the past, inside the object that ended up collapsing. There is a portion of that region inside the black hole's horizon, but it quickly collapses to zero radius and forms the singularity, so most of the interior of the hole (inside the horizon) is vacuum, and the exterior of the hole once the object has collapsed is also vacuum.
The best way to view it is to consider the "mass" of the hole as a global property of the spacetime geometry, not something that is localized to any particular region. So of your choices, (e) is probably the best.
Likes Dale
  • #33
My answer doesn't change. Galaxies are made up of stars and clouds of gas and dust. If a bunch of galaxies merged to form a superdupermassive black hole, it would be a process of conglomeration of smaller holes (at the very least, the supermassive holes already at the centers of the galaxies) and stars and gas and dust falling in. There is no plausible scenario where galaxies just happen to "superpose" so that a superdupermassive black hole gets created "in an instant" as they all reach just the right positions.
It's not a matter of scale, it's a matter of spacetime geometry. The concept of "Schwarzschild radius" only applies to the spacetime geometry of an isolated object or system of objects surrounded by vacuum. It does not apply to the universe as a whole since the universe as a whole is not an isolated system surrounded by vacuum.
  • #34
Is there even such a thing as "evenly distributed" inside the event horizon?
  • #35
For an instant, in certain idealized models, yes, there can be. The example that I have had in mind in my previous responses to @Dale is the Oppenheimer-Snyder model of spherically symmetric collapse of dust. At the instant when the outer surface of the dust is just crossing the event horizon, the dust has uniform density and occupies the entire space inside the horizon (note that at this instant, the singularity has not formed and so there is a well-defined notion of "the space inside the horizon" that is finite). However, the dust is collapsing inward and so this "evenly distributed" state is only that way for an instant.
  • Astronomy and Astrophysics
  • Science Fiction and Fantasy Media
