- #71
ohwilleke
- 1,467
Adrian59 said:I didn't see the Tully-Fisher relationship as similar to a galaxy rotation curve as you seem to be implying. Of course that is the underlying problem that both dark matter and MOND are trying to solve. As I am not a supporter of MOND, it is always with care that I reference Stacy McGaugh but non the less his paper from 2016 entitled ‘The Radial Acceleration Relation in Rotationally Supported Galaxies’ is an observational paper and as such can be read independently of Stacy McGaugh's preferred solution of MOND. I understood the observations to show a tight relation between baryonic mass and rotational velocity. It is surely meant to question the validity of dark matter as in order for dark matter theories to be compatible with these observations one has to invoke complex 'feed back' mechanisms. To my way of thinking any theory that can explain galaxy rotation velocities without dark matter will be compatible with these observations.
This is true. But, general relativity without dark matter is inconsistent with the Tully-Fischer relationship.
would you not agree that within the theoretical framework of SM a field requires a boson (I don't know if a future theory of quantum gravity can dispense with this requirement) but look how desperate the physics community was in its search for the Higg's boson.
All quantum gravity theories except the loop quantum gravity class of theories (e.g. causal dynamic triangles) and entropic theories, require a bosonic graviton at a minimum. LQG like GR focuses on space-time as the mechanism in lieu of gravitons. Entropic theories, IIRC, rely in part on quantum entanglement as a mechanism.
However, returning to an earlier post in this thread, you alluded to being a supporter of a version of MG. I don't know if you are prepared to say which and why if it is not too off topic for this thread.
I think that A. Deur's efforts to explain dark matter phenomena and dark energy are the closest to the truth (whether or not they are perfectly correct). His insights as a primarily QCD physicists inform his analysis in ways that other MG and GR researchers don't benefit from that are likely to be valid, he is quantum from the bottom up, his approach of starting from the non-abelian self-interacting scalar graviton static case and generalizing from that case is a smart one, and his back of napkin analysis suggests that he is in the right ball back to be explaining all of the dark matter and dark energy phenomena (solar system, galaxies, galaxy clusters, coincidence problem, dark energy, other cosmology issues) with no non-SM particles except a massless self-interacting graviton, but without a separate scalar or vector field. He made a successful prediction regarding apparent dark matter halo size in elliptical galaxies unique to his theory. It actually has one less free experimentally determined parameter than GR as it doesn't have a cosmological constant, in principle at least (he hasn't derived some constants that could be calculated from first principles). The fact that is provides a mechanism from which GR and MOND phenomena arise that is consistent with GR to the same extent of any vanilla attempt to do a quantum gravity theory that replicates GR, except one subtle issue regarding how self-interaction terms in non-spherically symmetric systems are treated, is big too
I didn't want to fixate too much on a particular theory that is not widely accepted and get into a debate over that particular theory, however. There are links summing up the key papers and a good powerpoint explanation above. None of the papers are terribly challenging for a physics grad student although the powerpoint presentation provides good motivation and context.
