How close does a supernova has to be to be lethal?
  • Thread starter SubTachyon
  • Tags
    Supernova
In summary, a 50-light-year-away supernova would expose us to lethal levels of radiation, but smaller supernovas (between 100 and 3000 light years away) would not pose such a danger.
SubTachyon
So one guy comes to me and says that he doesn't believe that a supernova 50ly away would be dangerous enough to pose a lethal threat to us. I contradicted him because based on my general reading supernovas (depending on their magnitude) between at least a 100 to 3000 light years away would expose us and our atmosphere to overwhelming levels of radiation. However then I thought of going further and actually doing some calculations myself to prove my point but I soon discovered the task is much more difficult than I would like it to be:
I start with the assumption that the supernova is 50ly away and radiates the energy worth of 1 Foe (10^44j). This gives me the value of 36Mj per metre squared at our distance. However here come the unknowns:
- Over what duration is this energy expelled? Are we looking at most of it shining through in 100 seconds or a month or the whole year?
- What % of that is short-wavelength radiation? Because unless we get kilowats worth of infrared radiation we are really mainly concerned with the harmful stuff right?
- How much can our atmosphere take? How many wats worth of gamma and x-rays do we have to be exposed to in order to deplete our ozone layer and kill us?
I am assuming there will be people here who dealt with a similar issue at some point and can perhaps at least talk from experience if not maths?
Astronomy news on Phys.org
A typical [type Ia or II] supernova would need to be less than 30 light years distant to pose any threat to life on earth. GRB's, on the other hand, could be a threat over a couple thousand light years. Another factor is what lies between Earth and a supernova. A significant quantity of interstellar hydrogen would cause compton scattering, further attenuating the deadlier wavelengths. For some recreational math, see here:
http://www.tass-survey.org/richmond/answers/snrisks.txt
Astronuc said:
Distance would obviously depend on the energy/type of SN.
And in case of an anisotropic supernova (e.g. due to bipolar jets) it will depend on its orientation.
This was a topic of a lunch conversation and the consensus was that the lethal distance was in the tens of light years. It wouldn't be the direct radiation that would kill us but the gamma rays would destroy the ozone layer.
To do a rough calculations
1) it really doesn't matter since you are looking at total energy absorbed
2) you can put in order 10% to 50% in high UV
3) for this you calculate the number of ozone atoms and compare to the number of photons that get generated
If you are impatient, here is someone that has already worked it out... :-) :-) :-)
http://iopscience.iop.org/0004-637X/585/2/1169/56170.text.html
Related to How close does a supernova has to be to be lethal?
1. How close does a supernova have to be to be lethal?
The exact distance needed for a supernova to be lethal depends on various factors such as the type of supernova, the amount of radiation emitted, and the composition of the material between the supernova and the observer. However, on average, a supernova would need to be within 50 to 100 light-years to cause significant damage to Earth.
2. Can a supernova cause harm from a farther distance?
Yes, a supernova can still have some effects on Earth even if it is farther away than 50 to 100 light-years. The radiation from a supernova can ionize the Earth's atmosphere, which can lead to disruptions in communication systems and potentially harm living organisms.
3. What type of supernova would be the most lethal?
Type II supernovae, which occur when a massive star runs out of nuclear fuel and collapses, are considered to be the most lethal type of supernova. This is because they release a large amount of energy and emit high levels of radiation, making them more dangerous than other types of supernovae.
4. How long would it take for a supernova to reach Earth?
The time it takes for a supernova to reach Earth depends on its distance from our planet. As light travels at a constant speed, it would take a supernova about 50 to 100 years to reach Earth if it is within 50 to 100 light-years away.
5. What would happen if a supernova exploded close to Earth?
If a supernova were to occur within a few light-years of Earth, it would have catastrophic consequences. The intense radiation and shockwave could destroy the protective ozone layer, leading to an increase in harmful UV radiation from the sun. This could have severe impacts on the Earth's climate and ecosystems, potentially causing mass extinctions.
