How close does an electron get to a proton to be attracted
In summary,There is no minimum distance at which an attractive force between two particles exists. If the particles are moving, the force decreases as the distance between them increases.
MarDude
I couldn't fit the whole question, it should say
"How close does an electron have to get to a proton to be attracted to it"
And I know it can depend on the speed and direction they are traveling. Can we just pretend they are stationary for this answer please.
By attracted I mean the electron will change its course to move towards the proton
Look at the equation that describes the force between two stationary charged objects. Is there any distance at which there is not an attractive force between them?
You're talking about Coulombs law. All that does us sum up the net attraction or repulsion. It is impossible to determine if the force is enough to actually move a particle.
So if that is my best reply then is it safe to assume that the answer to my question is not known?
Any one know of any other forums where I can try to find an answer?
Any force, however small, will move a particle. So, in theory, it doesn't matter how far apart the two particles are, they will move towards each other. In practice, however, you cannot set a proton and an electron one light-year apart, say, and see whether they start to move towards each other. On a large scale, e.g. the Solar system, objects tend to be electrically neutral and electrical attraction or repulsion over large distances is not relevant to the behaviour of the Solar system.
The issue is more important for gravity. Again, in theory, gravity works over any large distance, but it's important to know whether this is actually the case. And, in the universe there are large masses a very long distance away from each other. The evidence we have is that gravity works as expected over the largest distances that we have been able to measure.
Force is not required for motion. Force is required to change motion, but there is no minimum amount required. The smaller the force the smaller the change in motion.
As distance between the particles increases the force decreases. There is no separation distance for which the force is zero.
Several people have given you the correct answer. You can look elsewhere for other answers, but unless you can tell us what you find unsatisfactory about the ones you've been given you will just be doing random searches with no way to tell which answers are valid.
I think part of the problem here is semantics. You said this:
If by that you mean that the electron will move directly toward the proton, rather than on some path that misses it, the answer is that this will only happen if the electron started out stationary or already on the line directly toward the proton (or directly away from the proton if it's going slow enough). And in that case, there is no maximum distance (even in the case of moving directly away, at any distance if the electron is moving slowly enough it will eventually turn around). The Coulomb force goes to infinity, and F = ma says that as long as there's a nonzero force, there's a nonzero acceleration.
If the electron has some initial motion which is not directly toward or away from the proton, then the behavior is the same as for planets under Newton's Law of Gravitation: the path is going to be either a closed ellipse, a parabola, or a hyperbola, all of which will miss the central attracting object.
I'm wondering if there is something behind the question. Are you assuming that electrons in an atom aren't close enough to be attracted to the nucleus or they would have "fallen in"?
This is criptic. What do you mean with "net attraction or repulsion"?
lightarrow
Largest hydrogen atoms (ever detected in interstellar space) are about 0.5mm large. In liquid or solid electrolyte the noticeable (for purposes of chemistry) attraction starts from ~0.1mm too. For ion engine, recombination between separately emitted electrons and ions happens even if emitters are separated by several tens of cm.
Theoretically, the attraction force works up to infinity - the maximal recombination radius is mostly defined by electrical noise levels of background space, rather than by intrinsic properties of electron and proton.
Likes MarDude and PeroK
Just as with the gravitational force and orbits there will be an escape velocity for an electron being electrically attracted by a proton. If the electron's kinetic energy exceeds the potential energy of electron-proton system, the electron will escape.
How would they be detected? Absorption lines at low Radio frequencies? Do you have a reference about this - experimental details could be interesting.
Thanks, that will get me to the next step
Thanks, mentioning infinity was helpful
Thanks a lot, that was most helpful
lightarrow
I was never top of the class in English. I'm just trying to learn some stuff some of which is not often discussed
Yes, it is radio lines argument which trace to
"Very large hydrogen atoms in interstellar space"
published back in 1991. I checked recently and found the following correction dated 2013 though:
https://pubs.acs.org/doi/abs/10.1021/ed400399y?src=recsys
It states the maximal atom size was over-calculated 100 times, and therefore correct answer for maximal hydrogen atom size in ISM is 5um, not 500um.
Likes Lord Crc and sophiecentaur
FAQ: How close does an electron get to a proton to be attracted
1. How close does an electron need to be to a proton to experience attraction?
The distance between an electron and a proton for attraction to occur is not a fixed value. It depends on the strength of the electric field created by the proton and the energy level of the electron. Generally, the closer the electron is to the proton, the stronger the attraction will be.
2. Is there a minimum distance at which an electron and a proton can attract each other?
According to the laws of physics, there is no minimum distance for an electron and a proton to experience attraction. However, as the distance between the two particles decreases, the force of attraction becomes stronger and eventually overpowers the repulsion between the positively charged proton and negatively charged electron.
3. Can an electron be too far away from a proton to experience attraction?
Yes, there is a maximum distance at which attraction between an electron and a proton can occur. This is because the electric field created by the proton decreases as the distance increases, eventually becoming too weak to overcome the repulsion between the two particles.
4. How does the distance between an electron and a proton affect the strength of attraction?
The strength of attraction between an electron and a proton is directly proportional to the distance between them. As the distance decreases, the force of attraction becomes stronger, and as the distance increases, the force of attraction becomes weaker. This is due to the inverse-square law, which states that the force between two charged particles is inversely proportional to the square of the distance between them.
5. Can an electron and a proton attract each other if they are moving at high speeds?
Yes, the speed of the particles does not affect the strength of attraction between an electron and a proton. The only factors that influence attraction are the distance between the particles and the strength of the electric field created by the proton.
