How come black holes have a mass?
In summary, gravitational waves are produced when two masses orbit one another quickly, and the event horizon does not need to be crossed for the waves to be produced.
Dhaga
If the sun disappear right now, we won't notice before 8 and something minutes due to the speed of light. The Earth will keep going it's way on it's orbit because, as everything, gravity cannot exceed light speed.
The same would apply if we were orbiting à black hole.
I often heard of the graviton, an hypothesis for a particle carrying gravity. Nothing can escape à black hole (only degenerated particles over very long period of time) so why is gravity escaping?
In other words, why do black holes have a mass?
Does this question makes any sense?
Likes 1oldman2 and berkeman
Astronomy news on Phys.org
Mabe I should have asked my question in another way. I know black holes are made of matter, but I wonder why gravity is escaping out of them.
Gravity travels at the speed of light, not fast enough to escape à black hole...
Gravity is effectively an interaction with the gravitational field, not with the source of it. The distant gravitational field is created when the black hole is formed (and does not change at all for example if an object of a given mass collapses in a spherically symmetrical way).
Einstein's great accomplishment with GR was showing gravity is the geometry of spacetime. Nothing need escape a black hole to warp spacetime.
So the merging of the two black holes that caused the LIGO chirp happened outside of the Schwarzschild radius, and that's why we could detect the event?
The gravitational waves were produced while the black holes were orbiting one another, initially well outside the Schwarzschild radius. Even a black hole has to follow the shape of space-time, so no communication behind the event horizon is necessary for that to happen.
Gravitational waves are driven by the sources of the fields being moved rapidly, causing a ripple of a slight change in direction to move through space-time at the speed of light. By conservation of momentum, it's not possible for one source to move on its own, so on average the field changes caused by a pair of masses orbiting one another cancel out (which means that there is no "dipole" radiation). However, as the system moves from maximum elongation to minimum elongation, there is effectively a slight squashing and relaxing of space perpendicular to the elongation, and that propagates as a "quadrupole" ripple through space.
When the black holes get close enough, they start to interact and combine directly, with the event horizon deforming until it joins and encloses both, creating a single spinning black hole. That happens during the "ring down" phase. I think the idea is that the initial merged shape is like a dumbbell but rapidly becomes more circular, after which there is no longer any gravitational signal. Again, there is still no need for anything to communicate behind the event horizon, in that each part of the system is still simply following the shape of space-time.
Likes berkeman and 1oldman2
Related to How come black holes have a mass?
1. How do black holes have mass if they are just empty space?
Contrary to popular belief, black holes are not just empty space. They are incredibly dense objects that have a mass equivalent to millions or even billions of suns. This mass is concentrated in a very small space, which is what gives a black hole its strong gravitational pull.
2. How do black holes get their mass?
Black holes can acquire mass in several ways. One way is through the collapse of a massive star, in which the core becomes so dense that it collapses into a black hole. Another way is through the merging of two or more black holes, which can result in a larger black hole with a combined mass.
3. Can black holes lose their mass?
Black holes can lose mass through a process called Hawking radiation. This is a phenomenon in which a black hole emits radiation due to quantum effects near the event horizon. However, this process is very slow and only affects very small black holes. Most black holes in the universe are actually gaining mass through accretion of matter from their surroundings.
4. How is the mass of a black hole measured?
The mass of a black hole can be measured by observing the orbits of objects around it. Just like how we can calculate the mass of a planet by observing the orbits of its moons, scientists can use the same principle to measure the mass of a black hole. They can also use gravitational lensing, which is the bending of light by the strong gravitational pull of a black hole, to estimate its mass.
5. Is there a limit to how massive a black hole can be?
There is no known limit to the mass of a black hole. In theory, a black hole can continue to grow in mass as long as it continues to accrete matter. However, there is a limit to how quickly a black hole can grow, known as the Eddington limit, which is determined by the properties of the surrounding matter and the black hole's own gravity.
  • Astronomy and Astrophysics
