How come sub-atomic particles aren't affected by the vacuum around them
In summary, the vacuum around sub-atomic particles does not affect them because vacuum does not "suck" like a vacuum cleaner. Instead, it simply allows air to randomly fill the empty spaces. It is similar to a crowd of people filling two rooms when a door is opened. The empty room is not actively pulling them in.
Nasevic
Why aren't sub-atomic particles (electrons, protons, neutrons) affected by the vacuum around them. Why aren't they tugged off course like air in space
I think you have a small misunderstanding about vacuum.
Vacuum doesn't suck - what happens with say a vacuum cleaner (or a pump) is that you have less air on the inside than outside and so air moves towards the vacuuum simply out of randomly filling the spaces.
It's like having a crowd of people in a small room and opening the door - they will gradualy fill both rooms - but the empty room isn't pulling them
Sub-atomic particles, such as electrons, protons, and neutrons, are not affected by the vacuum around them because they do not interact with the vacuum in the same way that macroscopic objects do. The vacuum of space is not completely empty, but rather it is filled with virtual particles that constantly appear and disappear. These virtual particles do not have a significant effect on sub-atomic particles.
Moreover, sub-atomic particles have very small masses, making them less susceptible to external forces like the vacuum. In addition, they are also governed by the laws of quantum mechanics, which dictate that they can exist in multiple places simultaneously and can only be described by probabilities rather than definite positions.
Furthermore, sub-atomic particles do not have a surface or boundary like macroscopic objects do. This means that there is no air resistance or drag acting on them in the vacuum of space. Therefore, they are not tugged off course like air in space.
Overall, the behavior of sub-atomic particles is very different from that of macroscopic objects and cannot be explained by classical physics alone. It is only through the principles of quantum mechanics that we can understand why sub-atomic particles are not affected by the vacuum around them in the same way as larger objects.
Related to How come sub-atomic particles aren't affected by the vacuum around them
1. Why aren't sub-atomic particles affected by the vacuum around them?
Sub-atomic particles, such as electrons and protons, are not affected by the vacuum around them because they have very little mass and do not interact with the particles in the vacuum. This lack of interaction allows them to maintain their momentum and movement without being disturbed by the vacuum.
2. How do sub-atomic particles behave in a vacuum?
In a vacuum, sub-atomic particles behave in a similar manner as they do in other environments. They continue to move and interact with each other, but without the presence of air particles or other matter, their movement is not affected by friction or other forces.
3. Are sub-atomic particles affected by the vacuum of outer space?
Yes, sub-atomic particles are affected by the vacuum of outer space. However, the vacuum of outer space is much less dense than the vacuum on Earth, allowing particles to move more freely without being affected by other particles.
4. How can sub-atomic particles travel in a vacuum without losing energy?
Sub-atomic particles can travel in a vacuum without losing energy because they do not experience resistance or friction in the same way as larger particles. This allows them to maintain their energy and momentum for longer periods of time.
5. Can the vacuum of outer space affect the behavior of sub-atomic particles?
Yes, the vacuum of outer space can affect the behavior of sub-atomic particles. In deep space, the vacuum is less dense and particles can travel further without colliding with other particles. This can impact the rate at which particles decay or interact with each other.
