How common is it for articles to be published in more than one journal?
In summary: Depending on the field, it's also sometimes possible that a short letter can be published in the rapid communications section of a journal, with a longer version containing all of the details...this is generally seen as a way of getting the paper into a journal without actually submitting it.
Simfish
Say, if I publish in the Astronomical Society of the Pacific, then does it make it harder for me to get the paper into the Astrophysical Journal or Icarus later on? What about a paper that hits both Astrophysical Journal and Nature/Science/PNAS?
In math this never happens. You publish a paper at most once in your lifetime. If you have a volume of your collected works it is reprinted, or if it is so famous it gets reprinted in a collection of articles, but that's about it.
It's pretty much considered bad form to submit the same paper to multiple journals. Submitting the same paper can even get you "blacklisted" from certain journals.
I don't think it's simply a matter of bad form: it's probably illegal. Most journals tend to specifically state you cannot submit the same article to multiple journals, as the journal will hold the copyright to your article after it is published. They usually have you sign an agreement to this in order to get the paper published. You can of course skirt around this by adding new content, expanding on the original paper, etc., but you cannot submit exactly the same article to more than one journal.
It makes it impossible. Once it's submitted to one journal, you'll get into serious trouble if you submit it to another.
Also doesn't happen.
What does happen regularly is that papers that get rejected by Nature/Science/PNAS get resubmitted to Astrophysical Journal. Nature/Science/PNAS frequently reject papers on the grounds that the research is merely "good" and not "earth-shaking" at which point you take the rejection and then submit it to Ap.J.
Mute said:
I don't think it's simply a matter of bad form: it's probably illegal. Most journals tend to specifically state you cannot submit the same article to multiple journals, as the journal will hold the copyright to your article after it is published. You essentially sign an agreement to this in order to get the paper published. You can of course skirt around this by adding new content, expanding on the original paper, etc., but you cannot submit exactly the same article to more than one journal.
Beat me to it. Unfortunately, I'm not too familiar with the details of rights transfer when submitting a paper to a journal, but I would assume you transfer at least full rights to publish. This means it is no longer you that decides if, when and how the paper is going to get published.
This, on the other hand, is perfectly fine. When submitting a paper, you make an offer, and if they refuse it, you are no longer bound by it. Then, you can do whatever you could prior to submitting the paper to the journal.
Wow interesting - thanks for all the replies!
So what happens if someone publishes truly earth-shattering research? (say, something along the lines of discovering the double helix structure of DNA). Do the same types of papers sometimes hit both Nature and Science? (considering that both Nature and Science want to capture the hottest scientific discoveries?)
What do you mean what happens?
Does the same research get published on both journals? As in, is there any overlap in content between the two journals, or is their content almost always completely independent of each other? (as we would expect if people could not publish the same paper in both journals).
You only submit to one journal at a time. You don't send your paper everywhere and hope someone will take it, you start with the best journal you think it can be published in and work your way down if they won't take it even after revision (assuming the science is solid).
Depending on the field, it's also sometimes possible that a short letter can be published in the rapid communications section of a journal, with a longer version containing all of the details appearing elsewhere. You would never submit papers that contain exactly the same analysis. The long version would also make clear that a letter version has been submitted by citation so that editors and referees can decide whether publication of the longer version is warranted.
No. You have to choose.
The other thing is that there is a process for notifying when you've discovered an asteroid or supernova.
http://www.cbat.eps.harvard.edu/
There's also a procedure to follow if you've been contacted by extraterrestrials.
see http://www.atnf.csiro.au/people/rnorris/papers/n188.pdf
In astronomy, ordinary research results are sent off to the Los Alamos Preprint Server and made available via preprints immediately, and this takes place several months before the journal publishes. People in astrophysics don't read journals for research results. It's mostly for archival purposes with some degree of post-hoc quality control.
The only situation in which you wouldn't want to do that is if you think you've been contacted with space aliens or something like that in which case you want some other people to confirm before you look silly.
In some fields what journal publishes your paper is of crucial importance, but it's not terribly important in astrophysics. If you are in the US, you publish with Astrophysical Journal, and if you are in Europe you publish with A&A or MNRAS.
However, one big discussion is how "thin to slice the salami" (i.e. how many papers you can get from the same set of results).
In other words, it's not like applying to colleges or grad schools, or for jobs.
I entirely agree about not sending the same paper to more than one journal.
But if you want to be a "successful" academic you have to learn the trick of getting 20 slightly different papers published about one not-very-profound research project :devil:
Interesting replies, everyone.
Another question: Is it bad practice to submit a preliminary draft to arxiv.org and then to upload several updated subsequent drafts to the arxiv?
Yes. The arXiv is a preprint server, not a place to upload drafts. Typically, it's revised only once, when the journal prints it.
If you're at all concerned that your paper might not be accepted to a journal, don't put in on arXiv until it's accepted. That's pretty standard practice. At least that way you don't have to upload a few revised versions, or anything that might have a mistake no one in your group caught.
FAQ: How common is it for articles to be published in more than one journal?
It is not very common for articles to be published in more than one journal. This is because most journals require original and previously unpublished content.
Can an article be published in multiple journals simultaneously?
No, an article cannot be published in multiple journals simultaneously. This would be considered self-plagiarism and goes against the ethical standards of the scientific community.
Are there any exceptions to publishing an article in more than one journal?
There are some exceptions, such as when an article is translated into a different language and published in a journal targeted towards a different audience. However, this must be disclosed and approved by the original journal and the new journal.
What is the purpose of publishing an article in more than one journal?
The purpose of publishing an article in more than one journal is to reach a wider audience and increase the impact and visibility of the research. It can also help to establish the credibility and validity of the research.
Is it necessary to obtain permission from the original journal to publish an article in another journal?
Yes, it is necessary to obtain permission from the original journal before publishing an article in another journal. This is to ensure that the original research is properly credited and that there are no conflicts of interest or ethical concerns.
