How could we calculate the limit?
  • MHB
  • Thread starter evinda
  • Tags
    Limit
In summary: Thinking)In summary, we have shown that for the given linear differential equation with certain conditions, each solution goes to $\frac{l}{a}$ as $x \to +\infty$. This was proven by using the Laplace Transform and the final value theorem, as well as L'Hopital's rule and the Fundamental Theorem of Calculus. We also discussed the case where $l=0$ and showed that the limit is still $\frac{l}{a}$. However, we were unable to determine anything about the limit $\lim_{x \to +\infty} e^{-ax} \int_0^x e^{at} b(t) dt$.
evinda
MHB
3,836
Hello! (Wave)Let the (linear) differential equation $y'+ay=b(x)$ where $a>0, b$ continuous on $[0,+\infty)$ and $\lim_{x \to +\infty} b(x)=l \in \mathbb{R}$.
Show that each solution of the differential equation goes to $\frac{l}{a}$ while $x \to +\infty$,
i.e. if $\phi$ is any solution of the differential equation, show that $\lim_{x \to +\infty} \phi(x)=\frac{l}{a}$.
That's what I have tried:
The solution of the differential equation will be of the form:
$\phi(x)=ce^{-ax}+e^{-ax} \int_0^x e^{at}b(t) dt$
$\lim_{x \to +\infty} c e^{-ax}=0$
So, $\lim_{x \to +\infty} \phi(x)=\lim_{x \to +\infty} e^{-ax} \int_0^x e^{at}b(t)dt$How can we calculate the limit $\lim_{x \to +\infty} e^{-ax} \int_0^x e^{at}b(t)dt$ ? (Thinking)
The problem is easily solved using the Laplace Transform... in term of the s variable the solution is...
$\displaystyle Y(s) = \frac{B(s) - y(0)}{s + a}\ (1)$
... and applying the final value theorem is...
$\displaystyle \lim_{s \rightarrow 0} s\ B(s) = l\ (2)$
$\displaystyle \lim_{ x \rightarrow \infty} y(x) = \lim_{s \rightarrow 0} \frac{s\ [B(s) - y(0)]}{ s + a}\ (3)$
... so that is...
$\displaystyle \lim_{ x \rightarrow \infty} y(x) = \frac{l}{a}\ (4)$
Kind regards
$\chi$ $\sigma$
Hi evinda,
First consider \(\displaystyle l\neq 0.\) Note that this implies
\(\displaystyle \lim_{x\rightarrow\infty}\int_{0}^{x}e^{at}b(t)dt\)
diverges (to \(\displaystyle \pm\infty,\) depending on the sign of \(\displaystyle l\)). Hence, we can compute the limit for \(\displaystyle l\neq 0\) using L'Hopital's rule and the Fundamental Theorem of Calculus.Next consider \(\displaystyle l=0.\) Note that we have the inequality
\(\displaystyle \left|\int_{0}^{x}e^{at}b(t)dt \right|\leq \int_{0}^{x}e^{at}|b(t)|dt\qquad\forall x\)
Now, either the integral on the right either converges to a number \(\displaystyle M\) that is finite or it diverges to \(\displaystyle +\infty\) as \(\displaystyle x\rightarrow\infty.\) If the integral converges as \(\displaystyle x\rightarrow\infty\), then the above inequality shows that
\(\displaystyle \lim_{x\rightarrow\infty}e^{-ax}\int_{0}^{x}e^{at}b(t)dt=0,\)
as desired. If the integral
\(\displaystyle \int_{0}^{x}e^{at}|b(t)|dt\)
diverges as \(\displaystyle x\rightarrow\infty\), then we can once again use L'Hopital's rule and the Fundamental Theorem of Calculus to get that the limit is zero. Let me know if anything is unclear/not quite right.
GJA said:
Hi evinda,
How do we deduce that \(\displaystyle \lim_{x\rightarrow\infty}\int_{0}^{x}e^{at}b(t)dt\) diverges to \(\displaystyle \pm\infty\) ? (Thinking)
Suppose \(\displaystyle l>0.\) Since \(\displaystyle \lim_{x\rightarrow\infty}b(x)=l,\) there is \(\displaystyle N>0\) such that
\(\displaystyle \frac{l}{2}<b(x)\qquad\forall x\geq N\)
It then follows that
\(\displaystyle \infty = \frac{l}{2}\int_{N}^{\infty}e^{at}dt\leq \int_{N}^{\infty}e^{at}b(t)dt\)
I would try writing the proof for \(\displaystyle l<0\) using the above as a guide. Let me know if anything is unclear/not quite right.
GJA said:
If the integral
If \(\displaystyle \int_{0}^{x}e^{at}|b(t)|dt\) diverges, we cannot deduce that $\int_0^x e^{at} b(t) dt$ diverges, or can we? (Thinking)
You're 100% correct, we cannot conclude $\int_0^x e^{at} b(t) dt$ diverges as well - this was not part of the claim in the previous posts. Fortunately, we don't need to conclude this for the method outlined earlier.
In assuming $\int_{0}^{x}e^{at}|b(t)|dt$ diverges as $x\rightarrow\infty$, we can calculate the limit you want in your original post (using $\int_{0}^{x}e^{at}|b(t)|dt$ instead of $\int_{0}^{x}e^{at}b(t)dt$) via the Fundamental Theorem of Calculus and L'Hopital's Rule. If you haven't done this computation yet, give it a shot and see what you get. Then look at the inequality again. As before, I'm certain you can do this, so I am doing my best to avoid writing out all the details. Let me know, though, if you get stuck and I will help some more. Let me know if anything is unclear/not quite right.
Then it will be like that:
$$\lim_{x \to +\infty} e^{-ax} \int_0^x e^{at} |b(t)| dt= \lim_{x \to +\infty} \frac{\int_0^x e^{at} |b(t)| dt}{e^{ax}}= \lim_{x \to +\infty} \frac{e^{ax} |b(x)|}{a e^{ax}} dt \to \frac{|l|}{a}$$
Right?
However, having found this limit can we say something about the limit $\lim_{x \to +\infty} e^{-ax} \int_0^x e^{at} b(t) dt$? :confused:From the inequality don't we get that $-\frac{|l|}{a} \leq \lim_{x \to +\infty} e^{-ax} \int_0^x e^{at} b(t) dt \leq \frac{|l|}{a}$?
But this doen't help, or does it?
We need to recall what $l$ was in this case to finish the problem...
You mean that we have to use the fact that $\lim_{x \to +\infty} b(x)=l$? How does this help? (Thinking)
We knew specifically what $l$ was in the context of the argument you're quoting. Take a look at my previous post and you'll find the answer.
FAQ: How could we calculate the limit?
What is a limit in mathematics?
A limit in mathematics is the value that a function approaches as its input approaches a certain value. It represents the behavior of a function at a particular point and is an important concept in calculus.
How do we calculate a limit using the limit definition?
The limit definition is used to calculate the limit of a function. It involves evaluating the function at values approaching the given point and observing the trend in the output values. The limit is then determined by taking the limit of the output values as the input values get closer and closer to the given point.
What is the difference between a one-sided limit and a two-sided limit?
A one-sided limit only considers the behavior of a function as the input approaches the given point from one direction (either the left or the right). A two-sided limit, on the other hand, takes into account the behavior of the function from both directions as the input approaches the given point.
What are some common techniques used to evaluate limits?
Some common techniques used to evaluate limits include substitution, factoring, rationalization, and using limit laws such as the sum, difference, product, and quotient laws. L'Hopital's rule and Taylor series expansions are also commonly used for more complex functions.
Why is it important to calculate limits in mathematics?
Calculating limits is essential in understanding the behavior of functions and their properties. It allows us to determine important characteristics such as continuity, differentiability, and asymptotic behavior. Limits are also used in many real-life applications, such as in physics and engineering, to model and predict various phenomena.
