How did Eratosthenes measure the earth's circumference
In summary, Eratosthenes of Cyrene was a Greek mathematician, geographer, poet, astronomer, and music theorist who was able to measure the Earth's circumference using simple tools and geometry. He did this by measuring the sun's angle of elevation at noon on the summer solstice in two cities and using the distance between them to calculate the Earth's circumference. This measurement was later confirmed by other methods. Despite this, the common belief at the time was that the Earth was flat, and Columbus was one of the few who believed that Eratosthenes was wrong about the size of the Earth. However, his voyage to the "new lands" proved otherwise.
The mentalist
Hello everybody,
Eratosthenes of Cyrene ( 276 BC– 195 BC) was a Greek mathematician, geographer, poet, astronomer, and music theorist.The interesting thing about his biography,is that he was able to measure the Earth's circumference using only simple tools and good geometry .here is a video of Carl Sagan explains how he did it .
http://m.youtube.com/watch?v=0JHEqBLG650
Mathematics news on Phys.org
If you can't follow his calculation, feel free to ask me.
This is what wikipedia tells us:
"Eratosthenes calculated the circumference of the Earth without leaving Egypt. Eratosthenes knew that, on the summer solstice, at local noon in the Ancient Egyptian city of Swenet (known in Greek as Syene, and in the modern day as Aswan) on the Tropic of Cancer, the sun would appear at the zenith, directly overhead (he had been told that the shadow of someone looking down a deep well would block the reflection of the Sun at noon). Using a gnomon, he measured the sun's angle of elevation at noon on the solstice in his hometown of Alexandria, and found it to be 1/50th of a circle (7°12') south of the zenith. He could have used a compass to measure the angle of the shadow cast. Assuming that the Earth was spherical (360°), and that Alexandria was due north of Syene, he concluded that the meridian arc distance from Alexandria to Syene must therefore be 1/50 = 7°12'/360°, and was therefore 1/50 of the total circumference of the Earth. His knowledge of the size of Egypt after many generations of surveying trips for the Pharaonic bookkeepers gave a distance between the cities of 5,000 stadia (about 500 geographical miles or 927.7 km). This distance was corroborated by inquiring about the time that it takes to travel from Syene to Alexandria by camel. He rounded the result to a final value of 700 stadia per degree, which implies a circumference of 252,000 stadia. The exact size of the stadion he used is frequently debated. The common Attic stadion was about 185 m, which would imply a circumference of 46,620 km, which is off the actual circumference by 16.3%. However, if we assume that Eratosthenes used the "Egyptian stadion" of about 157.5 m, his measurement turns out to be 39,690 km, an error of 1.6%."
By the way, everybody "learns" in elementary school that Christopher Columbus differed from everyone else of his time because he believe the world was round while every one else believed it was flat. That, of course, is untrue. Every educated person (and, as far as geography is concerned that would include sea captains) knew the world was round and most knew the size from Erastosthene's calculation.
Columbus was one of a minority of people of the time who believed Eratosthenes was wrong. Their reason was, essentially, a "stylistic" one- they refused to believe that half of the world was full of land (Europe, Africa, Asia) while the other half was empty ocean. Of course, they were wrong- and the other half of the world was full of "new lands".
Just to clarify, Columbus didn't think Eratosthenes was wrong about the shape of the Earth, just the size. The funniest part is that in that false story, it's often claimed that Columbus "proved" that the Earth was round. I guess going a little further west than before and then returning just isn't possible on a flat Earth!
Hello there,
Eratosthenes used a method known as the "Stade Method" to measure the Earth's circumference. He first measured the distance between two cities, Alexandria and Syene, using a unit of measurement called a "stade" which was equivalent to about 185 meters. He then observed that on the summer solstice, the sun was directly overhead in Syene, casting no shadows. However, in Alexandria, there was a slight shadow cast by objects on the ground. Using this information, he was able to calculate the angle of the sun's rays hitting the Earth at both locations. With this angle and the distance between the two cities, he was able to use basic geometry to estimate the circumference of the Earth. His calculations were remarkably close to the actual measurement, which is why his method is still considered one of the most accurate ways to measure the Earth's circumference.
Related to How did Eratosthenes measure the earth's circumference
1. How did Eratosthenes come up with the idea to measure the earth's circumference?
Eratosthenes was a Greek mathematician and astronomer who noticed that at noon on the summer solstice, the sun shone directly down a well in the city of Syene (modern-day Aswan, Egypt), casting no shadow. This led him to believe that the sun was directly overhead at that location, and he wondered if the same was true at his own location in Alexandria.
2. How did Eratosthenes measure the distance between Syene and Alexandria?
Eratosthenes hired a group of men to pace out the distance between the two cities, using their own strides as units of measurement. He then used this distance, along with the angle of the sun's shadow in Alexandria, to calculate the circumference of the earth.
3. Was Eratosthenes' measurement accurate?
Eratosthenes' calculation of the earth's circumference was remarkably accurate, considering the limited technology and resources available at the time. His estimate was only off by about 2% from the actual value, which is quite impressive.
4. How did Eratosthenes' measurement impact future scientific discoveries?
Eratosthenes' measurement of the earth's circumference was a significant contribution to the field of geography and cartography. It also served as a foundation for future scientists to build upon, leading to a better understanding of the earth and its place in the universe.
5. Is Eratosthenes' method still used today to measure the earth's circumference?
Eratosthenes' method is not used in its original form today, as technology has advanced and more accurate methods have been developed. However, his basic concept of using the sun's angle and distance between two locations is still used in modern methods of measuring the earth's circumference.
15K
  • Art, Music, History, and Linguistics
  • Other Physics Topics
  • STEM Academic Advising
