I How did Hamilton derive the characteristic function V in his essay?
Hamilton derives the characteristic function V in his essay by varying the function U and establishing relationships between kinetic energy T, potential energy U, and Hamiltonian H. He uses the principles of calculus of variations to manipulate integrals and derive the expression for δV. This involves integrating by parts and applying identities related to variations of the coordinates and velocities. The final result expresses δV in terms of variations of both initial and final conditions, along with the term involving δH. The discussion highlights the mathematical rigor in Hamilton's approach to dynamics and the foundational role of calculus of variations in his derivations.
selim
In Hamilton's "on a general method in dynamics", he starts with varying the function ##U## and writes the equation:
$$\delta U=\sum m(\ddot x\delta x+\ddot y\delta y+\ddot z\delta z)$$
Then he defines ##T## to be:
$$T=\frac{1}{2}\sum m (\dot x^2+\dot y^2+\dot z^2)$$
Then by ##dT=dU##, he writes:
$$T=U+H$$
Then he varies T and writes:
$$\delta T= \delta U+\delta H$$
note that he is also varying in the initial conditions, that's why he did not omit the term ##\delta H##.
Hamilton then multiplies this expression by dt and integrates and writes it as:
$$\int\sum m(dx \delta \dot x+dy \delta \dot y+dz \delta \dot z)=\int\sum m(d \dot x \delta x+d \dot y \delta y+d \dot z \delta z)+\int\delta H dt$$
Then comes the part where I got confused. He says "that is, by the principles of the calculus of variations" and writes:
$$\delta V=\sum m(\dot x \delta x+\dot y \delta y+\dot z \delta z)-\sum m(\dot a \delta a+\dot b \delta b+\dot c \delta c)+\delta H t$$
where (x,y,z) and (a,b,c) are final and initial conditions then he denotes V by the integral:
$$V=\int\sum m(\dot x \delta x+\dot y \delta y+\dot z \delta z)$$
My questions are as follows:
1-how did he get ##\delta V##, what "principle of the calculus of variations" did he use?
2-then how from that did he get the integral ##V##?
To my shame I must admit that I've never read the original writings by Hamilton on his action principle. Do you have a reference?
Equation (B) of the paper gives the definition of ##V##: $$V \equiv \int \sum m(\dot x dx + \dot y dy + \dot z dz) = \int_0^t 2T dt \,\,\,\,\,\,\,\, (B)$$
With the definition (B) and some manipulations, you can derive the expression for ##\delta V## given in equation (A) of the paper. Start with equation (10) of the paper: $$\int \sum m(dx \delta \dot x + dy \delta \dot y + dz \delta \dot z) = \int \sum m(d \dot x \delta x + d \dot y \delta y + d \dot z \delta z) + \int \delta H dt \,\,\,\,\,\,\,\, (10)$$
The left-hand side of (10) is ##\int \delta T dt##. The last term on the right is just ##t \delta H## because ##H## is independent of time. So, (10) can be written as $$\int \delta T dt = \int \sum m(d \dot x \delta x + d \dot y \delta y + d \dot z \delta z) + t \delta H $$
The integral on the right can be manipulated using integration by parts. For example,
$$\int_0^t m d \dot x \delta x = \int_0^t m (\frac{d \dot x}{dt}) \delta x dt = m \dot x \delta x \bigg|_0^t - \int_0^t m\dot x \frac{d}{dt}(\delta x) dt$$ Since ##\frac{d}{dt}(\delta x) = \delta \dot x## and ##\dot x dt = dx##, we get $$\int_0^t m d \dot x \delta x = m \dot x \delta x \bigg|_0^t - \int_0^t m dx \delta \dot x = m \dot x \delta x - m\dot a \delta a - \int_0^t m dx \delta \dot x$$ The first term on the far right, ##m \dot x \delta x##, is to be evaluated at the time ##t## of the upper limit of the integration.
##\dot a## and ##\delta a## represent evaluation of ##\dot x## and ##\delta x## at the initial time ##t = 0##.
Doing the same thing for the ##\dot y \delta y## and ##\dot z \delta z## integrations in (10), you can see that equation (10) may be written as $$\int \delta T dt = \sum m ( \dot x \delta x + \dot y \delta y + \dot z \delta z ) - \sum m ( \dot a \delta a+ \dot b \delta b + \dot c \delta c) - \int \delta T dt - t \delta H$$ or $$2\int_0^t \delta T dt = \sum m ( \dot x \delta x + \dot y \delta y + \dot z \delta z ) - \sum m( \dot a \delta a+ \dot b \delta b + \dot c \delta c ) - t \delta H$$ According to (B), the left side is ## \delta V##. So, we finally get equation (A) $$\delta V= \Sigma m\left( \dot x \delta x + \dot y \delta y + \dot z \delta z \right) - \sum m ( \dot a \delta a+ \dot b \delta b + \dot c \delta c) - t \delta H$$
I'm unsure what Hamilton meant when he stated "by the principles of the calculus of variations". Here, we used integration by parts and the use of identities such as ##\frac{d}{dt}(\delta x) = \delta \dot x##. These are often used in derivations in the calculus of variations.
  • Wow
  • Love
Likes SammyS, vanhees71 and selim
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
