How Did James Bond Survive Being Placed in a Vat of Acid?
  • Thread starter jamesb-uk
In summary, James Bond swam underwater to get into the villain's base. When he arrived, he was discovered and placed in a vat of very strong acid. He survived by wearing a wetsuit which retained water and by moving into the vat fairly.
  • #36
jamesb-uk said:
I'm still unsure about how much acid there would be or how much there would be in the rebreather. To be honest, when I heard this, I didn't really go into the answer in as much detail as you obviously want from me.
Well, junglebeast asked in post #2:
3) Is the answer you're looking for actually physically plausible?
So, the real answer should have been "I don't know", or, quite probably "no, it's not".
[edit]Looking at Sofnolime (one of the products used in rebreathers), the smallest size sold is about 10 lbs, which probably covers multiple dives (I couldn't find out how many dives with a quick search). If we assume the whole 10 lbs is used in a SINGLE dive, and assume it's solid calcium hydroxide (which it isn't), that's about 61.2 moles. And if we assume a vat of "pure" sulfuric acid, with a volume of about 30 square feet, that's approximately 15936.9 moles. So about 0.4% of the sulfuric acid would get neutralized, which does bring down the concentration of the acid, but not by a lot.[/edit]
DaveE
  • #37
In my defense, I did hear this question from someone who knows quite a lot about chemistry.
What's the volume of an average person though. I've been doing a bit of research, and I've found values ranging from 1/2 m3, to 10m3(which I think is far too large). If the vat is about 0.7*2m, then he is going to be taking up quite a volume compared to the acid. The acid may not be completely pure as well, maybe only 70 or 80% of the volume could kill someone. Of course this would slow the reaction down, but there could be a long time period between inserting the chemical and him entering the acid.
Perhaps he may be harmed a little, but this may only consist of minor burns.
Perhaps he was only in there for a couple of minutes.
  • #38
:zzz:
  • #39
Well, I'm guessing Bond weighs about 180 lbs, which is roughly 81.6466266 kg. The human body is mostly water, and 1 liter of water is about 1 kg, so that's also about 81.6466266 liters, or 2.88 cubic feet. Really, the human body isn't quite as dense as water, so you can inflate that number by a bit, but I'm not sure by how much. Perhaps 3-4 cubic feet. Then there's all his gear and so forth, which probably isn't quite as voluminous as he is. But just to be safe, I was going with 10 cubic feet, tops.
Just to make sure I'm reading this right-- you're implying 0.7 meters in diameter, and 2 meters high? That's pretty tight. That's 27.56" of diameter, which is narrow. I'm not particularly broad shouldered, and my shoulders are about 21" from left to right. Bond is probably more like 22"-24", and that's only a scant few inches of leeway. Plus he's got diving gear.
But that aside, let's keep going with your estimate. That's 0.35m radius => 1.148' radius => 4.142 square feet base. Times a height of 2m => 6.562', which yields 27.178 cubic feet. So subtracting the best-case scenario of 10 cubic feet of "Bond", you're left with 17.178 ft3 of acid to neutralize.
So let's do more math. How many moles of molecules of acid are in the vat? Well, 17.178 ft3 is 486426.791 cm3. According to Wikipedia, Sulfuric acid is about 1.84 g/cm3, so that's about 895025.295g of Sulfuric acid. Again according to wikipedia, it's got a molar mass of 98.08 g/mol, so you're talking about 9125.462 moles of molecules of acid. Now, based on my outrageous assumption above that he's got 10 lbs of Sofnolime in his rebreather, and that it's 100% calcium hydroxide, he'd have roughly 61.2 moles with which to neutralize and dilute the acid. That's about 0.671% of the acid that's going to get diluted. Now, that's almost twice as much as I estimated before (because I think the vat ought to be bigger), but still, it's not much. And keep in mind that that's attempting to overestimate in Bond's favor by ludicrously high amounts at every turn, and we're STILL coming up with only 0.671%.
As you stated, we don't know what the pH level of the acid is-- but bringing it down by 0.671% isn't going to change it significantly.
Chances are, dissolving his air tank and other gear prior to getting in is going to have a better effect than just the calcium hydroxide, but the two in combination aren't going to do anything wonderful. They'll dilute the acid by a small margin, but since the pH level is logarithmic, I think you'd be extraordinarily lucky to even see half a point of change in the pH level.
Anyway, the bottom line seems to be that if the acid is very weak, then yes, dropping in the calcium hydroxide may be JUST enough to tip it in favor of him surviving or making it out unharmed. But he doesn't have enough to make it all that much more effective than simply dropping in, say, 15 lbs of water.
If (say) the situation were that he was about to be SPRAYED with acid from a 2 gallon jug, and could stealthily slip in his Sofnolime somehow (without melting the jug with the heat of the reaction or something), then yeah, I'm all for it being plausible. But there's just too much acid in a human-sized vat for it to make much difference.
DaveE
