How did Planck come up with 'h'?
  • Thread starter Potentiator
  • Tags
    Planck
In summary, Planck's derivation of the constant of nature (h) was based on his attempt to find the empirical basis for his theory of quantized radiation, which states that energy can only be transferred in small lumps. He was inspired by Boltzmann and used this concept to solve problems in thermodynamics. The justification for using this precise value is still unclear, but it has been experimentally measured and has been used in many modern physics concepts, such as Einstein's explanation of the photoelectric effect. Planck did not measure this constant himself, but it has been used successfully in various experiments and its value has been refined over time.
Potentiator
23
In my new found passion to understand the "inner meaning" of this thing called quantum theory, I've been trying to find Planck's derivation of -- or explanation for choosing -- the "constant of nature" that has become so popular.
I expected to be able to find the empirical basis for it very easily on google, but all I could find were explanations like, "a photon is a unit of radiation whose energy content can be found by E=hv." Well, this doesn't help me too much.
The closest thing I have been able to find to an "explanation" is from this article...
http://physicsworld.com/cws/article/print/373
To find W, Planck had to be able to count the number of ways a given energy can be distributed among a set of oscillators. It was in order to find this counting procedure that Planck, inspired by Boltzmann, introduced what he called "energy elements", namely the assumption that the total energy of the black-body oscillators, E, is divided into finite portions of energy, epsilon, via a process known as "quantization". In his seminal paper published in late 1900 and presented to the German Physical Society on 14 December - 100 years ago this month - Planck regarded the energy "as made up of a completely determinate number of finite equal parts, and for this purpose I use the constant of nature h = 6.55 x 10-27 (erg sec)". Moreover, he continued, "this constant, once multiplied by the common frequency of the resonators, gives the energy element epsilon in ergs, and by division of E by epsilon we get the number P of energy elements to be distributed over the N resonators".
What's the reason for using this precise value?
You can measure it experimentally.
You use a vacuum tube and excite electrons from the cathode with a light source of known wavelength and measure the voltage across the tube.
You can then get h/e from the slope - without having to know the work function of the cathode. If you know e you can get h.
It fitted an equation to experimental data, in his case of dependence of intensity of radiation on frequency for black body, that was the start of it all.
Thanks. Can you point me in a direction where someone has actually done this? I'm looking for experimental details...
Milikan did it originally in 1916 but you still have to pay for access to the paper !
http://focus.aps.org/story/v3/st23
There are lots of ugrad lab classes on the web describing it.
These are the first things in any textbook that goes beyond classical or elementary physics - as the fact of my knowing them proves. :smile:
It's also quite an easy experiment to do nowadays with LEDs and vacuum tubes.
Unlike Milikan's other experiments - it actualy works!
Thanks for the heads up on Milikan. However, the question still remains: What was Planck's justification for using it in 1900? I mean, how did the inventor of h derive it?
Sorry - Planck didn't measure it, and apparently didn't really believe in it!
He just realized mathemtically that if you made energy changes only available in discrete lumps it solved some problems in thermodynamics. Einstein used the idea to explain the photoelectric effect - so it's really as much Einstein's constant as Planck's.
Sometimes it takes centuries for the experiment to measure a constant proposed by a theory - it took a long time for the speed of light and the gravitational constant G to be measured accurately.
Planck came up with the idea of quantized radiation and the constant we know as h, in deriving a formula to fit the observed spectrum from a hot "black body." The details are covered in many introductory modern physics textbooks, e.g. Beiser, "Concepts of Modern Physics", section 2.2; Krane, "Modern Physics", section 3.3; Ohanian, "Modern Physics", section 3.1.
You might find these details on line by Googling for "black body radiation" or "blackbody radiation" or "Planck radiation formula".
So, where in the heck did it come from? Did manna from heaven fall into his lap?:smile:
Why did he pick these precise discrete lumps that now seem to fit so perfectly with empirical observation? Are you saying that the mathematics just "manifested it"?
I don't think that a constant is the reason why the Rayleigh-Jeans Law was a failure. Wein's displacement law is the thing that corrected it, and it had nothing to do with a simple constant.
No he came up with the idea that if you only allow energy to transfer in small lumps then some problems in thermodynamics are solved. He didn't need to know what value h had - just that it was very small.
It's the same as Newton's law of gravity - he knew that if the gravitational force was proportional the product of the masses and the distance squared then the orbits of planets worked out. It wasn't until a 100years later that Cavendish worked out what the value of 'G' was.
Planck, in 1900 used: 6.55 x 10-34 J s
(source in first post)
The NIST standard, in 2008 says: 6.62606896 x 10-34 J s
(source:http://physics.nist.gov/cgi-bin/cuu/Value?h)
I'm assuming this is just a lucky guess?
Interesting - I hadn't realisied Planck had actually got a value
You can derive it quite easily from Wien's law, which tells you frequency of the peak on the curve predicted by Planck's equation - of course this relies on you having a good value for Wien's constant!
Planck's original paper (translated!) http://dbhs.wvusd.k12.ca.us/webdocs/Chem-History/Planck-1901/Planck-1901.html
Yes... this is all very interesting, indeed. I'm doing my best to trace this thing back in history. My guess that Boltzmann is going to end up being known as the "real" father of QM!
Post # 3 is as close as you'll get:
Wilhelm Wien...showed that under adiabatic expansion or contraction, the energy of light changes in the exact same way as the frequency. This means that the peak frequency should change with temperature as the energy goes. Wien did not interpret his constant b as a new fundamental constant of nature. This was done by Planck.
http://en.wikipedia.org/wiki/Wien_displacement_law
I'm sitting here reading Kuhn's "Black Body Theory and the Quantum Discontinuity 1894-1912". This is an extremely in depth look into the origins of QM.
The first mention of the "b" constant that eventually becomes Planck's "h" is mentioned here:
Planck then, with no preparatory argument whatsoever, simply "defines" [Kuhn's quotes] the entropy of a resonator of frequency v and energy U by the equation
S = (-U/av)log(U/ebv),
where e is the base of natural logarithms and "a and b are two universal positive constants the numerical values of which in the absolute c.g.s. system will be developed from thermodynamics in the next section".
The internal quote from Planck is footnoted as: "Funfte Mittheilung" (Planck, 1899), p. 465; I, 585.
Hello, thermodynamics! The plot thickens...
Oh yeah? I'm reading a source of a source of a Wikipedia article!
In p. 104 of Kuhn's book, already cited:
To compute the entropy of an arbitrary distribution Planck must introduce combinatorials, and for this purpose he follows Boltzmann in subdividing the energy continuum into elements of finite size. It is at this point that he introduces the further novelty that was soon to prove the most consequential of all. For his purpose, unlike Boltzmann's, the size of the energy elements epsilon, epsilon-prime, epsilon-2prime, etc., must be fixed and proportional to frequency. Consideration of that vital step is the subject of the next chapter, but the passage in which Planck introduces it must be noted here, for it illustrates an aspect of his lecture that helped mislead readers about his intent.
"The distribution of energy over each type of resonator must now be considered, first the distribution of the energy E over the N resonators with frequency v. If E is regarded as infinitely divisible, an infinite number of different distributions is possible. We, however, consider -- and this is the essential point -- E to be coposed of a determinate number of equal parts and employ in their determination the natural constant h = 6.55 x 10-27 (erg x sec). This constant multiplied by the frequency, v, of the resonator yields the energy element epsilon in ergs, and, dividing E by epsilon, we obtain the number, P, of energy elements to be distributed over the N resonators." [Citation: "Zur Theorie des Gesetzes" (Planck, 1900e), pp. 239f.; I, 700f.]
Because Planck, here and for some time after, considers only the single set of resonators with frequency v and because he later omits the computation of a maximum, which would have demanded explicit recourse to resonators at other frequencies, the difference between his argument and that of Lorentz is obscured.
From what I understand of Kuhn's argument, Planck's use of Boltzmann's combinatorial method as applied to Wein's empirically correct law is the thing that got this whole "integer only energy quanta" thing off the ground...
Okay, this is what I've been looking for. h (Planck's) is nothing other that k (Boltzmann's). k is simply the gas constant (8.314472 J/K mol) divided by the Avogadro constant (6.02214179 entities per mol). There is apparently a controversy about who deserves credit for "discovering" this thing. According to http://en.wikipedia.org/wiki/Boltzmann_constant#Historical_note, Planck wrote in his Nobel Prize lecture:
"This constant is often referred to as Boltzmann's constant, although, to my knowledge, Boltzmann himself never introduced it — a peculiar state of affairs, which can be explained by the fact that Boltzmann, as appears from his occasional utterances, never gave thought to the possibility of carrying out an exact measurement of the constant."
It seems as though Planck was positively obsessed with proving the laws of thermodynamics on the "micro" rather than on the "statistical" level; the latter is all that concerned Boltzmann. According to Kuhn, Planck did quite a lot of "mathematical fudging," and his proofs did not impress too many of his peer reviewers in the time around December 1900.
But the "atomists" were ready and waiting to jump on anything that would bring Maxwell's continuous energy relations into a discrete form. So, when Einstein came along and popularized h in his own work, the physics world was primed for one heck of a party over the next few decades.
No. Planck's constant and Boltzmann's constant are two different things. They even have different units.
http://www.knowledgerush.com/kr/encyclopedia/Planck_time/
==quote==
Max Planck's creation of the natural units
Max Planck first listed his set of units (and gave values for them remarkably close to those used today) in May of 1899 in a paper presented to the Prussian Academy of Sciences. Max Planck: 'Über irreversible Strahlungsvorgänge'. Sitzungsberichte der Preußischen Akademie der Wissenschaften, vol. 5, p. 479 (1899). At the time he presented the units, quantum mechanics had not been invented. He himself had not yet discovered the theory of blackbody radiation (first published December 1900) in which the constant h made its first appearance and for which Planck was later awarded the Nobel prize. The relevant parts of Planck's 1899 paper leave some confusion as to how he managed to come up with the units of time, length, mass, temperature etc. which today we define using h-bar and motivate by references to quantum physics before things like h-bar and quantum physics were known. Here's a quote from the 1899 paper that gives an idea of how Planck thought about the set of units.
...ihre Bedeutung für alle Zeiten und für alle, auch ausserirdische und ausser menschliche Culturen nothwendig behalten und welche daher als 'natürliche Maasseinheiten' bezeichnet werden können...
...These necessarily retain their meaning for all times and for all civilizations, even extraterrestrial and non-human ones, and can therefore be designated as 'natural units'...
==endquote==
I've seen the German text of the 1899 article and I have an English translation somewhere. He gives a value for h that is very close to the right one, but it is hard to see how he came by it. He found it before the black body radiation law.
The title of the 1899 paper is "On irreversible radiation processes". If I remember right, he delivered it sometime late spring or early summer to the Prussian Academy of Sciences in Berlin.
Maybe googling the title would come up with an online copy.
This 46 page article looks promising - I haven't read it yet:
Planck, the Quantum, and the Historians
Clayton A. Gearhart Phys. perspect. 4 (2002) 170–215
http://employees.csbsju.edu/cgearhart/pubs/PQH.pdf
Translations to accompany it:
http://employees.csbsju.edu/cgearhart/Planck/planck_1906.pdf
This contains detailed discussion of how Planck developed his blackbody formula, in particular concerning how he approached entropy.
I found this as one of a bunch of interesting looking papers at:
http://enjoy.phy.ntnu.edu.tw/course/view.php?id=120#section2
Also, perhaps (if one could get the text):
The Historians' Disagreements over the Meaning of Planck's Quantum
Darrigol, O Centaurus, Volume 43, Numbers 3-4, 1 December 2001 , pp. 219-239(21)
http://www.ingentaconnect.com/content/mksg/cnt/2001/00000043/F0020003/art00044
and
"Max Planck and black-body radiation," essay in Dieter Hoffmann, ed., Max Planck:
Annalen Papers (Wiley-VCH (2008), 395¬–414).
http://employees.csbsju.edu/cgearhart/pubs/sel_pubs.htm
- Robin
I have started reading the Clayton Gearhart paper mentioned in my previous message and am finding it most helpful.
Here is another overview which looks promising: Chapter 3 - Thermal Radiation and Planck's 'Energy Elements' in:
Quantum Mechanics: Its Early Development and the Road to Entanglement‎
by Edward G. Steward Imperial College Press 2008
I found this chapter was available at http://books.google.com.
I found Figure 3.3 helpful. It depicts the black-body spectrum together with the curves of Wien's Distribution and Rayleigh-Jeans laws.
- Robin
Yours is basically a history question, so fortunately there is a unique answer! I suggest reading the first chapter of Resnick-Eisberg to get a lucid answer to your question and then some.
Related to How did Planck come up with 'h'?
1. How did Planck discover the value of 'h'?
Planck discovered the value of 'h' through his work on blackbody radiation in the late 19th century. He noticed that the energy of radiation emitted by a blackbody could not be explained by classical physics, leading him to develop his famous equation E=hf, where 'h' represents a constant that determines the energy of a single quantum of radiation.
2. What did Planck's discovery of 'h' contribute to the field of physics?
Planck's discovery of 'h' was a crucial step in the development of quantum mechanics. It helped to explain the behavior of subatomic particles and paved the way for future advancements in the field of physics, including the discovery of the photoelectric effect by Einstein and the development of the modern atomic model by Bohr.
3. How did Planck's theory of blackbody radiation lead to the discovery of 'h'?
Planck's theory of blackbody radiation was based on the assumption that energy could only be emitted or absorbed in discrete units, rather than continuously. This led him to develop his equation E=hf, where 'h' represents the constant that determines the energy of a single quantum of radiation. This discovery of 'h' was a direct result of his work on blackbody radiation.
4. How did Planck's discovery of 'h' challenge classical physics?
Planck's discovery of 'h' challenged classical physics by showing that the energy of a system was not continuous, as predicted by classical physics, but rather was quantized in discrete units. This went against the established principles of classical physics and opened the door to the development of quantum mechanics.
5. How has the value of 'h' been refined since Planck's discovery?
The value of 'h' has been refined since Planck's discovery through various experiments and advancements in technology. Today, the most precise value of 'h' is known as the Planck constant, which is 6.62607015 × 10^-34 joule seconds. This value has been determined through multiple experiments and is considered a fundamental constant in modern physics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Other Physics Topics
  • Quantum Physics
