How did spacetime pop out into existence?
In summary: This is incorrect. In FLRW solutions, the scale factor (which describes the expansion of the universe) goes to zero at the beginning of time (t=0), not the space and time coordinates themselves. As I mentioned before, time is an integral part of space-time and cannot be separated from it. The concept of a "moment of creation" or "big bang" is not necessarily accurate in this context, as it implies a beginning when in reality, space and time have always existed in some form.
dismachaerus
Hello,
Cosmology for the layman says that there was a time t=0 when the universe was created out of infinitesimal length distance and before that nothing existed not even time.
OK, but this rests on the assumption that there is always a manifold from which we cut off our space slices in the past until we reach a point where our space coordinates vanish. The space coordinates disappear at t=0, not the manifold itself! So, the whole spacetime manifold must have popped out into existence at once!
I don't believe that space is evolving with time right now as we speak. After all, in SR the spacetime is a unified plane and there is no distinction between space or time.
So why layman books are saying that spacetime is expanding etc? It's only space that's expanding and any particular spacetime must be a static solution of the GR differential equations, given the initial conditions.
And it must have popped out into existence all at once, with everything in it that has been and will become in the future.
Is this correct or have I got it all wrong?
This is wrong. Space-time is the manifold, talking about the manifold "appearing" at some time is meaningless.
What you believe has little to do with actual physics. The expanding universe is the best model available at the present time.
This is space-time, not space as you were referring to when talking about space evolving.
They don't, at least not if they are at all accurate (which may be a big assumption). Space is expanding. Space-time is what it is and time is a part of it.
No this is wrong. You need to double check the definition of what a static space-time is. The FLRW space-time is not static.
I think your biggest problem is that you are trying to describe what space-time is in terms of time, but time is an integral part of space-time itself. Something that "pops" into existence intrinsically refers to it not existing at an earlier time, but the concept of time does not exist outside of space-time.
Likes bcrowell
I am not an expert, but I think you have 3 things wrong here (if someone says I'm wrong they're probably right).
1. As space expands, so does time. As you said, they are unified as spacetime. As space expands so does time. At any place that has time, there is space, and any point in space, there is time. They expand together.
2. Spacetime didn't come from nowhere. According to GR it was always there in infinitesimal quantities. At one point is was smaller than the Planck length (which is where we have a little conflict with QM).
3. There is no future. Unlike marvel, there is no destiny, or time travel. What has happened has happened, and the future can't be known.
No, you cannot say this. The expansion of space is that as the cosmological time parameter grows, the size of the scale factor increases. There is no corresponding thing for time.
As I said in my post, "to come from" is intrinsically assuming a time ordering where there was an earlier time when it did not exist - but it does not make sense to talk about time outside of space-time.
I do not see how this is at all related to the topic. Space-time is what it is, the past, future, and present are all part of it.
Please answer only things which you are reasonably certain about.
Likes bcrowell
This is what I was commenting on for number 3.
Orodruin, I think you haven't quite captured what I said.
Isaac0427, on the contrary has exactly understood what I am saying, although his answer is the exact opposite of what I am saying. I am saying the space is not static, any solution of the FLRW is ( sorry for my wording here! ) Any hyperbolic spatial coordinate circle on the hyperbolic space-time sphere say, has increasing radius with time, but the sphere which is the space-time itself does not evolve anywhere. It is spacetime, unending and unborn as it was created.
Ok, I have a better wording for this now. There is a manifold in FLRW solutions where at some point on its surface has all space and time coordinates vanishing and you take this as the moment of creation or big bang, right? But this manifold is all that there is, and because all the g's are vanishing somewhere in its metric this does not mean that it had a beginning.
You're assuming spacetime is a substance or physical quantity which exists independently of anything else. It may be better to think of spacetime as a way of describing the relative position of objects or events using advanced geometry. In other words, don't think of the math as being a physical entity.
This is more likely to mean that our understanding of physics is incomplete than anything else.
Consider standard latitude and longitude coordinates on a sphere. Would you say that the manifold disappears at the south pole, or that the latitude lines disappear there? Personally, I don't think that either is a good description. I would just say that the latitude coordinate ranges from -90 degrees to 90 degrees.
Likes Orodruin
Please correct me if I'm wrong (I probably am) but I thought that there was never a time t=0, because spacetime could be infinitely small, which means that it has always existed.
I must admit that I've made a mistake. Not only the space coordinates disappear somewhere on the manifold but the time coordinate as well. It's hard to visualize this but as an example I have the 2D hyperbolic torus x2 + y2=-r2 , z2 + w2=-r2 embedded in a 4D Euclidean space with signature (1,-1, 1,-1) as it degenerates when r=0.
Forgive me if this is incorrect, as my knowledge of GR is very rudimentary, but I believe both of you are still under the impression that spacetime is a physical object and that as we look backwards in time we see spacetime shrink. When we talk about the universe expanding (or contracting in the case of looking backwards in time) we mean that the material within space moves further apart (or closer together). There is nowhere to which you can point to, "Here is where spacetime ends", you can only point to a period in time, t = 0, and say that "Here is where our equations give us infinities and other nonsense".
I think the problem here is that the universe has no known radius. It could very well be infinitely large. Thus, as t approaches zero, the size of the universe doesn't get smaller, it is the density of matter and energy that grows without limit. You can, of course, talk about some volume of space of radius R, such as the radius of the observable universe, and see what happens to all matter within that volume as you take t back all the way to zero, but I'm not sure you can talk about "spacetime itself" contracting.
As always, someone correct me if I'm wrong.
What coordinates you put on a manifold and whether they can take particular values are irrelevant to the physics. It is not clear what you mean by coordinates "disappearing", but anything that can be fixed through a change of coordinate chart is not physical.
I think that's why I am talking about a manifold in the first place because coordinates are irrelevant. How then do you say that spacetime had a beginning since all the g's in the metric vanish somewhere, when all there is, is the manifold itself oblivious of anything around or beyond it?
Look at my torus. It's a perfect analogue of a 2D expanding infinite flat spacetime.When r=0 both the 2 coordinates of space and time you have laid to measure vanish. There does not exist a third ultra time co-ordinate. r is the curvature so to speak. At some point r=0 and is infinite, everywhere else has a number. I do not know of any other better mathematics to explain this.
Why should you say that a manifold was created when its curvature was infinite I cannot understand it. I think is like the interior solution of a black hole in reverse. Does the interior solution of a black hole in the universe disappear out of existence? I don't believe it.
Again, you cannot use this terminology. Time is not something that exists independent from space-time and so saying that space-time was "created" is a completely vacuous statement - it has no meaning.
When we are talking about a space-time having a "beginning", it is rather a statement of past-directed timelike curves being bounded in length (i.e., proper time).
Yes, this is similar to approaching the singularity in a Schwarzschild black hole but in reverse, all time-like future directed curves inside the event horizon have finite length. This does not mean that space-time "disappears". Disappearing is again something requiring a time concept which does not extend beyond the space-time itself.
When r=0, you do not have a smooth manifold. Or are you using r as a coordinate in a 2+1 dimensional space-time? It is unclear from your definition.
I'm not sure if this is what you meant, but I was under the impression that spcetime described an area with both space and time, and that area could get infinitely small as we look back in time, but there would always be some area with spacetime (yes, I know that there is no such thing as an area without spacetime, I just mean it still exists no mater how small). Is that correct? Now I'm not sure if this is stupid, but about t=0 and infinites in the equations, would it be possible that there was no t=0? Time could get infinitesimaly close to 0, but if space and time were always there at unimaginably small amounts. Maybe time moved a lot slower when spacetime was smaller. Has that ever been thought of before or am I getting something really wrong here?
Isaac0427 said:
Is that correct?
This is impossible to answer as it is not very clear what you are intending to say. Since most popular physics induced self-interpretations seem to be quite off, the best bet would be "no". What are you basing your assertions on? Can you formulate it in a better way?
Particularly vague statements are:
You are getting something completely wrong. How space-time (and in particular time) behaves is described by the metric, which links to the Einstein field equations to which the FLRW metric is a solution. You can easily change your time coordinate to a coordinate which extends to minus infinity, but this will not change the proper time of the curves in the manifold, which is coordinate independent. The point of chosing the standard coordinates is that the time coordinate t equates to the proper time of a comoving observer.
So what I was trying to say is I thought spacetime was like a geometrical object with all mater and light in it. As you go back in time, that object would get smaller in space, and as you go forward in time, it expanded. My other point was it would be a possibility that space could never equal 0, and nor could time. GR is fairly new to me, so I am just curious.
The point is that space-time does not "go back in time". Time is a part of space time. In the FLRW space-times, you can study a surface of cosmological simultaneity, defined by the set of events which have the same cosmological time. This defines what "space" is at that cosmological time and at later times, space is bigger and so we say that space expands.
You cannot do the same with time (there is only one time simultaneous with itself) and the correct thing would be to say that space expands, not that space-time expands. As I said in the previous post, the time coordinate is chosen precisely to correspond to the actual time of a comoving observer, you could pick a different parametrisation, but it will not change the physics.
In the FLRW cosmolgy, the size of the Universe is proportional to the scale factor. Since t=0 really is not part of the manifold, the scale factor is never zero.
Do not get me wrong, it is good to be curious. I just suggest that you try not to overinterpret or analyse popular science descriptions. Instead, if you really want to understand it and not have your ideas full of misconceptions, you need to study real textbooks (including those which are prerequisites for the ones you wish to get to), preferably at a university where you can get proper guidance from teachers.
Likes amir samiri
Thank you. I did not mean that physicists use this terminology but rather what the popularizing physics book say.
So, I think we have agreed that space-time as a whole has no beginning nor ending and therefore was 'never' created, -never- in quotes, because time does not exist independently of space-time itself but is part off and partakes in its definition.
Space-time does not pop out in existence out of nowhere as the layman books say, because this presupposes an ultra or extra time dimension beyond itself. Nor is it expanding or diminishing somewhere.
I am sorry, if I failed to explain myself in words in the first post.
Most serious popular science written by actual physicists will not claim this. Secondary accounts by non-physicists might (or physicists in completely different fields), but tha. Is then based on personal misunderstandings.
I don't think that's the best way to think of it. It's not that "t=0" does not exist, it's that the results of the standard model of cosmology (the big bang theory), if extrapolated back to t=0 give nonphysical results, showing that the model is incomplete. SOMETHING happened at t=0, but we don't know what.
What do people think may have happened?
I agree w/ Mordred. Too speculative to answer.
This is what I don't get. If t ever was 0, r would equal 0 too, which means spacetime wouldn't exist. Yes, I understand that there was never a time where spacetime didn't exist, but t=0 means time had a beginning. One of the most important things for me about science is things don't just happen, there is always a reason. Every effect has a cause, or I would classify it as magic. With t=0, there couldn't be a cause for spacetime, because there was nothing there. Unless this is magic, it seems to me that there must have been a cause for the Big Bang. To me, the only logical answer is that spacetime has always existed, or some condition that could provide a cause for the big bang. Am I wrong about this whole cause and effect thing?
Why do you find this harder to imagine than the Earth having a north pole?
You are again referring to something as if it was a causal connection without time inside. Whenever you look at any point in space-time, there is always an earlier time (the singularity at t = 0 is not really part of the space-time).
Can you please stop cutting up my posts, because I don't think you re understanding what I am saying. I'm not talking about a point in spacetime. Also, the North Pole has nothing to do with this. Please respond to the question, not my wording.
Orodruin has given a correct response. The fact that you don't like it simply indicates that you need to give it further thought.
  • #31
It does, it is a similar concept and you need to understand this in order to have any chance of understanding what is going on.
Have you stopped to consider that your wording is very relevant to what you are asking? That you are not able to put the question in a language that is appropriate is only indicative of the fact that you are not yet familiar enough with the mathematics which go into the description of how space-time behaves. As such, we can only give you something which is somewhat of a popularisation of the theory. The theory is self-consistent and described beautifully in mathematics, in order to understand it properly, you need to learn these branches of mathematics. It is not enough to read a popular account of things and "reason" based on what you have read.
Likes artyb
  • #32
Orodruin said:
It does, it is a similar concept and you need to understand this in order to have any chance of understanding what is going on.Have you stopped to consider that your wording is very relevant to what you are asking? That you are not able to put the question in a language that is appropriate is only indicative of the fact that you are not yet familiar enough with the mathematics which go into the description of how space-time behaves. As such, we can only give you something which is somewhat of a popularisation of the theory. The theory is self-consistent and described beautifully in mathematics, in order to understand it properly, you need to learn these branches of mathematics. It is not enough to read a popular account of things and "reason" based on what you have read.
Ok, but can you please give me a simple answer: is there something that would have caused the Big Bang, or are we just assuming it appeared.
  • #33
Because the North Pole is the effect of the Earth's positioning. Spacetime having a beginning seems to be the effect of nothing at all.
  • #34
It is the effect of a coordinate system having a point at which the coordinates do not tell you very much. It is different from the singularity of the FLRW space-time in that you can remove the singularity by imposing a different coordinate system, but similar in the sense that there is a point where the given coordinate system breaks down. Once you understand this, you can start thinking about a cone with the top point removed, this is to some extent more similar to the type of manifold you would deal with in the FLRW case.
You are back at arguing in a manner that you have been repeatedly told does not make sense. You cannot talk of appearing or cause without a time concept, which is an integral part of the space-time itself.
The OP has been answered several times over and you are going in circles here. Thread closed.
FAQ: How did spacetime pop out into existence?
What is spacetime?
Spacetime is the four-dimensional framework in which all physical events occur. It combines the three dimensions of space (length, width, and height) with the dimension of time to create a single entity.
How did spacetime come into existence?
The origin of spacetime is still a mystery and is a topic of ongoing scientific research. Some theories suggest that spacetime emerged from a singularity during the Big Bang, while others propose that it has always existed.
What evidence supports the existence of spacetime?
There are several pieces of evidence that support the existence of spacetime. One of the most significant is the observation of gravitational waves, which are ripples in the fabric of spacetime caused by massive objects moving through it. The bending of light by massive objects, such as stars, is also evidence of the curvature of spacetime.
Can spacetime be manipulated or altered?
According to Einstein's theory of general relativity, spacetime can be affected by the presence of mass and energy. This means that massive objects, such as planets and stars, can warp the fabric of spacetime, causing objects to move along curved paths. However, the manipulation of spacetime on a large scale is currently beyond our technological capabilities.
Is spacetime infinite?
This is a topic of debate among scientists. Some theories suggest that spacetime is infinite and has no boundaries, while others propose that it is finite and has a definite size. Currently, there is no conclusive evidence to support either theory.
