How did they rewrite this polynomial in this way?
  • Thread starter MiddleEast
  • Tags
    Polynomial
In summary, the polynomial was rewritten by factoring out common terms and rearranging its components to simplify its expression. This process often involves identifying patterns or utilizing algebraic identities to facilitate easier manipulation and understanding of the polynomial's structure.
MiddleEast
23
Not homework
Non.
How can you rewrite polynomial in terms of (x-a) instead of x?
One thing came to mind is rewrite each x as x-a+2 (So it is x-2+2 in our example) but this will take long time and a lot of algebra steps, how did they do it very fast in the attached picture? thanks
We can finish it as
[tex]f(x)=(x-2)(2x^2+x-15)=(x-2)(2x-5)(x+3)[/tex]
Once we percieve that x=2 is a solution, we can devide the given formula by x-2.
Thanks for reply. I know that, basically divide f by (x-2). But am interested in the way they did it algebraically.
Cause they gave two solutions for that problem in the book, first solution is the standard one which is dividing f by (x-2) which is a factor of f. The second solution they did as per attached image and then factor (x-2) out of three terms.
MiddleEast said:
Homework Statement: Not homework
Relevant Equations: Non.
Why do you think that they did it fast? Expanding x to (x-2)+2 is the the standard way to do it, as far as I know.
They probably just don't show all the (fairly routine) steps.
Thanks for reply, actually I found the way.
Basically start with A(x-2) + B (x-2) + C (x-2) where A,B & C could be variables/constants.
That A must be 2x^2 to get "2x^3" in original function, that A when multiplied by -2 will give -4x^4, now you have to choose B as x so that -4x^4 & B*x will give us -3x^2 in original function. And you just continue that way. Constant term will be adjusted automatically once we get the process in right way as x-2 is factor of f.
All of this can be done in one line as they did.
Likes FactChecker
That is a logical way to proceed. But "A must be" is too strong, since A, B, and C are indistinguishable at this point. I get your idea though. Maybe you could say that the first term will include the highest power of x.
EDIT: Even then, you would have terms with a mixture of ##x^n (x-2)## factors. Are you trying to factor out (x-2)? That is not leading directly to the goal of a polynomial of ##x-2##. I think it might be better to start with ##A(x-2)^2+B(x-2)+C## and see where that takes you.
But I still think that the most direct approach is to just replace all the ##x##s with ##(x-2)+2## in the original polynomial and multiply it out.
There's also the old school "long division" method I learned in junior high school:
These methods all seem essentially the same to me; each with a different look. It's just division, as you said.
Likes WWGD
I don't see how this gives an expansion in (x-2) without several additional steps. I think there are more direct ways.
Likes DaveE
But this is the same as the "A, B, C" method in post #5. I don't claim it's the most efficient, IDK.
What are your "more direct ways"? Surely it's not simplifying ##2[(x-2)+2]^3+[(x-2)+2]-15##, is it?
@MiddleEast Are you trying to derive the second polynomial equation from the first one?
##2x^3-3x^2-17x+30=2x^3-4x^2+x^2-2x-15x+30=2x^2(x-2)+x(x-2)-15(x-2)##
You wont start by writing A(x-2)+B(x-2)+C(x-2), you start by writing (x-2), divide first term of f by x (first term in x-2) and you would get "2x^2(x-2)", then ON SAME LINE continue writing 2x^2(x-2)+ [space] (x-2) .. now try to figure out what to put in the space by considering x^2 term coming from "2x^2(x-2)" and try to match it with coe of x^2 in original function.. continue doing this till you finish. It is basically about 30 seconds to rewrite function in terms of (x-2) so that (x-2) can be factored out. Fastest approach, knowing that x=2 is factor, is carrying out synthetic division for sure. But this way is clever and worth knowing.
Not deriving, main goal is rewriting polynomial in terms of (x-a) in each term in one single step so that (x-a) will be factored out.
Not sure if this is what you're looking for, but this is a power series about ##x=2##.
Likes DaveE
They are also skipping the most important step of determining that 2 is a rational root.
It is given in the question that x=2 is a root, and solution 1 was straightforward by dividing f by (x-2) and factor resulting quadratic equation to get f completely factored out as product of linear terms. Author said division could be long or synthetic. Up to here, it is pretty standard question on factor theorem. However, in solution 2 he just gave another way of writing f with each term containing (x-2) so that it can be factored out and got f(x) = (x-2) * quadratic and continue factoring quadratic to get f is product of linear terms.
Unless there is more than the little you posted, what you are calling solution 2 is not a solution strategy. There are no steps, he just wrote down the answer.
Exactly, thats my point it is at least non-standard way to simplify polynomial without standard long/synthetic vision method. This could help with higher level math questions when coe's are arbitrary constants.
I would guess that the second solution is the author doing synthetic long division in his/her head.
Alright. Isn't that what I have done? I expressed the polynomial in terms of ##x-2## for each term.
You can factor ##x-2## out.
##2x^3-3x^2-17x+30=2x^3-4x^2+x^2-2x-15x+30##
## ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ =2x^2(x-2)+x(x-2)-15(x-2)##
##~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~=(x-2)(2x^2+x-15)##
It would have been nice to tell us that. I couldn't understand why you were so interested in dividing out x-2. In general, that does not help to answer your original question.
Bonus points due for a method that isn't simple division. I take back what I said about that. I wouldn't have thought of this, I think.
OTOH, no one can do all those Taylor expansion derivatives in one step, or two.
##-5(x-2)+9(x-2)^2+2(x-2)^3## isn't either the first or the last step here.
Likes WWGD
Rational Roots Theorem! Several possible rational roots can be checked based on lead coefficient and the constant term. I avoid trying to describe here further.
Fabulous point, @Frabjous !
@MiddleEast
It would have been wonderful had you included this information in the OP.
DaveE said:
It was obvious in the attached picture.
Things we find out from the solution should not be used to explain how to reach that solution. If the zero is not known ahead of time, it is not valid to use it in telling someone how to solve that problem. In addition, the special circumstance shown, where x=2 is a zero, is not valid for the general question asked: "How can you rewrite polynomial in terms of (x-a) instead of x?"
Likes SammyS
FAQ: How did they rewrite this polynomial in this way?
What does it mean to rewrite a polynomial?
Rewriting a polynomial involves expressing it in a different form while maintaining its equivalence. This can include factoring, expanding, or rearranging terms to reveal different properties or to simplify calculations.
Why would someone want to rewrite a polynomial?
Rewriting a polynomial can help in various ways, such as simplifying complex expressions, making it easier to find roots, facilitating integration or differentiation, and revealing underlying structures that may not be apparent in its original form.
What are common methods for rewriting polynomials?
Common methods include factoring (expressing it as a product of simpler polynomials), expanding (distributing products), completing the square (to convert to vertex form), and using synthetic or long division (to simplify rational functions).
What does it mean to factor a polynomial?
Factoring a polynomial means expressing it as a product of its factors, which are polynomials of lower degrees. This can help identify the roots of the polynomial and make it easier to solve equations or analyze the polynomial's behavior.
How can I verify that the rewritten polynomial is equivalent to the original?
You can verify the equivalence by performing operations such as substitution, evaluating both forms at specific values, or using algebraic identities. Additionally, you can expand the rewritten form to see if it simplifies back to the original polynomial.
