How did Tycho Brahe measure time?
In summary: Tycho was measuring the shift of stars in the night sky against the background of the Milky Way. He was measuring the distance to stars, not their absolute positions.
jaqob
I could have formulated this in a few different ways, and posted it in different parts of the forum, but I think this is the most fitting one, even if I think that my question is more about time keeping.
I recently watched an episode of Cosmos about Edmond Halley where parallax measurements where discussed. This got me interested, and I started to read more, especially about Tycho Brahe and his measurements. (I really appreciated this text http://cseligman.com/text/history/braheastro.htm).
Everywhere you read you find references to how he was extremely accurate, measuring the stars placement down to 2 minutes of arc (1/30 of a degree). I (think I) understand the mathematics behind the parallax measurements, and if I do, the timing of the measurement must be critical. (In the simplest case, the Earth should be facing in the exact same direction for the measurements to be directly comparable).
Attempting to summarize my question, was Tycho Brahe, around year 1600, able to measure the time of day (or night) with the needed precision to be able to compare measurements in a correct way? (Since Kepler was able to use his measurements for very impressive calculations, I assume that the answer is yes, and then my second question is how?)
(One possibility is that he "only" measured the relative position between stars, but I guess this would defeat the purpose of using parallax measurements if you believe that the distance to all stars are equal, I.e. that they are positioned on the same sphere)
Astronomy news on Phys.org
If you want to measure a distance of one parsec using parallax, you obviously need to be able to detect an angular difference of one arc second. Let's do the math.
There are 360 degrees times 60 minutes per degree times 60 arc seconds per minute = 1.296 million arc seconds in a complete circle
There are 24 hours times 60 minutes per hour times 60 seconds per minute = 86400 seconds in a solar day.
Ignoring the discrepancy between the sidereal day and the solar day, the ratio between the two is 360/24 = 15 arc seconds per second.
The idea that Tycho Brahe was able to make celestial observations that depended on comparing celestial angles to the local vertical with a timekeeping accuracy of 1/15th of a second is... far fetched.
Yes. He measured relative positions. The negative results of Tycho's parallax measurements disprove the hypothesis that novae are near-earth phenomena.
To answer the title question, he used a clock. This is a clock that dates two centuries before Tycho.
To answer questions on parallax, one needs to use relative parallax - how much one star shifts with respect to the others.
Related to How did Tycho Brahe measure time?
1. How did Tycho Brahe measure time?
Tycho Brahe used a combination of clocks and astronomical observations to measure time. He also developed a new type of instrument called a "water clock" which used water dripping from one container to another to measure time.
2. What is a water clock and how did Tycho Brahe use it?
A water clock is a device that measures time by the regulated flow of water from one container to another. Tycho Brahe used this type of clock to accurately measure time intervals during his astronomical observations.
3. Did Tycho Brahe use any other instruments to measure time?
In addition to water clocks, Tycho Brahe also used mechanical clocks and sundials to measure time. He also developed a new type of clock called a "meridian clock" which used the position of the sun to tell time.
4. How did Tycho Brahe's measurements of time contribute to his astronomical discoveries?
Tycho Brahe's accurate measurements of time allowed him to make precise observations of the positions of stars and planets. This data was crucial in his development of the Tychonic system, a model of the solar system that combined elements of both the geocentric and heliocentric models.
5. Were Tycho Brahe's methods of measuring time accurate?
For his time, Tycho Brahe's methods of measuring time were considered very accurate. However, with advancements in technology and instruments, we now have more precise methods of measuring time. Nonetheless, Brahe's contributions to the field of astronomy and time measurement were significant and paved the way for further developments.
  • Astronomy and Astrophysics
  • Quantum Interpretations and Foundations
