MHB How did we find sqrt(ε_7(2)) ?
  • Thread starter Thread starter evinda
The discussion focuses on the function ε_p that maps integers to p-adic integers, specifically examining ε_7(2) and its square root. The square root of 2 modulo 7 is identified as 3, while for 7^2 (49) it is 10, and for 7^3 (343) it is 108, illustrating the process of finding these roots. The conversation emphasizes the importance of defining square roots in modular arithmetic without using the traditional square root symbol due to its multivalued nature. A correction is noted regarding a typo in the fourth term of the square root sequence. Overall, the thread provides insights into the methodology of calculating square roots in p-adic contexts.
evinda
MHB
Hi! (Smile)
Let the function
$$\epsilon_p: \mathbb{Z} \rightarrow \mathbb{Z}_p$$
$$x \mapsto (\overline{x_n} )_{n \in \mathbb{N}_0}$$
where $\overline{x_n} \equiv x \pmod {p^n}$
There are some examples:
$$\epsilon_7 (173)=(173,173,173, \dots, 173, \dots)=(5,26,173,173, \dots)$$
$$\epsilon_7(-1)=(-1,-1,-1, \dots)=(6,48,342,2400, \dots)$$
$$\epsilon_7(2)=(2,2, \dots, 2, \dots)$$
$$\sqrt{\epsilon_7(2)}=(3,10,108,2016, \dots)$$
Could you explain me how we found $\sqrt{\epsilon_7(2)}$ ? (Thinking)
Mathematics news on Phys.org
evinda said:
Hi! (Smile)
Let the function
A square root of two modulo $7$ is $3$, since $3^2 \equiv 9 \equiv 2 \pmod{7}$. A square root of two modulo $7^2 = 49$ is $10$ since $10^2 \equiv 100 \equiv 2 \pmod{49}$. A square root of two modulo $7^3 = 343$ is $108$ since $108^2 \equiv 11664 \equiv 2 \pmod{343}$. And so on. You can still define square roots modulo $n$, though I would recommend not using the $\sqrt{}$ symbol as it is multivalued and generally a nuisance, just stick with the definition: an integer $x$ is a square root of $a$ modulo $n$ if and only if $x^2 \equiv a \pmod{n}$.
EDIT: I suppose the fourth term should be $2166$, not $2016$. Typo?
Yes, that was a typo..
I understand, thank you very much! (Smile)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
19K
