How did WW II planes with tail wheels taxi?
  • Thread starter Thread starter Stephen Tashi
    Planes Wheels
Pilots of WWII tail dragger aircraft, characterized by their small tail wheels and high nose position, primarily steered during taxiing using rudders and brakes rather than a separate steering wheel. This design limits forward visibility, so pilots maneuver by swerving left and right while taxiing. Each aircraft has unique handling characteristics; for instance, the P-51 Mustang allows the tail wheel to be locked or unlocked using the control stick, enabling controlled turns with rudder pedals. The small size of tail wheels helps reduce aerodynamic drag, as many did not retract like the main wheels. Overall, understanding these mechanics is crucial for effective ground handling of tail draggers.
Stephen Tashi
Education Advisor
The tail wheels on many WW II planes look tiny. How did pilots steer these planes when taxing? Was it by using the tail wheel? If so, what control was used to turn the tail wheel ? - some sort of steering wheel separate from the other flight controls?
Science news on Phys.org
No. The steering was (is) with rudders and brakes
Those planes are referred to as "tail draggers" and when they are on the ground - taxiing or not - their tail is down and their nose is high. So, from the cockpit, there is no forward visibility.
To get around this problem, they are not taxied in a straight line. Instead they are swerved left and right as they move down the taxiway so that the pilot can look left or right to see forward.
Here's a good video: Taildragger Ground Handling
BTW: I've piloted the Citabria and the Decathlon. Fun!
Likes Imager, Klystron, Astronuc and 2 others
Some had tail skids, some had tail wheels, some were free castor, some skids or tail wheels were steerable along with the rudder, some used differential steering by breaking the left or right main wheels. Each individual aircraft would be different.
I concur with that.
For example for the P-51 Mustang the position of the stick could be used to lock and unlock the tail wheel.
From http://www.rwebs.net/avhistory/opsman/pursuit/section7.htm:
Taxi with stick slightly aft of neutral. This will lock the tail wheel. In the locked position the tail wheel may be turned 6 degrees to the right or left by use of the rudder pedals. For sharp turns, push stick forward of the neutral position to allow the tail wheel full swiveling action. Use brakes as little as possible.
For a long time the P-51 sim from A2A has been my favorite FSX airplane, in part because they choose to model this exact mechanism allowing some nimble taxi maneuvers while still maintaining control. Since flying a real P-51 is a bit out of reach I can of course only assume that this portraits the taxi behavior of a real P-51 :smile: .
Likes 256bits, Astronuc and Lnewqban
One of the reasons for that wheel to be small was to reduce aerodynamic drag while flying, since , in many models, it did not retract as main wheels did.
https://acousticstoday.org/wp-content/uploads/2021/03/Underwater-Acoustics-A-Brief-Historical-Overview-Through-World-War-II-Thomas-G.-Muir.pdf This topic relates to a discussion about a fictitious narrative regarding a cook on a merchant ship who purportedly developed an 'acoustic dampening system'. The story appears to be 'historical fiction' generated by AI (LLM). Ref: https://www.physicsforums.com/threads/random-thoughts-7.1056780/post-7293577 Edit/update (original post about a...
  • · Replies 22 ·
  • · Replies 60 ·
  • · Replies 19 ·
  • · Replies 35 ·
