How Do Binary Dwarf/Neutron Stars get so close?
In summary, close binary systems of white dwarfs can have very short orbital periods due to their small size and density. It is likely that these stars were originally further apart and have gradually come closer over a long period of time. This can be due to factors such as gravitational radiation and magnetized stellar winds. Eventually, these stars may merge, resulting in a neutron star or black hole and possibly a supernova event. However, it is also possible for them to settle into a stable small orbit and remain that way for a long time.
AdamAutism1998
28
I am a little puzzled with how there is a White Dwarf Binary of Five Minutes. How do they get so close?
Astronomy news on Phys.org
It's more than likely that the two stars originally were more distant from each other and orbiting more slowly.
Over a very long they have become closer, and so would need to orbit faster so that orbit is maintained.
Remember white dwarfs are very small and dense, so they could get very close together without actually colliding or merging.
Maybe this pair have settled into this small orbit and will stay that way for a long time, then again in the long run it's possible they will end up merging.
The result would probably be a neutron star, or possibly a black hole, and likely there would be a supernova event just before that.
If the original stars already are neutron stars, these are even smaller and denser then white dwarfs, and a binary pair could likely orbit even more rapidly before merging, (or exploding), could be in the region of seconds.
Interesting. That's very good. Though I didn't think they would naturally get so close from just evolution.
I used to believe it was from a close binary in which one star is a white dwarf, and the other is a main-sequence. They orbit really close together, almost as a W Ursae Majoris variable. When the main sequence evolves, it envelops the white dwarf in it's expanding envelope, causing a friction dynamic to slow the white dwarf, while increasing it's mass. This leads for them to get closer and by the time the planetary nebula is ejected. In the end(if a type Ia Supernova doesn't occur) a close binary is left over. Like how Henize 2-428 probably was.
Very interesting.
In the case of close binary stars, we have learned orbital decay can be driven via emission of gravitational radiation. In the Hulse-Taylor study they were able to accurately acount for the decrease in orbital period of the system PSR B1913+16 over time via this mechanism. This does not, however, explain how the stars get close enough in the first place for gravitational radiation to become a driver for orbital decay. The principal mechanism for orbital decay of binary systems besides gravitational radiation is magnetized stellar winds which bleeds the system of angular momentum and energy causing the orbital period to slowly decline.
Related to How Do Binary Dwarf/Neutron Stars get so close?
1. How do binary dwarf/neutron stars form?
Binary dwarf/neutron stars form when a massive star reaches the end of its life and undergoes a supernova explosion. The core of the star collapses, creating a neutron star, while the outer layers of the star are ejected, forming a white dwarf. The two stars then orbit each other in a binary system.
2. How do binary dwarf/neutron stars get so close together?
The close proximity of binary dwarf/neutron stars is due to their mutual gravitational attraction. As the two stars orbit each other, they can gradually come closer together due to the transfer of mass and angular momentum between them.
3. What is the distance between binary dwarf/neutron stars?
The distance between binary dwarf/neutron stars varies depending on the specific system, but it can range from a few thousand kilometers to a few million kilometers. This is significantly closer than the distance between planets in our solar system.
4. How do scientists study binary dwarf/neutron stars?
Scientists study binary dwarf/neutron stars using a variety of techniques, including observations with telescopes and other instruments that detect electromagnetic radiation such as X-rays and radio waves. They also use computer simulations and theoretical models to better understand the behavior of these systems.
5. Can binary dwarf/neutron stars merge?
Yes, binary dwarf/neutron stars can merge over time due to the loss of energy and angular momentum through gravitational waves. When this happens, it can result in a massive explosion called a kilonova, which can produce elements heavier than iron and contribute to the expansion of the universe.
