How Do Cauchy's Estimates Apply to Analytic Functions Within Unit Discs?
  • MHB
  • Thread starter Deanmark
In summary: Now, substituting $r = 1 - \frac{1}{n+1}$, we have $|f^{(n)}(0)| \le \frac{n!}{\left(1 - \frac{1}{n+1}\right)^n} (n+1) = (n+1)!\left(1 - \frac{1}{n+1}\right)^{-n}$. To complete the argument, we need
Deanmark
Let $f$ be analytic in the disc $|z| < 1$ and assume that $|f(z)| \le \dfrac{1}{1-|z|}$.
Show that $|{f}^{(n)}(0)| ≤ e(n + 1)!$.
Any ideas on how to bound $\max|f(z)|$ in the disc?
Be careful: on what domain do you take $\max \lvert f(z)\rvert$? To handle this problem, take a Cauchy estimate on the disk $\lvert z\rvert = 1 - \dfrac{1}{n+1}$. For all $\lvert z\rvert = 1 - \dfrac{1}{n+1}$, $\lvert f(z)\rvert \le n + 1$, giving the Cauchy estimate
$$\lvert f^{(n)}(0)\rvert \le \frac{n!}{\left(1 - \frac{1}{n+1}\right)^n} (n+1) = (n+1)!\left(1 - \frac{1}{n+1}\right)^{-n}$$
Now show that $\left(1 - \dfrac{1}{n+1}\right)^{-n} \le e$ to complete the argument. [Hint: Show first that $e^x > \dfrac{1}{1 - x}$ for $0 < x < 1$.]
One way to bound $\max|f(z)|$ in the disc is to use the Cauchy integral formula. Since $f$ is analytic in the disc $|z| < 1$, we can write $f(z) = \frac{1}{2\pi i} \int_{|w| = r} \frac{f(w)}{w-z} dw$, where $r < 1$ is the radius of the disc. Then, using the triangle inequality, we have $|f(z)| \le \frac{1}{2\pi} \int_{|w| = r} \frac{|f(w)|}{|w-z|} |dw|$. Since $|w-z| \ge |w|-|z|$, we can further bound this by $\frac{1}{2\pi} \int_{|w| = r} \frac{|f(w)|}{|w| - |z|} |dw|$.
Now, using the given inequality $|f(z)| \le \frac{1}{1-|z|}$, we have $\frac{|f(w)|}{|w| - |z|} \le \frac{1}{1-|z|}$. Therefore, we can write $|f(z)| \le \frac{1}{2\pi} \int_{|w| = r} \frac{1}{1-|z|} |dw| = \frac{1}{1-|z|}$.
Now, using the Cauchy integral formula for the derivative, we have $f^{(n)}(0) = \frac{n!}{2\pi i} \int_{|w| = r} \frac{f(w)}{w^{n+1}} dw$. Therefore, we can bound $|f^{(n)}(0)|$ by $\frac{n!}{2\pi} \int_{|w| = r} \frac{|f(w)|}{|w|^{n+1}} |dw|$. Using the same argument as before, we have $\frac{|f(w)|}{|w|^{n+1}} \le \frac{1}{|w|^{n+1}(1-|z|)}$. Thus, we can write $|f^{(n)}(0)| \le \frac{n!}{2
FAQ: How Do Cauchy's Estimates Apply to Analytic Functions Within Unit Discs?
What is Cauchy's Estimates Problem?
Cauchy's Estimates Problem is a mathematical problem in complex analysis that deals with the estimation of the maximum value of a function over a region. It was first posed by mathematician Augustin-Louis Cauchy in the early 19th century.
What is the significance of Cauchy's Estimates Problem?
Cauchy's Estimates Problem is significant because it provides a powerful tool for solving many complex analysis problems. It is widely used in various fields of mathematics, including complex analysis, differential equations, and number theory.
What is the general approach to solving Cauchy's Estimates Problem?
The general approach to solving Cauchy's Estimates Problem is to use Cauchy's integral formula, which relates the value of a function at a point to the values of the function at points within a given region. This formula can then be used to estimate the maximum value of the function over the region.
What are some applications of Cauchy's Estimates Problem?
Cauchy's Estimates Problem has various applications in mathematics and physics, including the study of analytic functions, approximation theory, and the solution of differential equations. It is also used in the study of complex systems, such as fluid dynamics and quantum mechanics.
Are there any limitations to Cauchy's Estimates Problem?
While Cauchy's Estimates Problem is a powerful tool, it does have some limitations. It only provides an estimate of the maximum value of a function, and it may not always give the exact value. Additionally, it may not be applicable to certain types of functions, such as non-analytic functions.
