How do copper oxide solar cells work?
Copper oxide solar cells utilize cuprous oxide as a semiconductor, where oxygen acts as a dopant, enabling the formation of a p-n junction. Unlike traditional solar cells that rely on two doped materials, these cells can function with a copper electrode, which is not a semiconductor. The discussion highlights the unique properties of cuprous oxide, emphasizing its semiconductor characteristics despite the absence of conventional doping. Additionally, the conversation touches on the concept of Schottky diodes, noting their requirement for doping, which differentiates them from copper oxide solar cells. Overall, the forum provides insights into the operational principles of copper oxide solar cells and their distinct mechanisms.
askingask
TL;DR Summary
Cuprous oxide - copper solar cells have not been doped, yet they work. What is going on, if no PN-junction exists here.
So basically, I‘ve always been told that solar cells work because of the PN-junction that exists between two doped materials. Then I‘d like to ask, how do solar cells work that use cuprous oxide - copper electrodes. The cuprous oxide acts as an semiconductor I guess? But It isn‘t doped, and the other electrode (copper) isn‘t even a semiconductor. I‘ve heard of Schottky diode solar cells, but even those require the semiconductor to be doped. So can someone please explain to me what exactly is going on here, and if there are other examples of this phenomenon.
Tom.G said:
The cuprous oxide is itself a semiconductor, one could say that the doping is the Oxygen.
https://royalsocietypublishing.org/doi/10.1098/rspa.1939.0066
(found with: https://www.google.com/search?&q=copper+oxide+photocell)
Cheers,
Tom
p.s. Google is often useful, you can often learn more from a search than asking us to search.
Damn thank you. I had difficulties finding good explanations to the actual workings of copper solar cells.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
