How do covalent bonds of the same molecule form?
In summary, covalent bonds form when atoms share electrons, creating a higher binding energy and stability for the atoms. This process is driven by quantum mechanics and is not typically taught in detail until later years of study. Noble elements also have London forces to consider, and promotion of electrons can enhance the effect. However, for full shell atoms, Pauli repulsion prevents this and only weaker Van der Waals interactions can occur.
Kuzon
42
There is no difference in electronegativity, so how do bonds form?
Take for example C-C, they both want 4 electrons for a full valence shell to become more stable - they meet each other, but how come they share 4 electrons? There is no difference in electronegativity for them to attract each other.
Also - can atoms only bond to themselves when they have half a valence shell full of electrons? E.g. carbon can bond to itself because it has 4 valence electrons but also needs 4 so another carbon fills its valence shell perfectly.Apologies if any parts of my question confuse you, I just started chemistry so I don't have a solid grasp on these concepts.
Chemistry news on Phys.org
Covalent bonds form when atoms share electrons ... physically the configuration with the shared electrons has a higher binding energy than the configuration without, so atoms want to be in them. It's quantum. You typically don't get to know the process in detail until your third year.
Likes Kuzon
If you consider the noble elements, there is also the London forces (also called van der Waals' forces) to consider.
The bonding results from electrons being attracted to both nuclei at the same time.
Since each C atom has an incomplete shell the electrons of the other atom can approach its nucleus.
Promotion of 2s -> 2p enhances the effect.
For full shell atoms Pauli repulsion prevents this. In such a case there is only the much weaker Van der Waals interaction.
That's what I like to hear. Thanks.
Likes Simon Bridge
No worries.
Likes Kuzon
Related to How do covalent bonds of the same molecule form?
1. How do covalent bonds form between atoms of the same molecule?
Covalent bonds form between atoms of the same molecule when they share electrons in order to achieve a full outer electron shell. This sharing creates a strong bond between the atoms, stabilizing the molecule.
2. What is the difference between a single, double, and triple covalent bond?
A single covalent bond involves the sharing of one pair of electrons between two atoms, a double covalent bond involves the sharing of two pairs of electrons, and a triple covalent bond involves the sharing of three pairs of electrons. This results in varying degrees of bond strength and bond length.
3. How does the number of valence electrons affect the formation of covalent bonds?
The number of valence electrons an atom has determines its ability to form covalent bonds. Atoms with a full outer electron shell (8 electrons) are generally stable and do not form covalent bonds, while atoms with less than 8 electrons in their outer shell are more likely to form covalent bonds in order to achieve stability.
4. Can covalent bonds form between two atoms of the same element?
Yes, covalent bonds can form between two atoms of the same element. This is known as a homonuclear covalent bond and is commonly seen in diatomic molecules such as oxygen (O2) and nitrogen (N2).
5. What factors influence the strength of a covalent bond?
The strength of a covalent bond is influenced by several factors, including the number of shared electrons, the distance between the nuclei of the atoms, and the types of atoms involved. Generally, the more shared electrons and the shorter the distance between nuclei, the stronger the covalent bond will be.
  • Chemistry
  • Chemistry
